Go to Post it doesn't matter so much why i joined [FIRST], but that i stayed :D - sure_smile [more]
View Poll Results: Has this affected your design?
Yes 33 30.28%
No 76 69.72%
Voters: 109. You may not vote on this poll
Unread 05-02-2006, 17:31
BoyWithCape195 BoyWithCape195 is offline
AKA: Ben Gagne
FRC #0195
BoyWithCape195 has a brilliant futureBoyWithCape195 has a brilliant futureBoyWithCape195 has a brilliant futureBoyWithCape195 has a brilliant futureBoyWithCape195 has a brilliant futureBoyWithCape195 has a brilliant futureBoyWithCape195 has a brilliant futureBoyWithCape195 has a brilliant futureBoyWithCape195 has a brilliant futureBoyWithCape195 has a brilliant futureBoyWithCape195 has a brilliant future
Send a message via AIM to BoyWithCape195
New rule Clarification changes plans
Has this Q & A made anyones designs illegal?
http://forums.usfirst.org/showthread.php?t=508
This new clarification complicates a lot of things. We didn't think there was anything illegal about our design until about 30 seconds ago, so now we must redesign, and we only have 2 weeks left!!
2007 UTC New England Regional Champions (1124 and 558)
2007 UTC GM Industrial Design
2006 International Championship Finalist (25 and 968)
2006 Newton Division Champions (25 and 968)
2006 Championship Innovation in Control Award
2006 UTC Quarterfinalist (236 and 230)
2006 UTC Innovation in Control Award
2005 Curie Division Quarterfinalists (703 and 234)
2005 UTC Semifinalist (228 and 236)
2004 UTC Entrepreneurship Award
2004 New Jersey Semifinalists (173 and 11)
2004 New Jersey Sportsmanship Award
Unread 05-02-2006, 17:45
Starke Starke is offline
Producer at The RoboSportsNetwork
AKA: Matt Starke
FRC #0174 (Arctic Warriors); (Alumni: 340 (GRR), 1126 (SparX))
Starke has a reputation beyond reputeStarke has a reputation beyond reputeStarke has a reputation beyond reputeStarke has a reputation beyond reputeStarke has a reputation beyond reputeStarke has a reputation beyond reputeStarke has a reputation beyond reputeStarke has a reputation beyond reputeStarke has a reputation beyond reputeStarke has a reputation beyond reputeStarke has a reputation beyond repute
Re: New rule Clarification changes plans
this rule does not change our design because our harvester (picking balls up from the floor) is within the 28x38 design criteria. so, we can also deliver balls to the corner goals without the problem of being outside these limits to be considered a shooter mechanism.
Team 340 | G.R.R. | Alumni/Mentor | 2003-2007, 2010
Team 1126 | SparX | Engineer | 2008-2009
FRCDesigns.com | Engineer | 2011 - Present
Team 174 | Arctic Warriors | Advisor | 2012 - Present
Unread 05-02-2006, 17:53
AKA: Ben Gagne
FRC #0195
I just read rule S03
<S03> The SHOOTING MECHANISM must remain inside the ROBOT - Any mechanism used to throw balls
must be contained within the original 28” x 38” x 60”starting envelope of the ROBOT and must be
shielded such that the mechanism cannot make contact with other ROBOTs. A ROBOT that violates this
rule will be considered unsafe per <S01>.
Reversing a roller outside the starting dimensions was not considered "throwing" in the design process of our team, so we never thought twice about it. Also rule S01 states
<S01> If at any time a ROBOT’s operation or design is deemed unsafe by the head referee, it will receive a 10-
point penalty and be disabled for the remainder of the match. If the safety violation is due to the ROBOT
design, the head referee has the option to not allow the ROBOT back onto the field unless the design has
been corrected. An example of unsafe operation is repeatedly throwing balls off the field at audience
members, media personnel, judges, referees, etc. An example of an unsafe design is a SHOOTING
MECHANISM that has a large mass that is stopped abruptly at the end of travel and is at risk of breaking
off the ROBOT and becoming a projectile.
Would this mean if it wasn't considered "dangerous" by the head referee, you could you use it? It also says due to robot design, the head ref would have to consider it "unsafe"
Unread 05-02-2006, 17:58
Manoel's Avatar
Manoel Manoel is offline
FRC #0383 (Brazilian Machine)
Manoel has a reputation beyond reputeManoel has a reputation beyond reputeManoel has a reputation beyond reputeManoel has a reputation beyond reputeManoel has a reputation beyond reputeManoel has a reputation beyond reputeManoel has a reputation beyond reputeManoel has a reputation beyond reputeManoel has a reputation beyond reputeManoel has a reputation beyond reputeManoel has a reputation beyond repute
Send a message via ICQ to Manoel Send a message via MSN to Manoel
Yes, but is it "shielded such that the mechanism cannot make contact with other ROBOTs", per rule <S03>?
I think that's the tricky part of the rule.
We have some redesigning to do, I think.
Manoel Flores da Cunha
Brazilian Machine
Team # 383
Unread 05-02-2006, 18:00
Greg Marra Greg Marra is offline
[automate(a) for a in tasks_to_do]
FRC #5507 (Robotic Eagles)
Greg Marra has a reputation beyond reputeGreg Marra has a reputation beyond reputeGreg Marra has a reputation beyond reputeGreg Marra has a reputation beyond reputeGreg Marra has a reputation beyond reputeGreg Marra has a reputation beyond reputeGreg Marra has a reputation beyond reputeGreg Marra has a reputation beyond reputeGreg Marra has a reputation beyond reputeGreg Marra has a reputation beyond reputeGreg Marra has a reputation beyond repute
Being the team that posted the question to the Q&A, we had to redesign part of our robot. I think the new solution we can up with is actually superior to our old design, but it forced us to go back to the drawing board.
Unread 05-02-2006, 18:19
AKA: Matt Starke
yes, our harvester is shielded so it does not make contact with other robots. so we are legal, right? i just want to make sure so we do not have to re-design again.
Unread 05-02-2006, 19:08
Collin Fultz's Avatar
Collin Fultz Collin Fultz is offline
no team (IndianaFIRST)
Collin Fultz has a reputation beyond reputeCollin Fultz has a reputation beyond reputeCollin Fultz has a reputation beyond reputeCollin Fultz has a reputation beyond reputeCollin Fultz has a reputation beyond reputeCollin Fultz has a reputation beyond reputeCollin Fultz has a reputation beyond reputeCollin Fultz has a reputation beyond reputeCollin Fultz has a reputation beyond reputeCollin Fultz has a reputation beyond reputeCollin Fultz has a reputation beyond repute
So do you think that this applies to doors that open out (hinged at bottom)? There is no power in the door...just gravity.
Collin Fultz
Unread 05-02-2006, 19:12
AKA: Ben Gagne
FRC #0195
I'm really hoping it doesn't, because that is probably what will have to change too...
Unread 05-02-2006, 19:18
chinckley chinckley is offline
Winner 2009 West Michigan District
FRC #1254 (Entropy)
chinckley is a name known to allchinckley is a name known to allchinckley is a name known to allchinckley is a name known to allchinckley is a name known to allchinckley is a name known to all
Question Re: New rule Clarification changes plans
I think I am confused about shielding. How can you shield a front loader that also might push balls back out and still collect balls? How do you shield the shooter but still allow shooting?
Wouldn't a ball collector low in front also allow soomeones corner of their robot to enter the collection area? I've seen pictures of robots with open areas low in front, where it looks like another robot could fit a corner into. Who gets the penalty then?
Any ideas?
Thanks,
Carolyn Hinckley
2009 West Michigan District Winner
Thanks to Team 216 and Team 1918
2009 Traverse City Semifinalist
Thanks to Team 1596 and Team 47
2009 Traverse City UL Safety Award Winners
Attending 2009: West Michigan, Traverse City, & State
Unread 05-02-2006, 19:31
Sachiel7's Avatar
Sachiel7 Sachiel7 is offline
<Yes I managed to flip it
AKA: Shayne Helms
FRC #1132 (RAPTAR Robotics)
Sachiel7 is just really niceSachiel7 is just really niceSachiel7 is just really niceSachiel7 is just really niceSachiel7 is just really nice
Send a message via AIM to Sachiel7
Guys, reread the first Q&A.
That device would not be a legal shooter . That means you cannot shoot balls rapidly out of it.
If you're not, you can still extend outside the 28x38 (or whatever) starting bounds.
So, your shouldn't have to redesign that much. Just lower the speed of your mechanism. I think FIRST needs to define a minimum velocity that defines a device as a shooter.
-=Sachiel7=-
There's no such thing as being too simple!
Look for Team #1132, RAPTAR Robotics at the VCU Regional this year!
Unread 05-02-2006, 19:35
They did. They very clearly said that no matter the exit velocity of the balls, it is "not a legal shooting mechanism because it is outside of the 28 x 38 inch allowable starting envelope."
Unread 05-02-2006, 19:42
Sachiel7's Avatar
AKA: Shayne Helms
I think FIRST needs to clarify it more then, because my interpretation of what they're saying is "if you're not using it as a shooter, it's fine". I would assume shooting would be more classified for the center goal. As per the rules, the center goal is the only goal that requires balls to be "shot" into, so FIRST calling it a "shooter" in my mind references more the center goals.
Perhaps I'm just understanding it wrong.
How is it a shooting mechanism if it slowly releases balls?
I think FIRST needs to further clarify this and possibly reconsider to allow teams who aren't pummeling balls out at 12 m/s to dump this way. Teams have safely used these mechanisms in the past, why stop a team from doing so if they're releasing them at a safe speed?
I seriously think FIRST should make a minimum velocity to classify a device as a shooter. If it's fast enough, it must abide by the shooted design rules. If it's under, it falls under the normal rules for robot components.
Just my $.02
edit: Unless you're referencing another Q&A post, they didn't say anything about "no matter the speed of the ball".
-=Sachiel7=-
Unread 05-02-2006, 19:43
dlavery's Avatar
dlavery dlavery is offline
Curmudgeon
FRC #0116 (Epsilon Delta)
If the mechanism can eject a ball, it is considered a shooter. See this question/answer. The velocity of the ball while being ejected does not matter.
-dave
Unread 05-02-2006, 19:47
-dave
I think this may be another "the intent of the rule" problem. A door for a ball leaving a basket isn't a shooter unless it is powered out of the basket. But if the basket has a powered ouput...it becomes a shooter.
Kind of like a stack being a stack being a stack, or a ball being "contained" in a goal.
Collin Fultz
Unread 05-02-2006, 19:50
AKA: Ben Gagne
FRC #0195
I really wish this new definition was released earlier...I think it will affect a lot of teams. This will make the next two week period very crammed for time, especially for those teams that have already finished their robot/ are close to finishing.
[OCCRA]: Rule Clarification Viking(redneck) OCCRA 3 24-11-2004 09:41
Rule Changes at off season competitions Ken Leung Off-Season Events 23 11-05-2004 22:39
Very Important Rule Clarification!!! Mr. Mac OCCRA 0 17-10-2002 23:35
IMPORTANT RULE ADDITION AND CLARIFICATION Mike McIntyre OCCRA 0 03-12-2001 22:17
