Go to Post FIRST tricks you into using your brain on a regular basis. - Gabe [more]
Unread 06-02-2006, 19:33
Arkorobotics's Avatar
Arkorobotics Arkorobotics is offline
Robots!
AKA: Ara Kourchians
FRC #0589 (FalkØn)
Arkorobotics is a splendid one to beholdArkorobotics is a splendid one to beholdArkorobotics is a splendid one to beholdArkorobotics is a splendid one to beholdArkorobotics is a splendid one to beholdArkorobotics is a splendid one to beholdArkorobotics is a splendid one to behold
Send a message via AIM to Arkorobotics
CIM motor shaft extender (adapter)
I was wondering how I can extend the shaft of the CIM motor with an adapter. Since the shaft output is keyed and the I want a keyed extention too. Does anyone know any adapters? And maybe wheels that might fit on to that extention?
2007 Rockwell Automation Innovation in Control Award winners (Southern California Regional)
Crescenta Valley High School Team 589
http://www.arkorobotics.com My Blag
3.141592653589793238462643383275902884197 <- Current memorization of Pi
Callsign: N6ARA
Unread 06-02-2006, 19:45
sanddrag sanddrag is offline
On to my 16th year in FRC
FRC #0696 (Circuit Breakers)
Re: CIM motor shaft extender (adapter)
I assume you mean the small CIM. You can machine a coupler type piece with an O size hole in it, and then buy an 8mm bushing and a 2mm broach from McMaster, than put the hole and hekway in it. You probably won't be able to go any longer than an inch though. That's why I said coupler. You could probably find a metric felx coupler you could buy, but it'll have a metric output side too.
For wheels I like NPC wheels or Colson Wheels.
Unread 06-02-2006, 19:46
Engineer at Medrobotics
AKA: Dr. Joe
FRC #0088 (TJ2)
There are a number of "rigid shaft couplers" available at McMaster.com
Some come with keys, some not. I would guess that will be able to get by without a keyed coupler.
I would suggest this one: 2469K2 (8mm = .315 - close enough for this coupler to work)
Note that some of the couplers actually have different input and output shaft diameters so you can couple a .312 shaft out of the smaller/more powerful CIM with a .500 shaft. If this is what you want, try this one: 3084K31
It comes with a small bore of .235 that you will have to open up to .312, but that is nothing that 10 minutes and a lathe can't fix.
Joe J.
Team #88, TJ2
Unread 06-02-2006, 19:55
Cody Carey's Avatar
Cody Carey Cody Carey is offline
AKA: C. Carey
FRC #0306 (CRT)
Cody Carey has a reputation beyond reputeCody Carey has a reputation beyond reputeCody Carey has a reputation beyond reputeCody Carey has a reputation beyond reputeCody Carey has a reputation beyond reputeCody Carey has a reputation beyond reputeCody Carey has a reputation beyond reputeCody Carey has a reputation beyond reputeCody Carey has a reputation beyond reputeCody Carey has a reputation beyond reputeCody Carey has a reputation beyond repute
Send a message via AIM to Cody Carey Send a message via Yahoo to Cody Carey
Here is one that we made to couple the CIM shaft to a quarter inch one, Sorry if you can't read it... It's my first attempt at drawing in paint ( don't have and CAD on the comp I'm on"
P.S. Change the .156" Diameter to whatever size the small CIM shaft is
Unread 06-02-2006, 20:15
Robots!
AKA: Ara Kourchians
FRC #0589 (FalkØn)
Wow, thanks that helps, Now all that i need is wheels that have a 6" diameter that have a keyway, non pneumatics.
Callsign: N6ARA
Unread 07-02-2006, 01:39
You didn't mention what bore you want on the wheels but I've used these before and liked them. http://www.npcrobotics.com/products/...at=22&mode=gfx We put them on a 220+ lb robot with NPC battlebot motors and the delrin hubs never gave a problem.
Unread 07-02-2006, 01:49
Robots!
AKA: Ara Kourchians
FRC #0589 (FalkØn)
darn, no 5/16 shaft hole. Things kinda changed, I have been looking around all day for a wheel just like the wheel chair ones, but no ball bearing, that I can weld too (steel to steel shaft) (not aluminum).
Callsign: N6ARA
Unread 07-02-2006, 22:43
Cody Carey's Avatar
AKA: C. Carey
FRC #0306 (CRT)
Is there any specific reason for not using aluminum?
Unread 07-02-2006, 22:52
AKA: Dr. Joe
FRC #0088 (TJ2)
Consider using (2) 8mm trantorque and a tube.
You can do this:
. .....................WHEEL WHEEL
. ..........TUBE TUBE TUBE TUBE TUBE TUBE TUBE
. .........TRANTORQUE...................... TRANTORQUE .....BEARING
.MOTOR SHAFT ............... AUXILARY 8mm SHAFT AUXILARY 8mm SHAFT
Joe J.
Team #88, TJ2
Unread 08-02-2006, 06:53
Alex Burman's Avatar
Alex Burman Alex Burman is offline
∆o□
AKA: The Burmanator
FRC #0075 (Roboraiders)
Alex Burman has much to be proud ofAlex Burman has much to be proud ofAlex Burman has much to be proud ofAlex Burman has much to be proud ofAlex Burman has much to be proud ofAlex Burman has much to be proud ofAlex Burman has much to be proud ofAlex Burman has much to be proud of
Send a message via AIM to Alex Burman Send a message via MSN to Alex Burman Send a message via Yahoo to Alex Burman
You can do this:
Joe J.
OOOOHHHHHH! PRETTY COLORS!
The Burmanator
www.Roboraiders.com
http://www.myspace.com/burmanator
CIM Motor Count Tobaby817 Motors 2 27-01-2006 11:58
CIM Motors UlTiMaTeP Motors 13 10-01-2006 14:48
6 CIM Motors? psquared89 Kit & Additional Hardware 16 09-01-2006 08:47
CIM speed in reverse? colt527 Motors 41 06-12-2004 19:09
CIM vs. Drill motor duckshepherd Motors 3 15-02-2003 18:36
