Go to Post By the way, if anyone happens to find my dignity lying around anywhere, please let me know. I seem to have lost it completely. - dlavery [more]
Unread 06-02-2006, 20:54
White_Orpheus's Avatar
White_Orpheus White_Orpheus is offline
Woot for Aphex Twin!
AKA: Chris Teresi
FRC #0253 (MRT)
Team Role: Animator
White_Orpheus will become famous soon enoughWhite_Orpheus will become famous soon enough
Send a message via AIM to White_Orpheus
Exclamation Wheels Needed
We have designed our base to use 5/8" shaft, but are having trouble finding good wheels for them. We've looked at skyway, but we'd really prefer to use a solution with conveyer belt material. If any team has a suggestion on where to buy them, or 6 7" or 8" wheels lying around that they'd be willing to sell, drop me a line.
Team 253
2004 Silicon Valley AVA Winner
Unread 06-02-2006, 23:12
Nuttyman54's Avatar
Nuttyman54 Nuttyman54 is offline
Mentor, Tactician
AKA: Evan "Numbers" Morrison
FRC #5803 (Apex Robotics) and FRC #0971 (Spartan Robotics)
Nuttyman54 has a reputation beyond reputeNuttyman54 has a reputation beyond reputeNuttyman54 has a reputation beyond reputeNuttyman54 has a reputation beyond reputeNuttyman54 has a reputation beyond reputeNuttyman54 has a reputation beyond reputeNuttyman54 has a reputation beyond reputeNuttyman54 has a reputation beyond reputeNuttyman54 has a reputation beyond reputeNuttyman54 has a reputation beyond reputeNuttyman54 has a reputation beyond repute
Send a message via AIM to Nuttyman54
Re: Wheels Needed
We've taken the 6" Skyway wheels included in the kit and just screwed 1" roughtop conveyor tread on them, and glued it down. They appear to work quite well, and I imagine it would be easy to simply do that for the 8" wheels included in the kit. the only problems i forsee are that they might not be wide enough for your purposes, and i don't know if you can get 5/8" bearings for them.
Alternately, IFI sells 6" and 8" traction wheels, however they are only available in 1/2" and 3/8" bore. I imagine modification would be easier on these than on the skyways wheels though.
Unread 07-02-2006, 01:36
sanddrag sanddrag is offline
On to my 16th year in FRC
FRC #0696 (Circuit Breakers)
Re: Wheels Needed
What you are looking for is certainly not an easy find. Can you take 1/2" axle? What diameter do you need? Does it need to be a live or dead axle?
Unread 07-02-2006, 01:41
Arkorobotics's Avatar
Arkorobotics Arkorobotics is offline
Robots!
AKA: Ara Kourchians
FRC #0589 (FalkØn)
Arkorobotics is a splendid one to beholdArkorobotics is a splendid one to beholdArkorobotics is a splendid one to beholdArkorobotics is a splendid one to beholdArkorobotics is a splendid one to beholdArkorobotics is a splendid one to beholdArkorobotics is a splendid one to behold
Send a message via AIM to Arkorobotics
Re: Wheels Needed
Does anyone know any wheels that can fit to a 5/16 shaft, metal hub, and rubber on the outer ends?
2007 Rockwell Automation Innovation in Control Award winners (Southern California Regional)
Crescenta Valley High School Team 589
http://www.arkorobotics.com My Blag
3.141592653589793238462643383275902884197 <- Current memorization of Pi
Callsign: N6ARA
Unread 07-02-2006, 07:55
Der Rowan's Avatar
Der Rowan Der Rowan is offline
AKA: Capn Rowan
FRC #1531 (Lake Effect)
Der Rowan is an unknown quantity at this point
Send a message via AIM to Der Rowan
Re: Wheels Needed
One solution might be to use these:
MSC part number: 35375278
Oil impregnated bronze bushings.
they are 3/4" OD 5/8" ID and cost $.42 each.
then just set them into the hubs on the stock wheel chair wheels and put them onto your shafts.
Just make sure your shaft is something other than bronze.
Steel would be best. You might want to help them out a bit with some light oil.
Cheers
Where's my Burger's vector?
Unread 07-02-2006, 20:54
Henry_Mareck's Avatar
Henry_Mareck Henry_Mareck is offline
FRC #0418 (Purple Haze / LASA Robotics)
Team Role: Student
Henry_Mareck is a jewel in the roughHenry_Mareck is a jewel in the roughHenry_Mareck is a jewel in the rough
Send a message via AIM to Henry_Mareck
Re: Wheels Needed
you could make your wheels, thats what we did.
here is the best picure of last years wheels i could find, this year they are allmost identical.
http://www.lasarobotics.org/gallery/...05&id=050052_G
Unread 07-02-2006, 21:29
Nuttyman54's Avatar
Mentor, Tactician
Re: Wheels Needed
Yes, but that depends a lot on resources. Some teams don't have access to anything (mill or CNC) that would allow them to do that. If you've got the resources however, go for it. make them either keyed or able to fit a bearing of the size you want and you're good to go
Unread 08-02-2006, 02:43
Cory's Avatar
Cory Cory is offline
AKA: Cory McBride
Re: Wheels Needed
The wheelchair wheels that Skyway gave us years ago have 5/16" ID bearings. If you don't have any, ask another team that's been around for awhile if they can give you some.
2001-2004: Team 100
2006-Present: Team 254
Unread 08-02-2006, 03:17
Re: Wheels Needed
Over the years I've come to the realization that there are not all that many wheels with keyway (or ready for keyway) bores out there on the market. If it's something specific that you want, you'll have to make it yourself. Sometimes you'll get lucky and find something that fits what you are doing, but it is fairly common to have to manufacture a solution (at least hubs) yourself.
Unread 07-02-2006, 22:32
Ceal Craig's Avatar
Ceal Craig Ceal Craig is offline
Ceal Craig is a glorious beacon of lightCeal Craig is a glorious beacon of lightCeal Craig is a glorious beacon of lightCeal Craig is a glorious beacon of lightCeal Craig is a glorious beacon of lightCeal Craig is a glorious beacon of light
Re: Wheels Needed
We use Go-Kart wheels (Azusalite 4"), with Go-kart tires (8") and tubes made by Azuza Engineering.
Takes 5/8" shaft, light aluminum sprockets. Available at local go-kart shops; http://www.azusaeng.com/. Call them; they are very helpful.
Ceal Craig
Industry Coach, Team 1120
Getting A Bot To Turn Andrew Blair Technical Discussion 20 16-10-2005 23:49
Four Wheel, all steering, non-omniwheel, ONE power/motor source drive FizMan Technical Discussion 31 27-04-2004 12:12
Lots of Wheels and F = u x N archiver 2001 17 23-06-2002 23:37
Power Wheels parts needed: Will trade, sell soul, etc. archiver 1999 13 23-06-2002 22:27
