Go to Post I love robotics, it has a spot for every kinda future career a student chooses. - Bharat Nain [more]
Go Back   Chief Delphi > Technical > IT / Communications > Website Design/Showcase
Unread 21-01-2006, 00:13
Dan Zollman's Avatar
Dan Zollman Dan Zollman is offline
7
FRC #1712 (Dawgma)
Dan Zollman has a reputation beyond reputeDan Zollman has a reputation beyond reputeDan Zollman has a reputation beyond reputeDan Zollman has a reputation beyond reputeDan Zollman has a reputation beyond reputeDan Zollman has a reputation beyond reputeDan Zollman has a reputation beyond reputeDan Zollman has a reputation beyond reputeDan Zollman has a reputation beyond reputeDan Zollman has a reputation beyond reputeDan Zollman has a reputation beyond repute
Installing MySQL on Windows
I've successfully installed Apache 2 and PHP 5 (on Windows XP), which I'm using for website testing. I'd also like to install MySQL for database use with PHP.
I've tried to install MySQL using some instructions I have and the instructions in the MySQL manual, but that's kind of confusing and, though it seems that MySQL was installed on the computer, it doesn't show up with the phpinfo() function and it doesn't seem to be recognized by Apache or PHP.
Can anybody help with this? Are there any websites with clear, step by step instructions for installing MySQL with Apache and PHP from the beginning for someone who doesn't necessarily know a lot about system configuration or using the command line?
Thanks,
Dan
Product design student at Rensselaer
Web designer/consultant
FIRST alum, Dawgma 1712
dan.zollman - at - gmail.com
Unread 21-01-2006, 00:28
Rohan_DHS Rohan_DHS is offline
AKA: Kayla's big bro...
FRC #1620 (Robolution)
Rohan_DHS is a glorious beacon of lightRohan_DHS is a glorious beacon of lightRohan_DHS is a glorious beacon of lightRohan_DHS is a glorious beacon of lightRohan_DHS is a glorious beacon of light
Send a message via MSN to Rohan_DHS
Re: Installing MySQL on Windows
Hey there Dan,
I don't know any good sites out there for tutorials or such, but for managing the databases once you set things up, there are two good programs available from the same people who made MySQL called MySQL Query Browser and MySQL Administrator, which add nice GUI based management functions.
I know that this probably won't help until after you've set this up, but it takes care of the command line problem
Good luck,
Rohan
Unread 21-01-2006, 00:37
Davx's Avatar
Davx Davx is offline
Davux
AKA: Dave Amenta
FRC #0195 (Cyber Knights)
Davx will become famous soon enoughDavx will become famous soon enough
Send a message via AIM to Davx Send a message via MSN to Davx
Install the MyODBC driver, that will allow PHP to talk to MySql, you can get the driver at the MySql website.
--David Amenta - Dave Amenta .com - Person Meets Profession
Unread 21-01-2006, 14:12
107Dexter 107Dexter is offline
I write code
AKA: slenk
FRC #0107 (Team R.O.B.O.T.I.C.S.)
Team Role: Webmaster
107Dexter is on a distinguished road
Send a message via AIM to 107Dexter Send a message via MSN to 107Dexter
What I would suggest doing is downloading and installing Xampp . It has Apache2, PHP 5, and MySQL with a bunch of plugins. And it is installed so they are allc ommunicating with eachother already.
Free Images Hosting Service: http://upload.team107.org
Audioscrobbler iTunesRegistry.com: 2,230 tracks, 4.130 diversity
Unread 21-01-2006, 15:44
7
FRC #1712 (Dawgma)
Thanks for the quick responses.
I think I'll try that because it's probably the simplest and fastest way to do this (plus, it has PHPMyAdmin).
First, will I be able to safely and cleanly use Add/Remove Programs to remove Apache, PHP, and MySQL, or will that cause problems since Apache and MySQL are listed as services?
Unread 21-01-2006, 15:45
DarkJedi613's Avatar
DarkJedi613 DarkJedi613 is offline
Running Riot
AKA: Patrick Cloke
FRC #0358 (Hauppauge Robotic Eagles) FRC #1493 (RPI/Albany High School)
DarkJedi613 is a splendid one to beholdDarkJedi613 is a splendid one to beholdDarkJedi613 is a splendid one to beholdDarkJedi613 is a splendid one to beholdDarkJedi613 is a splendid one to beholdDarkJedi613 is a splendid one to beholdDarkJedi613 is a splendid one to behold
Send a message via AIM to DarkJedi613 Send a message via MSN to DarkJedi613 Send a message via Yahoo to DarkJedi613
Here's a tutorial I had written for a couple of my friends to install Apache2, PHP 5.x and MySQL. It is slightly outdated however.
Apache2 Win32 Binary (MSI Installer)
--Download & Run
----Information:
------Domain: 127.0.0.1
------Server: localhost
------Email: whatever@whatever.com
------Manual
--Configure
----Goto "C:\Program Files\Apache Group\Apache2\conf"
------Open "httpd.conf"
--------Find & Change "DirectoryIndex" to:
----------"DirectoryIndex index.htm index.html index.html.var index.php index.php3 index.phtml"
--------Add to Bottom:
----------#PHP Stuff:
----------LoadModule php5_module "C:/PHP/php5apache2.dll"
----------AddType application/x-httpd-php .php .php3 .phtml .phtm
----------PHPIniDir "C:/PHP"
Windows (x86) - mysql-4.1.14-win32.zip
--Download & Run
----Typical
----Skip Sign Up
----Standard Setup
------Include BIN
------Do not Automatically Run
----Security Settings
------Password
Windows Binaries - Zip Package
--Unzip to C:\PHP
----Rename "php.ini-dist" to "php.ini"
----Open "php.ini"
------Find "Windows Extensions"
--------Uncomment Extensions Needed
----------Recommended:
------------images = php_gd2.dll
------------mysql = php_mysql.dll
------------pdf = php_pdf.dll
------------sockets = php_sockets.dll
------------zip = php_zip.dll
--------Path and Extensions
----------extension_dir = "C:\PHP\ext"
Download PECL Modules for PHP
--Unzip
----Copy "php_pdf.dll" and "php_zip.dll" to "C:\PHP\ext\"
Optional - Download phpMyAdmin
--Unzip to "C:\Program Files\Apache Group\Apache2\htdocs"
--Rename folder to "phpMyAdmin"
--Open "config.inc.php"
----Change 'host' to 'localhost'
----Change 'port' to '8080'
----Change 'password' to what you set it while installing MySQL
----"http://localhost:8080/phpMyAdmin/" runs it
***ALL DOCUMENTS GO IN THE FILE "C:\Program Files\Apache Group\Apache2\htdocs"***
Hint: Make shortcut on your desktop.
To Run Files:
--Run Apache2
----Program Files > Apache HTTP Server x.x.x > Control Apache Server > Start Apache in Console
----Program Files > MySQL > MySQL Server x.x
Extras:
--Download the icon files for PHP and set up PHP files to have that icon
I also have some nice batch files for running the server and shutting it down if you want them. If you're having trouble installing it feel free to IM me on AIM.
2003 - 2006 President, Coach, Webmaster Team358.org
2008 Mentor, Team 1493
Team Search | (Updated: 1-16-08)
FIRSTsearch
Unread 05-02-2006, 12:32
7
FRC #1712 (Dawgma)
It took me a couple of weeks before I got to it, but I installed MySQL (and the other things that come with it) with Xampp. It worked.
Originally Posted by DarkJedi613
Here's a tutorial I had written for a couple of my friends...
I wanted to use Xampp for the simplest installation possible, but I saved that tutorial in case I could use it in the future.
Thanks for your help!
Unread 05-02-2006, 14:16
Running Riot
AKA: Patrick Cloke
Yeah, I figured I would just post it in case you still wanted to go that way. Also it (well most of it) is available with screen shots now on our website.
FIRSTsearch
Unread 06-02-2006, 00:25
Chris_Elston's Avatar
Chris_Elston Chris_Elston is offline
Controls Engineer
AKA: chakorules
FRC #1501 (Team THRUST)
Chris_Elston has a reputation beyond reputeChris_Elston has a reputation beyond reputeChris_Elston has a reputation beyond reputeChris_Elston has a reputation beyond reputeChris_Elston has a reputation beyond reputeChris_Elston has a reputation beyond reputeChris_Elston has a reputation beyond reputeChris_Elston has a reputation beyond reputeChris_Elston has a reputation beyond reputeChris_Elston has a reputation beyond reputeChris_Elston has a reputation beyond repute
Hi Dan...
Although I don't really like windows, I had a need recently to install a MySQL database / server on my local machine to do some database debugging with PHP. I found a website that helped me STEp-BY-STEP get mysql running on my Windows XP desktop so I could complete my task.
Hopefully this will help you:
http://www.devside.net/web/server/windows/mysql
Team T.H.R.U.S.T. 1501
Download all of our past robot's source code here:Repository
Favorite CD quote:
"That can't be their 'bot. not nearly enough (if any) rivets to be a 1501 machine." ~RogerR: Team #1369
Unread 06-02-2006, 09:40
7
FRC #1712 (Dawgma)
Thanks again!
Winzip and Windows XP problem, please help sanddrag IT / Communications 9 15-12-2005 16:13
MPLAB on Windows XP Greg Marra Programming 12 08-01-2005 13:23
MySQL on Windows Venkatesh IT / Communications 6 27-06-2004 19:12
Malware, Adware and Spyware JohnBoucher Technical Discussion 41 16-05-2004 22:51
Windows ME robot180 Chit-Chat 11 07-07-2003 00:21
