Go to Post It's a hunch, based on engineering intuition; there are too many hard-to-quantify variables to do any accurate calculations. Looking for some experimental corroboration or refutation. - Ether [more]
Unread 15-01-2006, 16:15
WebWader125
Posts: n/a
Shielding the Shooter
Rule S03 specifies that the shooter mechanism must be shielded. Now that FIRST has clarified that the shooter includes any barrel (if so equipped), I'm wondering how teams are thinking about shielding the shooter?
I'm assuming a piece of Lexan with a hole for the ball to exit, mounted right after the shooter...
Unread 15-01-2006, 16:30
Andrew Blair's Avatar
FRC #0306 (CRT)
Re: Shielding the Shooter
Something like that. The intent of the rule is so you can't have an exposed flywheel that, even through extraordinary circumstances, cannot make contact with something and explode, or something else bad.
-Sir Francis Bacon
-Albert Einstein
Unread 15-01-2006, 17:47
TSIMFD
AKA: Sean Lavery
FRC #1712 (DAWGMA)
I think a barrel would probably count as shielding in itself, but dont take only my word for it. As long as the actual mechanism that is providing kinetic energy to the ball (fly wheel, piston, etc) is shielded I think you'll be fine.
As to how to shield it, a polycarb/aluminum/wooden case would work, and so would a "rollcage" or something of that nature.
Unread 15-01-2006, 23:38
WebWader125
Posts: n/a
Be careful... I posted that specific question (whether a barrel following a shooter counts as part of the shooter mechanism that must be shielded) on the FIRST Q&A forum. The answer was yes. Prior to that answer, I would have also guessed that shielding the moving parts would have been sufficient.
With several other posts talking about turrets, I'm wondering how they would be shielded.
Unread 16-01-2006, 16:27
psycho7 psycho7 is offline
pyscho
AKA: (ex-freshman)
FRC #1831 (Screaming Eagles)
Team Role: Scout
psycho7 is on a distinguished road
Send a message via AIM to psycho7
Cool Re: Shielding the Shooter
I'm just wondering how people are going to make sliding shielding work, because I've looked at and to have a robust moving shield system is going to be rather comlex and heavy. Then again it's area that I haven't done a lot of work, so I may or may not be right
Definitions of Nerd and Geek: Geek-the people who go to dances, try and dance,and get beaten up. Nerd- those who stay home during the dances and study.
by week two of FIRST robotics, everything needed to be done as of last week.
think outside the box.
what is 1+1=?
answers:
window;11;2;mace
Unread 16-01-2006, 17:18
Excelsior's Avatar
Excelsior Excelsior is offline
Electrical Head
AKA: Alex Hughes
None #1208 (Metool Brigade)
Team Role: Electrical
Excelsior is on a distinguished road
Send a message via AIM to Excelsior
So, if you make a turret, in order to shield it, you basically have to put it in a box? Therefore forgoeing any tank resemblance a robot may end up with?
Drat it all.
Edit:
Also, with the shooting device needing to stay within the 28x38x60 area, does any shooter shielding also have to stay within that area?
Team 1208
The Metool Brigade
Three Hours Short of Going Insane
0=====<(' '<) <( ' ' )> (>' ')>=====0
Unread 19-01-2006, 11:44
Kevin_547 Kevin_547 is offline
FRC #0547
Kevin_547 is an unknown quantity at this point
is there any way to do this or against the rule of going up to a bot shooting and blocking their shots as long as u stay in the size requirments.
Unread 19-01-2006, 15:44
dhitchco's Avatar
dhitchco dhitchco is offline
Awards/Photo/Video &quot;wizard&quot;
AKA: Doug Hitchcock
FRC #1511 (Rolling Thunder)
dhitchco has a brilliant futuredhitchco has a brilliant futuredhitchco has a brilliant futuredhitchco has a brilliant futuredhitchco has a brilliant futuredhitchco has a brilliant futuredhitchco has a brilliant futuredhitchco has a brilliant futuredhitchco has a brilliant futuredhitchco has a brilliant futuredhitchco has a brilliant future
Please post the link to any offical FIRST Q&A responses here. I could not find reference to the official response to shielding.
The more "shielding" that is put in place (e.g. covvering the barrel of some shooting mechanism) runs counter-intuitive to rule <G30> in extracting extra balls from your overly-shielded robot at the end of the match.
It also runs counter-intuitive to rule <S03> about keeping the "shooting mechanism" INSIDE the 28x38x60 envelope. it just seems to be adding more "bulk" to cover the entire "mechanism" including stationary parts like the barrel, etc.
Lastly, the need to "shield" the entire mechanism seems to run counter-intuitive to rule <G13> about needing to be able to "clearly see" all of the balls pre-stored on-board the robot.
The THUNDER just keeps getting LOUDER in 2008....
Team 1511 now supports over 15 FLL teams
RollingThunder....Winner of the 2007 Chairman's Award at Finger Lakes Regional and Spirit Award at Boston.....Winner of 2006 Finger Lakes Regional Engineering Inspriation and Boston Imagery awards.......Winner of 2005 World Championship Rookie All-Star (plus FLR Rookie All-Star, Buckeye Top-Seeded Rookie, GTR Champion, Spirit, and Inspiration)
"Gracious Professionalism is a WAY of life".....
Unread 19-01-2006, 16:42
Jon K. Jon K. is offline
n.e.r.d #6
Jon K. has a reputation beyond reputeJon K. has a reputation beyond reputeJon K. has a reputation beyond reputeJon K. has a reputation beyond reputeJon K. has a reputation beyond reputeJon K. has a reputation beyond reputeJon K. has a reputation beyond reputeJon K. has a reputation beyond reputeJon K. has a reputation beyond reputeJon K. has a reputation beyond reputeJon K. has a reputation beyond repute
In terms of getting at the balls easy, make your shielding out of polycarb of some sort held on with like velcro or some other sort of quick disconnecting fastener. That will also allow for the quick sighting of balls stored. As for the rule about the shooting mechanism staying in the box, well thats just part of the design challenge.
Alumnus of FLL 2000 ~ Alumnus of FRC173 2002-2005 ~ Mentor of FRC173 2006-2007 ~ Mentor of FRC 3780 2014
FIRST Volunteer since 2003
Manufacturing Manager
AndyMark, Inc.
http://www.andymark.com
Unread 19-01-2006, 23:38
insub2 insub2 is offline
None #1227
insub2 is an unknown quantity at this point
<S03> Shooter Mechanism must remain inside the ROBOT - Any mechanism used to throw balls must be
contained within the original 28” x 38” x 60”starting envelope of the ROBOT and must be shielded such
that the mechanism cannot make contact with other ROBOTs
. A ROBOT that violates this rule will be
considered unsafe per <S01>.
the sheilding is only neccessary to prevent contact with other robots.
also, is this the Q&A you posted???
Q:
Originally Posted by FRC663
Rule S03 states that the shooter mechanism must remain within the original starting envelope of the robot. If a robot uses a pitching machine style shooter, followed by a barrel to direct the ball, does the barrel count as part of the shooter mechanism? I assume the intent is to keep moving/dangerous parts out of the reach of other robots?
A:
Originally Posted by GDC
The barrel does count as part of the shooter mechanism and must remain within the original starting envelope.
if so, it doesn't say anything about sheilding your barrel. it just says that it has to stay inside the starting envelope. so as long as your barrel doens't come in contact with other robots, you don't need to put it in a box.
Unread 05-02-2006, 20:05
chinckley chinckley is offline
Winner 2009 West Michigan District
FRC #1254 (Entropy)
chinckley is a name known to allchinckley is a name known to allchinckley is a name known to allchinckley is a name known to allchinckley is a name known to allchinckley is a name known to all
Question Re: Shielding the Shooter
I think I am confused about shielding. How can you shield a front loader that also might push balls back out and still collect balls? How do you shield the shooter but still allow shooting?
Wouldn't a ball collector low in front also allow someones corner of their robot to enter the collection area? I've seen pictures of robots with open areas low in front, where it looks like another robot could fit a corner into. Who gets the penalty then?
Also, since I see lots of teams using wheels to shoot out the ball could they cover the wheels and shooter with hardware cloth. Unless you use lexan, ordinary plastic could shatter if wheels got loose.
Just trying to understand SHIELDING.
Thanks
Carolyn
2009 West Michigan District Winner
Thanks to Team 216 and Team 1918
2009 Traverse City Semifinalist
Thanks to Team 1596 and Team 47
2009 Traverse City UL Safety Award Winners
Attending 2009: West Michigan, Traverse City, & State
The Knights Who Say Nee (1341)'s Shooter Prototype Adam Richards Robot Showcase 13 27-01-2006 15:42
Team 125 Ball Shooter Prototype! Brandon Holley Technical Discussion 21 21-01-2006 00:07
One or Two Wheel Shooter Nitroxextreme Technical Discussion 6 14-01-2006 01:10
pic: team 125 minature ball shooter prototype Brandon Holley Extra Discussion 5 14-01-2006 00:52
Ball Shooter Squall Rules/Strategy 7 11-01-2005 14:47
