Go to Post pit visitor: "Why'd you use #35 chain?" team member "less links to CAD...." - Aren_Hill [more]
Unread 05-02-2006, 15:28
armoredvehicle's Avatar
armoredvehicle armoredvehicle is offline
ArmoredVehicl
AKA: Ahmad El-Arabi
FRC #0691 (HartBurn)
Team Role: Electrical
armoredvehicle is on a distinguished road
Send a message via AIM to armoredvehicle
Question Shipping Crate
Hey everybody. I am kinda confused about this shipping crate stuff. Can you only make the crate out of wood, or can you make it out of 80/20 or Lexan or other materials?
And do any of you have a good material to make the box out of or some plans and drawings. I would greatly appreciate it
Unread 05-02-2006, 20:00
agndoggieboi's Avatar
agndoggieboi agndoggieboi is offline
CpT. cOMmANdo
AKA: Snoogie
FRC #0368 (Kika Mana (Tiger Power))
Team Role: Mascot
agndoggieboi is an unknown quantity at this point
Send a message via AIM to agndoggieboi Send a message via Yahoo to agndoggieboi
Re: Shipping Crate
as long as the crate holds up from shipment to the competition then its good. just make sure it wont fall apart or someting!!
see our crate is just a big yellow box with stuff.
if at first u dont succeed...bash it till u do!!!
Unread 05-02-2006, 20:03
ChuckDickerson's Avatar
ChuckDickerson ChuckDickerson is offline
FRC #0456 (Siege Robotics)
Re: Shipping Crate
Originally Posted by Collin Fultz
You can make it out of whatever you want...
Huh, that's not how I read it:
6.3.2 Crate Specifications
When you build your crate, remember to consider the weight of your materials. For instance, if 3/8” or ½”
plywood is sturdy enough, why use the much heavier ¾” product? Build it with more than one shipment
and/or season in mind.
All Crates must:
• NEW: Comply with the Wood Materials Regulations above if the crate ships into the U.S.
• Weigh 400 pounds or less in order to avoid drayage overage charges
• Be sturdily built to prevent damage to your equipment
Have plywood construction to ensure stacking capability during transport
• "Sit" on 2 pieces of 4" by 4" lumber, spaced at least 28" apart so it can be moved by a forklift.
• Have a footprint no greater than 4' by 4' and be no taller than 5'10" (70") high. This maximum
includes the 4" by 4" lumber mentioned above.
• Be capable of being moved by a forklift
I am just quoting the rules here but it seems like you cannot, in fact, make it out of whatever you want. Again, read the rules closely. They are your friend.
Unread 05-02-2006, 20:04
Collin Fultz's Avatar
Collin Fultz Collin Fultz is offline
no team (IndianaFIRST)
Collin Fultz has a reputation beyond reputeCollin Fultz has a reputation beyond reputeCollin Fultz has a reputation beyond reputeCollin Fultz has a reputation beyond reputeCollin Fultz has a reputation beyond reputeCollin Fultz has a reputation beyond reputeCollin Fultz has a reputation beyond reputeCollin Fultz has a reputation beyond reputeCollin Fultz has a reputation beyond reputeCollin Fultz has a reputation beyond reputeCollin Fultz has a reputation beyond repute
Re: Shipping Crate
You may be right...I was basing my post on history...but that rule pretty much negates it. Thank you!
Collin Fultz
Unread 05-02-2006, 20:08
Re: Shipping Crate
I believe the intent of the plywood requirement is to meet the requirements of shipping companies. While a crate made of diamond plate or 80/20 and lexan may look cool I don't think the freight companies care so much about looks as they do sturdiness. Wood crates have been the standard for centuries.
Unread 05-02-2006, 21:51
dachickindapit dachickindapit is offline
AKA: Gina Sweet
FRC #0033 (The Killer Bees)
dachickindapit is a name known to alldachickindapit is a name known to alldachickindapit is a name known to alldachickindapit is a name known to alldachickindapit is a name known to alldachickindapit is a name known to all
Send a message via AIM to dachickindapit Send a message via Yahoo to dachickindapit
Re: Shipping Crate
This question was posted on the FIRST Q&A and was answered that other materials can be used.
Q: Our crate is built with aluminum structure with aluminum diamond plates sides. It is stackable and easily able to support 600#. We have used this crate for many years. Do we have to change it to plywood per rule 6.3.2?
A: No.
http://forums.usfirst.org/showthread.php?t=498
2017-??: Team 33 -- The Killer Bees
2001-2016: Team 67 -- The Heroes of Tomorrow
1997: FLL Pilot Program
**Controls and Electrical Systems for who knows how many years now**
Unread 05-02-2006, 22:19
Re: Shipping Crate
Hmmm, well isn't that a contradiction. I guess I stand corrected. However, our crate is plywood and will stay that way to be safe. I have also seen a contradiction on shipping vs. bringing batteries to the competition. The rules clearly state that the crate must include the robot and the two batteries in the 2006 KoP but one of the questions on the Q&A seems to allow teams to not ship the batteries with the robot and just bring them with them.
6.3.5 Required Crate Contents
Teams must include the robot and the two batteries. Carefully and completely follow all instructions above listed in the “Battery Packaging“ section...
Q) Bringing batteries to events with the teams?
Will teams be permitted to bring the 12V batteries with them to events, as opposed to shipping them in the crate, as was done last season?
A) Yes, but be aware of shipping requirements on airlines.
http://forums.usfirst.org/showthread.php?t=284
Sometimes, I dunno what to believe!
Unread 05-02-2006, 22:21
Re: Shipping Crate
I think that would mean that you must ship two...but can bring others instead of shipping them
Collin Fultz
Unread 05-02-2006, 22:32
Re: Shipping Crate
That is definitely one way to interpret the Q&A, however, to be perfectly clear a better answer would have been "You must ship 2 but may bring any extra with you...". My question would then be why? If you can bring extra batteries but must ship 2 then what is the real point? All teams seem to have the right to either buy extra batteries or use old ones from previous years so what is the point of having to comply with the federal battery shipping regulations (special box inside the crate, extra labeling, etc.) when we can just bring them with us?
Unread 06-02-2006, 01:22
Katie Reynolds Katie Reynolds is offline
no team (NEW Apple Corps)
Katie Reynolds has a reputation beyond reputeKatie Reynolds has a reputation beyond reputeKatie Reynolds has a reputation beyond reputeKatie Reynolds has a reputation beyond reputeKatie Reynolds has a reputation beyond reputeKatie Reynolds has a reputation beyond reputeKatie Reynolds has a reputation beyond reputeKatie Reynolds has a reputation beyond reputeKatie Reynolds has a reputation beyond reputeKatie Reynolds has a reputation beyond reputeKatie Reynolds has a reputation beyond repute
Send a message via AIM to Katie Reynolds Send a message via Yahoo to Katie Reynolds
Re: Shipping Crate
If you look through last year's Q&A, the "do we have to ship two batteries" question was posed to the committee and the answered (I'm paraphrasing here), "No, if you're driving to an event you can bring the batteries with you, and don't have to ship them."
I wonder if that still stands for this year.
Team #93 - NEW Apple Corps
Student - 2001-2004
Team #857 - Superior Roboworks
Mentor - 2006-2009
Size of shipping crate Max Brin Technical Discussion 1 18-01-2006 16:19
**FIRST EMAIL**/FedEx Airbills and Robot Shipping Information Rich Wong FIRST E-Mail Blast Archive 0 05-02-2005 18:55
Your Shipping Crate JohnBoucher Technical Discussion 21 26-07-2004 15:08
What is your shipping crate made out of, and what does it weigh? Elgin Clock Technical Discussion 9 17-07-2004 20:02
the size of the shipping crate, the maximum dimensions?????????? MASherry General Forum 5 13-01-2004 22:30
