Go to Post Stand up and cheer for yourselves and others. That is FIRST, don't change it. - Steve W [more]
Unread 05-02-2006, 14:38
Ami Schwartz Ami Schwartz is offline
FRC #1657
Ami Schwartz is an unknown quantity at this point
How to use a "Timer"
How to include the Timer to the program.
P.S how many 1/x bits per Sec.
Thx alot "Hamosad" team.
Unread 05-02-2006, 14:53
MacFlightSierra MacFlightSierra is offline
FRC #0912 (Iron Lyons)
MacFlightSierra is an unknown quantity at this point
Re: How to use a "Timer"
one loop of the controller is 26.2 millis - approx 38 loops per second. just add a variable to count till 38 and then reset it to zero
good luck/behatzla'ha
Unread 05-02-2006, 15:46
Eldarion's Avatar
Eldarion Eldarion is offline
Electrical Engineer / Computer Geek
AKA: Eldarion Telcontar
no team (Teamless Orphan)
Eldarion has a reputation beyond reputeEldarion has a reputation beyond reputeEldarion has a reputation beyond reputeEldarion has a reputation beyond reputeEldarion has a reputation beyond reputeEldarion has a reputation beyond reputeEldarion has a reputation beyond reputeEldarion has a reputation beyond reputeEldarion has a reputation beyond reputeEldarion has a reputation beyond reputeEldarion has a reputation beyond repute
Send a message via AIM to Eldarion Send a message via Yahoo to Eldarion
A word of caution--I learned the hard way that this is not always true.
The loop executes at a minimum of 26.6ms, but it most certainly can take much longer than 26.6ms!
The BLROD doesn't trigger until the code takes a whopping 1/4 to 1/2 second per loop!
EDIT:
If you want an example of this behavior, try the 2005 default camera code.
The code slows dramatically as soon as the camera is hooked up, and as far as I can tell, takes more on the order of 1/4-second per loop.
CMUCam not working? Tracks sporadically? Try this instead: http://www.falconir.com!
PM me for more information if you are interested (it's open source!).
Want the FIRST Email blasts? See here: http://www.chiefdelphi.com/forums/sh...ad.php?t=50809
"The harder the conflict, the more glorious the triumph. What we obtain too cheaply, we esteem too lightly; it is dearness only that gives everything its value."
-- Thomas Paine
If it's falling apart it's a mechanical problem. If it's spewing smoke it's a electrical problem.
If it's rampaging around destroying things it's a programming problem.
"All technology is run on 'Magic Smoke' contained within the device. As everyone knows, whenever the magic smoke is released, the device ceases to function."
-- Anonymous
I currently speak: English, some German, Verilog, x86 and 8051 Assembler, C, C++, VB, VB.NET, ASP, PHP, HTML, UNIX and SQL
Unread 05-02-2006, 16:48
phrontist's Avatar
phrontist phrontist is offline
Proto-Engineer
AKA: Bjorn Westergard
FRC #1418 (Vae Victus)
phrontist has a reputation beyond reputephrontist has a reputation beyond reputephrontist has a reputation beyond reputephrontist has a reputation beyond reputephrontist has a reputation beyond reputephrontist has a reputation beyond reputephrontist has a reputation beyond reputephrontist has a reputation beyond reputephrontist has a reputation beyond reputephrontist has a reputation beyond reputephrontist has a reputation beyond repute
Send a message via AIM to phrontist
Do not depend on loop timings! They are highly variable!
Use timer interrupts. Kevin has code on his website.
University of Kentucky - Radio Free Lexington
"I would rather have a really big success or a really spectacular crash and failure then live out the warm eventual death of mediocrity" - Dean Kamen
Unread 05-02-2006, 16:58
Mike Shaul's Avatar
Mike Shaul Mike Shaul is offline
FRC #0065 (Huskie Brigade)
Mike Shaul has a brilliant futureMike Shaul has a brilliant futureMike Shaul has a brilliant futureMike Shaul has a brilliant futureMike Shaul has a brilliant futureMike Shaul has a brilliant futureMike Shaul has a brilliant futureMike Shaul has a brilliant futureMike Shaul has a brilliant futureMike Shaul has a brilliant futureMike Shaul has a brilliant future
I'm a little unclear of what the actual question is. Are you asking how to use the PIC's internal timers? How to use the timers would vary based on your application. The PIC's timer modules can be configured as either timers or counters based on a few different internal sources (at varying speeds) as well as external sources.
If you are interested in using the timer modules I would suggest you start by reading the data sheet on the PIC micro timer modules and then reviewing Kevin's interrupt/timer code from 2005 (he hasn't posted 2006 code yet).
Once you've reviewed the above items you should have a better idea of what you are looking for, or where you may need some assistance.
By far the best proof is experience. - Sir Francis Bacon
Unread 06-02-2006, 09:38
FRC #1657
We did read the PDF files and we dont know the specific code to operate the Timer.
( AKA. we dont know how to use the code thats in the "H" files ) .
Thx again : )
Unread 06-02-2006, 12:11
tribotec_ca88's Avatar
tribotec_ca88 tribotec_ca88 is offline
FIRST-a-holic
AKA: Camila Fitzgibbon
FRC #1382 (Tribotec Team)
Team Role: Student
tribotec_ca88 is just really nicetribotec_ca88 is just really nicetribotec_ca88 is just really nicetribotec_ca88 is just really nicetribotec_ca88 is just really nice
Send a message via ICQ to tribotec_ca88 Send a message via MSN to tribotec_ca88 Send a message via Yahoo to tribotec_ca88
Hmm...i wouldn't recommend using the "approx 38 loops per second" method.
If you're looking for greater precision i recommend using the interrupt-driven timers. Our team is currently using Timer1 of the five PIC timers. Perhaps i'm not the best person to explain you exactly how they work but let me see if i can help...
First off, we created a function known as Init_timers(); (inside a .c file of our choice), which is called from inside User_Initialization() under user_routines.c.
Inside Init_timers we wrote the following code (to initialize and configure Timer1):
void Init_timers(void)
T1CONbits.T1CKPS0 = 1; // 1:8 Prescale (clock=1.25MHz/each tick=800ns)
T1CONbits.T1CKPS1 = 1;
TMR1H = 0x85; // sets Timer1's most significant byte
TMRIL = 0xED; // sets Timer1's least significant byte
T1CONbits.TMR1CS = 0; // Uses Internal clock
T1CONbits.T1OSCEN = 0; // Internal oscillator off
T1CONbits.RD16 = 1; // Timer1 operations done in 16-bit accesses
IPR1bits.TMR1IP = 0; // Sets interrupt as low priority
PIR1bits.TMR1IF = 0; // Overflow flag
PIE1bits.TMR1IE = 1; // Timer1 interrupt OK
INTCONbits.GIEL = 1; // Low priority interrupts OK
T1CONbits.TMR1ON = 1; // Timer1 set as on
Next you'll need to add a few things inside InterruptHandlerLow() inside user_routines_fast. This is a system function; I.E. when an interrupt is set, this function is immediately called by IFI's interrupt handler. You do not need to call it from anywhere in your code, however, you will need to include the following lines of code inside it. You'll notice this function already has several "IF" loops so all you have to do is add one more...
void InterruptHandlerLow ()
if[...]
else if (PIR1bits.TMR1IF && PIE1bits.TMR1IE) // checks to see if overflow has occured
PIR1bits.TMR1IF = 0; // resets Timer1 overflow
TMR1L = 0xED;
TMR1H = 0x85;
timer1_count++; // Timer1 counter incremented every 25ms
} // end of InterruptHandlerLow() function
Since I'm assuming you'll be working with timers inside your Autonomous code (as are we), all you'd have to do next is use "IF"s to compare the timer1_count variable. As was explained, the timer increments every 25ms, so if for example you wanted to have your robot execute a specific part of your code for 1s (=1000 ms), simple!: check if timer1_count is equivalent to 40...! For 2 seconds, 80, for 10 seconds, 400, etc etc etc...
This may not perhaps be the most accurate method but from our experiences it suited our specific needs...
Hope this helps...
any questions whatsoever, pm me...
1382 Tribotec Team - Brazil
2005 NJ Regional GM Industrial Design Award
2005 NJ Regional Website Excellence Award
2004 NJ Regional Semifinalists
Unread 06-02-2006, 12:15
FIRST-a-holic
Team Role: Student
oops...rather small yet important detail....don't forget to include the "timers.h" header file inside any .c files that work with Timers...
Unread 06-02-2006, 14:49
FRC #1657
Thx all !!!! (for the help )
21' is comming soon
Unread 09-02-2006, 20:20
10scott10 10scott10 is offline
None #1148
10scott10 is an unknown quantity at this point
thanks a ton. this is very useful. I think.
Unread 10-02-2006, 00:33
CronosPrime1 CronosPrime1 is offline
FRC #0321
CronosPrime1 is an unknown quantity at this point
Do you think you could provide more details on interrupt driven timers? Does it use up one of the six interrupts your robot has? Oh, and the 25 ms timing loop, why is it 25 ms? It seems to me that the calculation is:
2 bytes*8 bits/byte = 16 bits
largest possible 2-byte integer = 2^16 - 1 = 65535
And 800 ns*65535 =52.428 ms
You seem to get half of that...
I'm not doubting the correctness of 25 ms, I just wonder as to why it is 25 ms...
Unread 10-02-2006, 06:07
FIRST-a-holic
Team Role: Student
Rather small detail...on my posts above i made a typo mistake ... TMRIL should be TMR1L...so don't panic if you're getting any "symbol undefined" errors!! Sorry about that...
Now a few comments on the 25 ms loop...:
OK up to that point that's correct... according to the Timers White Paper found herehttp://www.ifirobotics.com/docs/time...004-jan-14.pdf) the following formula should give you what you want:
# of ticks = (time elapsed) * 10^7s / (prescale factor)
As you said above, with a 16 bit timer, counting to 65535, we can measure 6.5535 ms (considering the fact that the internal clock is 10MHz). What happens is that this duration is far too small to use for real applications, so then we used a prescale factor. In this case, we're using one of 8. This means that the timer will only increment once every eight ticks, therefore it will overflow after 52.428 ms. So that is where and how you got this value.
OK up to that point i think we can agree on. Now, we use the formula above to find the # of ticks we need to get a nice even interval of 25 ms (= 0.025 s):
# of ticks = (0.025) * 10^7s /(8)
Using the last equation we find that we need 31250 ticks to do this. Since it is easier to look at an overflow condition in the timer, we will preload the timer with a value that will cause this overflow after 31250 ticks. To get this value we subtract 31250 from the 16-bit timer’s maximum value (65535) and get 34285.
Therefore we get 65535 (timer's max value of ticks) - 31250 (number of ticks we need) = 34285 (preload value).
This is the value we will preload our timer with. In the code written above you will see 34285 represented in hexadecimal as 0x85ED. Which pretty much explains why the following lines are written the way they are:
TMR1L = 0xED; // sets Timer1's least significant byte
So, if for example you wanted to work a different time interval (50 ms, let's suppose) use the formula to find out the number of ticks you will need, subtract that value from 65535 and convert the result of that into hexadecimal. That will get you your preload value.
Hope this helps...
Unread 11-02-2006, 12:57
FRC #0321
Oh alright. I somehow overlooked the preload values.
So, how do I set a sclaing factor? In your code there seems to be a line that sets it to one yet it's 8...
Unread 11-02-2006, 18:56
Joohoo's Avatar
Joohoo Joohoo is offline
FRC #0340 (G.R.R.)
Joohoo is just really niceJoohoo is just really niceJoohoo is just really niceJoohoo is just really niceJoohoo is just really nice
Send a message via AIM to Joohoo Send a message via Yahoo to Joohoo
There is one problem with this
the timer link you have is for the 8520 controller the new controller is the 8720 and I can't get the code that was given in this thread to work has any one else???
also does any one have the code/"white papers" for the 8720 timers???
or is it the same and we just messed with it too much???
Unread 11-02-2006, 20:39
Matt Krass's Avatar
AKA: Dark Ages
FRC #0263 (Sachem Aftershock)
Check out the OpenTimer#() functions in this PDF:
http://www.kevin.org/frc/C18_libraries.pdf
It's very useful.
Matt Krass
