Go to Post I'm pretty sure Andrew Baker and Andy Baker are the same person. Then again, Andy may just be holding out on us. - Amanda Morrison [more]
Unread 05-02-2006, 13:46
itzrobz itzrobz is offline
None #0333
itzrobz is an unknown quantity at this point
Sensor Help
Does anyone know how to set up a trans-beam receiver and trans-beam source?
Any help would be greatly appreciated.
Thanks
Unread 05-02-2006, 14:07
Jon236's Avatar
Jon236 Jon236 is offline
AKA: Jon Mittelman
FRC #2648 (Infinite Loop)
Jon236 has a reputation beyond reputeJon236 has a reputation beyond reputeJon236 has a reputation beyond reputeJon236 has a reputation beyond reputeJon236 has a reputation beyond reputeJon236 has a reputation beyond reputeJon236 has a reputation beyond reputeJon236 has a reputation beyond reputeJon236 has a reputation beyond reputeJon236 has a reputation beyond reputeJon236 has a reputation beyond repute
Re: Sensor Help
Thanks
Look on the side of each module......there is a little wiring digram. The transmitter (the one with 2 wires) gets 12v supplied. The receiver needs 5v. Each signal (NO and NC) gets pulled up with a resistor to 5v. You will need some perf board to get it all connected. You can choose to use either ouput, or both....each to its own digio.
