Go to Post GP is an ideal to live by, but not a tool to judge with. - Rich Kressly [more]
Unread 06-02-2006, 10:25
cmurdoch cmurdoch is offline
AKA: Caroline Murdoch
FRC #1208 (Metool Brigade)
cmurdoch is on a distinguished road
Camera Troubles
I'd like to say there's a problem with the camera itself causing our problems. Unfortunately, the camera was working fine until I attempted to adapt the tracking and search code to manipulate the pwm output for our rotating turret instead of the pan servo. I tried my best to leave the tilt tracking code intact. When we tested, however, the panning code worked as anticipated, while the tilt code didn't work at all (well... it tried to work, but failed miserably resulting in a subtle twitching motion). It seems as though the camera is trying to change the tilt servo value and remain in home position simultaneously. I'd appreciate any ideas anyone might have to solve my problem. Thanks
CMU Camera kills robot controller if not found. Chris_Elston Programming 21 27-03-2006 14:30
How To Use the Google Camera generalbrando Kit & Additional Hardware 2 07-02-2006 16:00
Camera Is Spazzing Out! BrittanyV Programming 15 04-02-2006 13:39
Scripting Setup and the Camera + Serial Port Drivers CJO Programming 22 11-01-2006 17:42
CMUCam2 Camera Code - Are important parts commented out? Mr. Lim Programming 4 14-01-2005 12:11
