Go to Post The ChiefDelphi forums are more than just a place for people to kill time and engage in some chit chat. - Karthik [more]
Unread 04-02-2006, 11:34
sciguy125 sciguy125 is offline
Electrical Engineer
AKA: Phil Baltar
FRC #1351
sciguy125 has a reputation beyond reputesciguy125 has a reputation beyond reputesciguy125 has a reputation beyond reputesciguy125 has a reputation beyond reputesciguy125 has a reputation beyond reputesciguy125 has a reputation beyond reputesciguy125 has a reputation beyond reputesciguy125 has a reputation beyond reputesciguy125 has a reputation beyond reputesciguy125 has a reputation beyond reputesciguy125 has a reputation beyond repute
Send a message via AIM to sciguy125 Send a message via MSN to sciguy125 Send a message via Yahoo to sciguy125
Running just the compressor (was: free compressor)
This is a little unorthadox, so the rules weren't clear enough for my situation. If we were to run the compressor ONLY, would we need the associated valves, tanks, etc? It's not being used to run pneumatics. It's just plugged in and turned on.
-----BEGIN GEEK CODE BLOCK-----
Version: 3.12
GE/S/P a-- e y-- r-- s:++ d+ h! X+++
t++ C+ P+ L++ E W++ w M-- V? PS+ PE+
5- R-- tv+ b+ DI+++ D- G
------END GEEK CODE BLOCK------
Unread 04-02-2006, 12:23
Re: free compressor
there wouldnt happen to be a party noise maker attached, would there?
or the end of a broken balloon (PHbpbppbpbpbbhbhbhblp! :^)
I dont think you can connect the compressor to anything other than the approved pneumatic components, valves, hoses, tanks...
if its literally not connected to anything, then what function does it serve?
Unread 04-02-2006, 13:28
Electrical Engineer
AKA: Phil Baltar
FRC #1351
Re: free compressor
Assumptions:
1. balls in hopper will jam
2. shaking paintball hopper unjams it
3. compressor vibrates
4. anything compressor is bolted to will vibrate
5. vibration will unjam balls
Version: 3.12
Unread 04-02-2006, 13:32
Re: Running just the compressor (was: free compressor)
It would be lighter and easier to take one of the smaller motors and bolt an eccentric plate to the shaft. For example, take a 2- or 3- inch diameter round piece of aluminum plate and drill a hole off-center. Attach the round to the motor, and attach the motor to whatever you want to vibrate. I guarantee it will vibrate like crazy. You will probably dramatically reduce motor life, but it only has to last for a few minutes, right?
Unread 04-02-2006, 13:40
Electrical Engineer
AKA: Phil Baltar
FRC #1351
Well, it'd be lighter, but not necesarily easier. The compresser already has mounting holes and is already made. We just have to plug it in. Weight might not be an issue because we want it. Our goal is to push the robot right up to the limit.
We might not even go with this vibrator, I was just investigating options.
Version: 3.12
Unread 04-02-2006, 13:49
interesting
have you considered having your drive train motors twitch for a instant?
I cant think of any logical reason why you would not be allowed to attach the compressor like this, but I can think of several easier and more effective ways to make your bot shake like a Chihuahua OD'ing on caffeine.
(keep in mind, when you get to your 1st event you may come up with an idea for something you want to add to your bot. Having some margin on your weight will make that easier).
Unread 04-02-2006, 20:37
Unsung FIRST Hero Woodie Flowers Award
Chris Fultz Chris Fultz is offline
My Other Car is a 500 HP Turbine
FRC #0234 (Cyber Blue)
Rookie Year: 1942
Chris Fultz has a reputation beyond reputeChris Fultz has a reputation beyond reputeChris Fultz has a reputation beyond reputeChris Fultz has a reputation beyond reputeChris Fultz has a reputation beyond reputeChris Fultz has a reputation beyond reputeChris Fultz has a reputation beyond reputeChris Fultz has a reputation beyond reputeChris Fultz has a reputation beyond reputeChris Fultz has a reputation beyond reputeChris Fultz has a reputation beyond repute
It sounds like it would be a legal set-up, since you would never operate over the 60 or 120 psi level.
BUT< if you are serious about pursueing this idea, I would suggest your mentor formally ask the question on the FIRST Q&A website, then, assuming they say it is OK, take a copy of the question and answer page with you.
If your robot design is dependent on it, you do not want to leave it to the judgement / interpretation of the inspectors at a Regional.
Chris Fultz
Cyber Blue - Team 234
2016 IRI Planning Committee
2016 IndyRAGE Planning Committee
2010 - Woodie Flowers Award - Championship
Unread 05-02-2006, 14:22
DarkJedi613's Avatar
DarkJedi613 DarkJedi613 is offline
Running Riot
AKA: Patrick Cloke
FRC #0358 (Hauppauge Robotic Eagles) FRC #1493 (RPI/Albany High School)
DarkJedi613 is a splendid one to beholdDarkJedi613 is a splendid one to beholdDarkJedi613 is a splendid one to beholdDarkJedi613 is a splendid one to beholdDarkJedi613 is a splendid one to beholdDarkJedi613 is a splendid one to beholdDarkJedi613 is a splendid one to behold
Send a message via AIM to DarkJedi613 Send a message via MSN to DarkJedi613 Send a message via Yahoo to DarkJedi613
If you're running the compressor the whole time your battery life/power will be down a bit. I'm not sure positive, but I don't believe you'd be allowed to just switch the compressor on/off when you want either, it has to be computer controlled?
Or maybe you could shut it off, but the only "on" is still computer regulated?
Just throwing the idea out there.
2003 - 2006 President, Coach, Webmaster Team358.org
2008 Mentor, Team 1493
Team Search | (Updated: 1-16-08)
FIRSTsearch
Unread 05-02-2006, 15:40
From and inspection standpoint, you would need to demonstrate that the compresoor will shut off should the pressure "somewhere" reach 120 PSI. That requires that the cutoff switch, guages and at least a valve to close the system be attached. Please note the compressor has some vibration damping built into the mount. This might not give you as much as the previous idea of a motor with an eccentric weight.
Unread 05-02-2006, 19:53
chrisinmd's Avatar
chrisinmd chrisinmd is offline
AKA: Chris Pickett
FRC #0888 (Robotiators)
chrisinmd is a jewel in the roughchrisinmd is a jewel in the roughchrisinmd is a jewel in the rough
Send a message via AIM to chrisinmd
Re: free compressor
Originally Posted by sciguy125
Assumptions:
that is a good train of thought, but the compressor doesn't vibrate as much as a small motor with a eccentric mass, like the little one in a cell phone. The compressor in the kit of parts is a fairly quality component in that it is quiet and doesn't vibrate like mad. It also draws a fair amount of power when it's running. If you were using pneumatics on your robot, then what you're thinking of might be an option, but if you just want the compressor for its weak vibration, you might want to consider something else.
Unread 05-02-2006, 20:23
ForgottenSalad's Avatar
ForgottenSalad ForgottenSalad is offline
In search of a home...
AKA: Michael Wessler
ForgottenSalad will become famous soon enoughForgottenSalad will become famous soon enough
Send a message via AIM to ForgottenSalad
Re: free compressor
Do they still include the mabuchi motor in the KOP? I don't recall seeing it this year...
If so, you could just slap a weight onto it like you'd see in the handle of one of those clear PS2 controllers (or something likewise that'd generate more vibration) and be better off than using the compressor. (Assuming it gets enough RPMs... I've never used one, I wouldn't know)
Unread 05-02-2006, 22:40
If I were a judge, looking for clever engineering solutions and innovative designs for the judges awards, I would be more impressed by a team that designed a mechanism specifically to shake a holding bin precisely as needed, than I would be by a team that bolted the compressor on the robot to make it vibrate.
Compressor = overkill.
Unread 06-02-2006, 01:12
dlavery's Avatar
dlavery dlavery is offline
Curmudgeon
FRC #0116 (Epsilon Delta)
Actually, if I were a judge I would be very impressed by a team that was able to recognize that a solution to an problem was right in front of them through the innovative use of an existing part. By efficient use of existing materials, the team is able to quickly solve a problem, is able to avoid using extra (scarce) materials, avoids design efforts to create a duplicative solution, and is able to redeploy their human resources to work on other, potentially more important, problems. And if this were being done in a professional environment, as a project manager I would be very impressed by a team that was able to find a quick way to solve a problem without additional overhead, instead of racking up lots of additional manpower charges to design a solution for a problem that can be solved in a cheaper, faster, simpler way.
Good engineering often comes down to knowing the difference between "better" and "good enough."
-dave
Unread 06-02-2006, 11:26
JVN JVN is offline
@JohnVNeun
AKA: John Vielkind-Neun
FRC #0148 (Robowranglers)
-dave
"Sometimes 'done' is better than 'perfect'."
Unread 06-02-2006, 11:52
week 5 = panic!
Free Service At 2005 Florida Regional mdion Regional Competitions 5 04-03-2005 11:46
Default code and the Compressor Matthew_H Programming 16 07-02-2005 07:19
