Re: Joystick Ports as Duplex Data Port
Yeah, we're trying to do something similar on our team. We have a palm pilot, and some software that emulates an LCD screen with it, and we're hoping to be able to use it to remotely display statistics (wheel speed, pot positions, etc.)
We just started working on it, so I'm still having trouble figuring out exactly how to output to the LCD manually and everything. Anyway... I'd probably just plug it into the Dashboard port if I plan to interface to it, then? |
Yeah, you probably need a RS232 converter cable, though. Luckily, Axim x50 series RS232 cables are readily available (but for the steep-arse price of $50).
| Updated: Serial Port Driver Code | Kevin Watson | Programming | 4 | 05-02-2005 18:39 |
| New Serial Port Driver | Kevin Watson | Programming | 16 | 09-01-2005 01:56 |
| heres the code. y this not working | omega | Programming | 16 | 31-03-2004 15:18 |
| Fried program slots? | Jeff Waegelin | Programming | 18 | 19-03-2003 18:08 |
| Limiting PWM in pbasic | archiver | 2001 | 4 | 24-06-2002 00:38 |
