Go to Post Anything is capable of happening in FIRST. - Dorienne [more]
Unread 06-02-2006, 20:36
railerobotics's Avatar
railerobotics railerobotics is offline
FRC #0935
railerobotics will become famous soon enough
Autonomous problem
I have written this for atonomous code but the the robot does not stop when the counter reaches 2000. Anyone know why?
/* Add your own autonomous code here. */
switch (Step)
case 1:
stop = 2000;
crawl = (stop - 200);
slow = (stop - 100);
Left_Count = Get_Left_Encoder_Count();
Right_Count = Get_Right_Encoder_Count();
if (Left_Count < slow)
pwm03 = 220;
if (Left_Count > slow && Left_Count < crawl)
pwm03 =200;
if (Left_Count > crawl && Left_Count < stop)
pwm03 =150;
if (Left_Count >= stop)
pwm03 =127;
printf("Left Counter %ld\r", Left_Count);
if (Right_Count < slow)
pwm04 =220;
if (Right_Count > slow && Right_Count < crawl)
pwm04 =200;
if (Left_Count > crawl && Right_Count < stop)
pwm04 =150;
if (Right_Count >= stop)
pwm04 =127;
printf("Right Counter %ld\r", Right_Count);
Unread 06-02-2006, 20:44
Jared Russell's Avatar
Taking a year (mostly) off
Re: Autonomous problem
Make sure that your encoders are counting the direction that you expect them to.
Are you changing the values of pwm03 or pwm04 anywhere else?
Unread 06-02-2006, 20:54
FRC #0935
I am not changing the pwm's anywhere else and the encoders are counting in the correct direction. Actually i am using hall effect sensors with encoder code.
Unread 06-02-2006, 21:32
Chriszuma's Avatar
Chriszuma Chriszuma is offline
Jack of all trades
AKA: Chris Hammond
FRC #0068 (Truck Town Thunder)
Chriszuma is just really niceChriszuma is just really niceChriszuma is just really niceChriszuma is just really nice
Send a message via AIM to Chriszuma
Where did the "step" variable come from? I don't see it being used anywhere in that code block.
EDIT: It would help if you posted the rest of that part of the code so we could tell more about the problem (don't worry, we aren't going to steal your code for our own use)
2006 T3 World Tour: Great Lakes - Waterloo - Palmetto - IRI
2006 Awards: Motorola Quality - RadioShack Innovation in Control
My website: http://zuma.phire.org/
Truck Town Thunder's website: http://trucktownthunder.com/
Unread 06-02-2006, 21:58
Step needs to be set to 1 somewhere, but I don't see it being done in the code fragment you posted.
Unread 07-02-2006, 00:35
Dillon Compton Dillon Compton is offline
Jack-Of-All-Trades
FRC #1391 (Metal Moose)
Dillon Compton has much to be proud ofDillon Compton has much to be proud ofDillon Compton has much to be proud ofDillon Compton has much to be proud ofDillon Compton has much to be proud ofDillon Compton has much to be proud ofDillon Compton has much to be proud ofDillon Compton has much to be proud of
Send a message via AIM to Dillon Compton
Will that work?
I dont know, I'm just asking...if the count isnt updating due to code not interfacing properly with your sensors, that could be the issue.
www.metalmoose.com
Unread 07-02-2006, 01:03
Keith Watson Keith Watson is offline
FRC #0957 (WATSON)
Keith Watson is just really niceKeith Watson is just really niceKeith Watson is just really niceKeith Watson is just really nice
Let's look at your algorithm first. I have changed your mode variables to hard coded numbers which makes the code more obvious.
        switch (Step)
            case 1:
                stop = 2000;
                crawl = 1800;  // are you sure these
                slow = 1900;   // are in the correct order?
            if (Left_Count < 1900)
                    pwm03 = 220;
            if (Left_Count > 1900 && Left_Count < 1800)
                    pwm03 =200;
            if (Left_Count > 1800 && Left_Count < 2000)
                             pwm03 =150;
            if (Left_Count >= 2000)
                    pwm03 =127;
            if (Right_Count < 1900)
                    pwm04 =220;
            if (Right_Count > 1900 && Right_Count < 1800)
                             pwm04 =200;
            if (Left_Count > 1800 && Right_Count < 2000)
                    pwm04 =150;
            if (Right_Count >= 2000)
                    pwm04 =127;
Notice that this shows problems with initialization of the crawl and slow values. Some lines are unreachable and some condition statements are executed twice. A simpler and more manageable way to use multiple if statements on the same variables is this form:
    if (count < slow) {
        // fast
    else if (count < crawl) {
        // slow
    else if (count < stop) {
        // crawl
    else {
        // stop
There is nothing in your algorithm preventing a pwm of 127 being set if the count is actually incrementing. If your printf statements are being reached and show the counts go over 2000 then the next thing to check is if setting those pwm's to 127 really does stop the motors.
Keith Watson - Professional Software Engineer
No relation to "Kevin" Watson, who created the camera tracking code.
Unread 07-02-2006, 08:36
FRC #0935
thanks for your help and step is defined at the top of user routines fast.
Autonomous Problem... JoeFryman Programming 2 19-02-2005 14:56
Future of Autonomous Mode FadyS. Programming 41 24-05-2004 19:45
problem with autonomous that has stumped all programmers so far bd02 Programming 32 10-03-2004 22:22
autonomous mode problem on field Chris_C Programming 17 26-03-2003 19:11
The problem with scouting... archiver 2001 10 23-06-2002 23:49
