Go to Post And that's why we all need to consider reserving a "No! Bad robot!" button for the robocoach. :yikes: - vhcook [more]
Unread 05-02-2006, 12:52
Nitroxextreme's Avatar
Nitroxextreme Nitroxextreme is offline
Relation to Mrs. Steve
AKA: Jon
FRC #1626 (Falcon Robotics ; 190 (Gompei and The Herd))
Nitroxextreme is a splendid one to beholdNitroxextreme is a splendid one to beholdNitroxextreme is a splendid one to beholdNitroxextreme is a splendid one to beholdNitroxextreme is a splendid one to beholdNitroxextreme is a splendid one to behold
Send a message via AIM to Nitroxextreme
Power of Victor Brake
I have seen that many teams are deciding that they need to have brakes so that they will not roll down off of the ramp.
What is the effectiveness of the Victor brake...is it really that bad that you need to have a manual brake?
"He needed a chuck norris lesson in FIRST"...."I will give him a round house kick to the face...with gracious professionalism"
Unread 05-02-2006, 13:22
kiracofe8 kiracofe8 is offline
#1317 (Digital Fusion)
kiracofe8 will become famous soon enough
Re: Power of Victor Brake
It depends on the friction in the rest of your drive train, but yes, it is probably that bad. The brake in the Victor is a dynamic brake. That means that the two leads of the motor are essentially connected together. When you try to turn the motor, it acts as a generator and produces a voltage which gets fed back and tries to prevent the motion. Try it yourself by just connecting the leads of a motor together. It's useful in many situations, but maybe not enough to keep you from rolling back down.
/* Daniel */
Unread 05-02-2006, 13:31
sanddrag sanddrag is offline
On to my 16th year in FRC
FRC #0696 (Circuit Breakers)
Does the Victor break work when the robot controller is disabled?
Unread 05-02-2006, 13:58
Billfred's Avatar
Billfred Billfred is offline
Last year, Ockham had a lift made of 80/20 lifted by a belt system powered by a van door motor. I'm not sure of the exact weight of everything together, but it would backdrive with the Victor braking even without a tetra.
Hope this gives you a bit of a gauge on how effective it is--if you really want it to stay in one place, I'd suggest a mechanical brake.
Unread 05-02-2006, 14:40
Umm Errr...
If you want to see what the effectiveness of the victor break is, power one of your motors directly off a battery, and while it is still spinning, take it off the battery and short the leads together. The motor will stop pretty rapidly. This is what the victor brake does. It Won't do much at all as far as locking your wheels from moving while your robot is stopped or at a very slow speed, but it will bring things to a stop pretty rapidly. The force it exerts is porportional to the current speed of the motor. It relies on using the motor as a shorted out generator.
1139 Alumni
Unread 05-02-2006, 14:45
Andy A. Andy A. is offline
Getting old
FRC #0095
It's as effective as the speed in which the motor is turning. As the motor gains speed it generates a higher voltage with slows it down. As it slows down, the voltage drops which lowers the effective braking effect so it speeds back up. This roller coaster gets averaged out of course, so in effect the brake produces a speed in which all the forces balance out.
As for keeping a robot on the ramp, it probably won't be enough. It will slow a robot down, but the robot will keep moving until the force of gravity can not overcome the friction of the drive train. Since scoring of objects on the ramp won't happen right away, the bot will probably hit the carpet before being scored.
The dynamic brake can slow down a motor. It can not 'lock up' a motor because as soon as the motor is not moving, it is not generating a voltage.
-Andy A.
Unread 05-02-2006, 15:13
The dynamic brake in a Victvor will not keep a robot on the ramp. It effectively is a method where in converting mechanical energy to electrical energy being delivered to a dead short provided by the brake, causes a similar load to be applied to the motor. Energy is generated only when the motor is moving.
Unread 05-02-2006, 15:24
Is a shorted motor not harder to turn though?
Also, does the braking still work when the RC is disabled?
Unread 05-02-2006, 15:26
Manoel's Avatar
Manoel Manoel is offline
FRC #0383 (Brazilian Machine)
Manoel has a reputation beyond reputeManoel has a reputation beyond reputeManoel has a reputation beyond reputeManoel has a reputation beyond reputeManoel has a reputation beyond reputeManoel has a reputation beyond reputeManoel has a reputation beyond reputeManoel has a reputation beyond reputeManoel has a reputation beyond reputeManoel has a reputation beyond reputeManoel has a reputation beyond repute
Send a message via ICQ to Manoel Send a message via MSN to Manoel
Al,
While I agree that the Brake function in the Victors will not hold a robot still in the ramp, it does help a bit. According to the Victor manual,
Originally Posted by Innovation FIRST
The Brake condition (Jumper on Outer two pins)
sets the output to a short across the motor leads
during neutral.
So, some resistance to turning will be achieved, even when the robot is disabled:
Originally Posted by Innovation FIRST FAQ
It seems that dynamic braking is disabled when the victor recieves no pwm input, (when the robot is disabled in the FIRST competition), regardless of the brake/coast jumper. Is this correct?
Would it be possible to let braking remain active when not recieving a pwm signal in later revisions of the 884?
No. When the Victor 884 does not a have a PWM signal, it looks at the jumper setting. If the jumper setting is Coast Mode, the Victor will remain in Coast. If the jumper setting is in Brake Mode, the Victor will remain in Brake Mode. Be aware that braking is proportional to the motor turning. Thus you can still turn a motor by hand slowly while in Brake Mode but it would be very difficult to turn it fast.
For the students that never played with it, the best motor to try it on is the FP with the gearbox attached. Try turning it with the leads connected and you'll see exactly what the Victor does when it is set to Neutral (a pwm output of 127) or has no signal while the Brake jumper is selected.
Manoel Flores da Cunha
Brazilian Machine
Team # 383
Unread 05-02-2006, 15:30
Sandrag,
I believe the brake jumper is still active when disabled.
Manoel,
I agree but the brake is still only effective when the motor is turning, so with it active you will still roll down the ramp, just more slowly than without the jumper.
Unread 05-02-2006, 16:26
Cody Carey's Avatar
Cody Carey Cody Carey is offline
AKA: C. Carey
FRC #0306 (CRT)
Cody Carey has a reputation beyond reputeCody Carey has a reputation beyond reputeCody Carey has a reputation beyond reputeCody Carey has a reputation beyond reputeCody Carey has a reputation beyond reputeCody Carey has a reputation beyond reputeCody Carey has a reputation beyond reputeCody Carey has a reputation beyond reputeCody Carey has a reputation beyond reputeCody Carey has a reputation beyond reputeCody Carey has a reputation beyond repute
Send a message via AIM to Cody Carey Send a message via Yahoo to Cody Carey
OK, yes... The break does still work when the RC is disabled... AND if there is enough friction in your drivetrain (probably with 6 or 8 wheel designs) the victor brake will be enough to slow your motion off of the ramp down, but it will be the friction that stops you. Basically, If you have to exert a "good amount" of force to push your robot on the groud while it is not powered up, then you have a chance at staying on the ramp with the Victor brake.
Unread 05-02-2006, 16:44
Conor Ryan Conor Ryan is online now
I'm parking robot yacht club.
FRC #4571 (Robot Yacht Club)
Conor Ryan has a reputation beyond reputeConor Ryan has a reputation beyond reputeConor Ryan has a reputation beyond reputeConor Ryan has a reputation beyond reputeConor Ryan has a reputation beyond reputeConor Ryan has a reputation beyond reputeConor Ryan has a reputation beyond reputeConor Ryan has a reputation beyond reputeConor Ryan has a reputation beyond reputeConor Ryan has a reputation beyond reputeConor Ryan has a reputation beyond repute
as long as your off the ground when the buzzer sounds, you should count as being on the ramp. The victor break may help you, but don't count on it.
The main use for the victor brake is when you are driving, when you let go the robot slows quickly, if you don't have the Victor break on the robot tends to coast for a few feet. We did some tests to see if the break eats the battery more than if it wasn't on, but it didn't seem to make a difference, at least in the 2 minutes and 15 seconds that we drove with them on (several times).
Unread 05-02-2006, 23:01
Jared Russell's Avatar
Taking a year (mostly) off
The brake is most useful when used on a motor whose position you are depending on. For example, our turret motor uses the Victor brake to keep from overshooting.
If you are just on the cusp of being able to stay on the ramp, the brake might help, but it's not going to be able to hold that much by itself.
Unread 05-02-2006, 23:40
Sachiel7's Avatar
Sachiel7 Sachiel7 is offline
<Yes I managed to flip it
AKA: Shayne Helms
FRC #1132 (RAPTAR Robotics)
Sachiel7 is just really niceSachiel7 is just really niceSachiel7 is just really niceSachiel7 is just really niceSachiel7 is just really nice
Send a message via AIM to Sachiel7
Brake-ing your victors can also assist your drivetrain to position a bit more accurately.
My question is (and I know this has been brought up before) what is the legality of flipping between brake and coast mode in-match, and how can this be done (I recall threads where people were talking ideas for this. )
I would assume you could build a custom circuit to do this easily..
The reason I ask is because our drivetrain is amazing with braking mode on. Very precise, fluid movement, etc.
But, we've been discussing the whole strategy debate of giong for the ramp when we remembered our strategy in '03.
In '03, our bot was set to coast by default, and at the last seconds in te match, we had the system such that we gunned it for the ramp, and coasted up into position, sometimes even after the buzzer. (just by a bit)
We've been talking of doing this this year, but would like to switch between coast and brake. Any ideas?
-=Sachiel7=-
There's no such thing as being too simple!
Look for Team #1132, RAPTAR Robotics at the VCU Regional this year!
Unread 05-02-2006, 23:42
There's a rule this year prohibiting that.
Need way to fix power feed on OI Shu Song Electrical 11 25-04-2004 15:03
Operator Interface power ISSUE kacz100 Technical Discussion 11 27-02-2004 13:46
URGENT!! Need OI power brick specs for 7AM demo tomorrow!!! kmcclary Electrical 8 10-10-2002 10:56
power of globe motor with gear box? Ken Leung Motors 5 21-11-2001 13:43
Max mechanical power of motors, how is it useful? Ken Leung Motors 1 09-11-2001 14:15
