Go to Post I think the answer you will get will be the same we have been saying since post #2 on page 1. - KenWittlief [more]
Unread 04-02-2006, 21:15
Andrew Blair's Avatar
FRC #0306 (CRT)
Array Syntax Error
I'm using a lookup table to take joystick values and return a cubic function of them, basically just a drive ramp, but I cannot seem to get my array to compile properly. I have here a drastically reduced version, but one that still returns the same syntax error.
rom const unsigned char[2] = {0,3};
I've consulted all of the lookup table threads, but I feel that I have a small syntax error that is holding this up.
-Sir Francis Bacon
-Albert Einstein
Unread 04-02-2006, 21:27
Re: Array Syntax Error
A small syntax error? You left out the name of the array!
  rom const unsigned char arrname[2] = {0,3};
Unread 04-02-2006, 21:29
rom const unsigned char x[2] = {0,3};
Unread 04-02-2006, 22:09
FRC #0306 (CRT)
Please give me a moment while I proceed to beat my head against the wall...
Thanks! I knew I was missing something!!!
-Sir Francis Bacon
-Albert Einstein
Unread 05-02-2006, 02:05
Matt Krass's Avatar
AKA: Dark Ages
FRC #0263 (Sachem Aftershock)
It's ok.
Half an hour...
Over a dozen code downloads...
Two master resets...
Then I remembered to plug the PWM cables in
Oh and yeah, this beauty:
if(x > 0)
{x = 0;}
Matt Krass
Unread 05-02-2006, 02:16
Eldarion's Avatar
Eldarion Eldarion is offline
Electrical Engineer / Computer Geek
AKA: Eldarion Telcontar
no team (Teamless Orphan)
Eldarion has a reputation beyond reputeEldarion has a reputation beyond reputeEldarion has a reputation beyond reputeEldarion has a reputation beyond reputeEldarion has a reputation beyond reputeEldarion has a reputation beyond reputeEldarion has a reputation beyond reputeEldarion has a reputation beyond reputeEldarion has a reputation beyond reputeEldarion has a reputation beyond reputeEldarion has a reputation beyond repute
Send a message via AIM to Eldarion Send a message via Yahoo to Eldarion
Originally Posted by Matt Krass
It's ok.
Half an hour...
Speaking of which, here's one my mentor did:
He couldn't get a potentiometer value to display with the new 2006 code, so he put the old 2005 code in, only to discover that it still didn't work. A little while later a student walks in and notices that the OI was unplugged the whole time!
Then there's always the problem of "why doesn't the camera work!?"...
Oh, wait, the backup battery came loose again!
Maybe a thread should be started with "Top 100 Stupid Programming Mistakes"?
CMUCam not working? Tracks sporadically? Try this instead: http://www.falconir.com!
PM me for more information if you are interested (it's open source!).
Want the FIRST Email blasts? See here: http://www.chiefdelphi.com/forums/sh...ad.php?t=50809
"The harder the conflict, the more glorious the triumph. What we obtain too cheaply, we esteem too lightly; it is dearness only that gives everything its value."
-- Thomas Paine
If it's falling apart it's a mechanical problem. If it's spewing smoke it's a electrical problem.
If it's rampaging around destroying things it's a programming problem.
"All technology is run on 'Magic Smoke' contained within the device. As everyone knows, whenever the magic smoke is released, the device ceases to function."
-- Anonymous
I currently speak: English, some German, Verilog, x86 and 8051 Assembler, C, C++, VB, VB.NET, ASP, PHP, HTML, UNIX and SQL
Unread 05-02-2006, 13:37
The MPLAB environment is a great example of the finest IDEs of the 1970s. Modern IDEs save you lots of time during code development. If you can write C everything else looks easy by comparison. Code verifiers, real-time syntax checkers, and instant help systems still won't plug in the battery for you.
Unread 05-02-2006, 14:11
Eldarion's Avatar
I guess what I meant to say was "Top 100 Stupid Mistakes made by the Programmer".
-- Thomas Paine
-- Anonymous
C18 v2.4 -- Syntax error where there is no syntax error Joel J Programming 7 12-01-2007 17:27
Syntax Error! Denz Programming 15 04-02-2006 23:57
stupid Array error: Error [1300] stack frame too l Validius Programming 7 27-01-2006 10:53
Syntax Error: externs, structs, and macros Astronouth7303 Programming 3 16-02-2005 15:39
syntax error using enum{} gnormhurst Programming 8 07-02-2005 14:25
