Go to Post Congratulations! You have been successful! You got what you wished for! Now get to work. - gblake [more]
Unread 05-02-2006, 15:35
Re: Motor Limits
The limit switches will be listed as "micro switches" in a catalog or at Radio Shack. Digikey and Mouser both have tons of different types. On a really important application, back up a pot with a limit switch set (mounted) to the absolute farthest travel you can allow. The pot works but might not stop a fast moving motor in time to prevent damage.
Unread 05-02-2006, 23:36
Idaman323 Idaman323 is offline
In Theory, Our Robot Would Own.
FRC #1706
Team Role: Driver
Idaman323 is an unknown quantity at this point
Re: Motor Limits
Okay, so we got his code from Salad
If your motor was hooked to pwm01 you'd use...
Limit_Switch_Max(rc_dig_in01, &pwm01);
Limit_Switch_Min(rc_dig_in02, &pwm01);
Where in the code would you put this? And is this all you would need to get it to work properly?
TEAM 1706
2007 Judges Award, St. Louis (For our amazing ability to have bad luck)
2005 Rookie Inspiration Award, St. Louis
Unread 06-02-2006, 00:15
ForgottenSalad's Avatar
ForgottenSalad ForgottenSalad is offline
In search of a home...
AKA: Michael Wessler
ForgottenSalad will become famous soon enoughForgottenSalad will become famous soon enough
Send a message via AIM to ForgottenSalad
Re: Motor Limits
I don't exactly know why that code wasn't working for us (although it's probably something stupid and obvious that I'm missing) but all it was doing was slowing down our motors when they hit the limit switches instead of stopping them. If someone would please clear that up it would be greatly appreciated by me and I'm sure by Idaman as well.
NOTE: Yes, our speed controllers are calibrated.
Unread 06-02-2006, 08:02
Donut Donut is offline
The Arizona Mentor
AKA: Andrew
FRC #2662 (RoboKrew)
Re: Motor Limits
That should be the code to stop them. We have it in the code, but haven't tested it yet.
When hit, the limit switch should only stop your motor from moving in one direction, unless their was an error made programming it.
What pwms and inputs are you using when it's not working properly? I keep hearing bad things about pwms 13-16, if you're using one of those try a different one.
Unread 06-02-2006, 20:56
FRC #1706
Team Role: Driver
Re: Motor Limits
Hmm, does that get put some where in the user_routines.c file? If so, what section of it? I woudl liek to see how it works with our motors. Thanks
TEAM 1706
Unread 07-02-2006, 00:08
The Arizona Mentor
AKA: Andrew
Re: Motor Limits
The call to the limit switch function can be put where ever you like it (this will be in a function called in user_routines.c or directly in there), just make sure that it is called AFTER the other code you use to set pwm values. It makes no sense to limit your motor so it can't drive further, then to command it to drive beyond it afterwards, since the last command will be the one the motor sees.
