Go to Post Ahh yes, the good old "let's dedicate all our resources to absolutely cheesing the opponent alliance" strategy - Jaci [more]
Unread 06-02-2006, 08:35
Andy Brockway Andy Brockway is offline
Engineer
FRC #0716 (Who'sCTEKS)
Andy Brockway has a reputation beyond reputeAndy Brockway has a reputation beyond reputeAndy Brockway has a reputation beyond reputeAndy Brockway has a reputation beyond reputeAndy Brockway has a reputation beyond reputeAndy Brockway has a reputation beyond reputeAndy Brockway has a reputation beyond reputeAndy Brockway has a reputation beyond reputeAndy Brockway has a reputation beyond reputeAndy Brockway has a reputation beyond reputeAndy Brockway has a reputation beyond repute
pic: Dual FP KOP Tranny
Andy Brockway
Team 716, The Who'sCTEKS
Unread 06-02-2006, 08:36
jjdebner's Avatar
jjdebner jjdebner is offline
Jdizzle
AKA: Joshua Debner
None #0195 (Cyber Knights)
jjdebner has much to be proud ofjjdebner has much to be proud ofjjdebner has much to be proud ofjjdebner has much to be proud ofjjdebner has much to be proud ofjjdebner has much to be proud ofjjdebner has much to be proud ofjjdebner has much to be proud ofjjdebner has much to be proud of
Send a message via AIM to jjdebner
Re: pic: Dual FP KOP Tranny
Does this mean you are going to be using 4 FP to drive your robot?
- 2004 Entrepreneurship Award, UTC Regional
- 2004 3rd Place, NJ Regional
- 2004 J&J Sportmanship Award, NJ Regional
- 2006 Championship Finalist
- 2006 Innovation in Control Award, UTC Regional
- 2006 Championship Inovation in Control Award
- 2007 Winner UTC Regional
- 2007 GM Industrial Design Award, UTC Regional
Unread 06-02-2006, 08:44
Jonathan Norris Jonathan Norris is offline
Jno
FRC #0610 (Crescent Robotics)
Jonathan Norris has a reputation beyond reputeJonathan Norris has a reputation beyond reputeJonathan Norris has a reputation beyond reputeJonathan Norris has a reputation beyond reputeJonathan Norris has a reputation beyond reputeJonathan Norris has a reputation beyond reputeJonathan Norris has a reputation beyond reputeJonathan Norris has a reputation beyond reputeJonathan Norris has a reputation beyond reputeJonathan Norris has a reputation beyond reputeJonathan Norris has a reputation beyond repute
I would suspect it is for their cannon system. You would have too many problems burning them out if you used them to drive. I only think you are allowed 2 of them anyways.
Co-Founder of Taplytics.com
2013 World Champions (1241, 1477, 610)
Crescent Robotics Team 610 Mentor
K-Botics Team 2809 Founding Mentor ('09-'11)
Queen's University Mechanical Engineering, Applied Science '11
Crescent Robotics Team 610 Alumni
Unread 06-02-2006, 09:03
Crebb's Avatar
Crebb Crebb is online now
AKA: James M.
FRC #5279 (Bionic Eagles)
Crebb has much to be proud ofCrebb has much to be proud ofCrebb has much to be proud ofCrebb has much to be proud ofCrebb has much to be proud ofCrebb has much to be proud ofCrebb has much to be proud ofCrebb has much to be proud ofCrebb has much to be proud of
What kind of gear is that and where did you get it? We were looking to use the fp motor last year but couldn't find the specs on the gear that comes on it. Thanks- James
Shibuya Hoppmann, Mechanical Engineer
VCU School of Engineering 2012
Team 5279 2016-Present
Team 384 2003-2015
Unread 06-02-2006, 09:16
David Guzman's Avatar
David Guzman David Guzman is offline
AKA: Dave
FRC #1251 (The Techtigers)
David Guzman has a brilliant futureDavid Guzman has a brilliant futureDavid Guzman has a brilliant futureDavid Guzman has a brilliant futureDavid Guzman has a brilliant futureDavid Guzman has a brilliant futureDavid Guzman has a brilliant futureDavid Guzman has a brilliant futureDavid Guzman has a brilliant futureDavid Guzman has a brilliant futureDavid Guzman has a brilliant future
This is most likely for a shooter because the output rpms seems very high I would guess arround 1200 or so.
Team 1251 The Techtigers
2010 FL Regional Winner (BIG thanks to 86 and 1612)
2009 FL Regional Finalist (BIG thanks to 79 and 744)
2008 FL Regional Winner, FL GM Industrial Design, SC GM Industrial Design
2007 FL Regional Winner, FL GM Industrial Design, Palmetto Regional Finalist, Palmetto Motorola Quality.
2006 Palmetto Regional Winner, Daimler Chrysler Team Spirit Award
2005 FL Regional Judges Award, FL Regional 3rd seeded and finalist, Palmetto Regional Xerox Creativity Award, Palmetto Regional 1st seeded and finalist
2004 UCF Regional Rookie All-star Award
Unread 06-02-2006, 11:41
Engineer
We are using this for our "shooter" (per FIRST definition). RPM is actually around 450 based on 16,000 free speed.
Ken Patton says "Our F-P is a 9012, and it has a 32 pitch, 19 tooth pinion on it" and mine are the same. The mating gear is 46 tooth that I had lying around but is available through PIC (not recommended per bad experience with this company), Berg, Stock Drive and others. I had a 46 tooth, I suggest the readily available 45 tooth for anyone who wants to copy this.
The specs on FP motors are scattered throughout CD, a five minute search will give you specs on multiple years. The motors come with different tooth counts, typically 16 or 19.
Good Luck!
Andy Brockway
Dual fields Keith Chester Rumor Mill 11 05-04-2005 17:57
Looking for KOP Helical Gears ChuckDickerson Kit & Additional Hardware 1 21-07-2004 15:39
Team 968's technokat inspired 4 speed tranny Travis Covington Robot Showcase 12 01-03-2004 10:06
pic: dual speed gearbox CD47-Bot Extra Discussion 9 07-10-2003 15:04
