Go to Post I know my posts are sometimes exhausting but there are PICTURES in this one, if that helps at all. - Jaine Perotti [more]
Unread 05-02-2006, 19:01
Don Reid Don Reid is offline
Don Reid will become famous soon enough
Error in dashboard spec
I believe I have found an error in the dashboard spec.
The file dashboard-specification.pdf, dated 1.5.2005 says (on page 4) that
the "extended" packet is:
    Byte06 USER BYTE 2
    Byte07 USER BYTE 3
    Byte08 CTRL_A
    Byte09 USER BYTE 5
    Byte10 CTRL_B
    Byte11 USER BYTE 5
    Byte12 CTRL_C
    Byte13 USER BYTE 6
    Byte14 PACKET NUMBER
    Byte15 USER BYTE 6
My experiments have shown that byte07 is not USER BYTE 3, but that byte09 is, and that bytes 4 & 5 are in byte11 and byte13, like this:
    Byte06 USER BYTE 2
    Byte07 ?????????
    Byte08 CTRL_A
    Byte09 USER BYTE 3
    Byte10 CTRL_B
    Byte11 USER BYTE 4
    Byte12 CTRL_C
    Byte13 USER BYTE 5
    Byte15 USER BYTE 6
Don Reid
Unread 05-02-2006, 23:07
Jared Russell's Avatar
Taking a year (mostly) off
Re: Error in dashboard spec
Can anyone else confirm this?
Unread 06-02-2006, 09:10
seanwitte seanwitte is offline
None #0116
seanwitte has a brilliant futureseanwitte has a brilliant futureseanwitte has a brilliant futureseanwitte has a brilliant futureseanwitte has a brilliant futureseanwitte has a brilliant futureseanwitte has a brilliant futureseanwitte has a brilliant futureseanwitte has a brilliant futureseanwitte has a brilliant futureseanwitte has a brilliant future
Send a message via AIM to seanwitte
How did you determine that the packet spec is wrong? If it's wrong I'd like to patch the software I've released, but I don't have access to a robot controller to verify. Can someone please confirm or deny the claim?
Unread 06-02-2006, 12:40
First I wrote a small c program to decode the packets based on the spec, I printed each of the duplicate entries shown. Then I hacked a copy of the robot code to output unique and changing values to the User_Byte variables. Looking at the reaults showed what was
happening.
I'll attach my updated dump code, It requires that the serail port already be set to 19200 baud etc. I write this for gcc on Linux, results on other platforms may vary.
Don Reid
Unread 06-02-2006, 12:54
None #0116
happening.
Did you validate the results with the IFI dashboard? Just curious whether theirs shows the correct values.
Unread 07-02-2006, 12:40
I posted the same basenote to their forum. No responce yet.
Don Reid
Unread 09-02-2006, 12:39
IFI has now posted http://www.ifirobotics.com/forum/vie....php?p=579#579
"Answer: You are correct. We have updated the dashboard-specification.pdf. Thanks for the feedback."
Don Reid
Dashboard Programs? EHaskins Programming 5 31-01-2006 14:01
Duplicate user byte 6 in Dashboard spec? Jared Russell Programming 3 23-01-2006 20:45
2004 Dashboard Protocal vs 2005 Dashboard Protocal Kyle T Programming 4 14-03-2005 22:19
Battery Voltages in Dashboard Ian W. Programming 10 07-03-2004 16:50
New dashboard packet spec Ameya Programming 2 08-01-2004 19:59
