Go to Post I've found that being outraged on behalf of others is often a misuse of energy. - Taylor [more]
View Poll Results: did you use the kitbot?
yes 82 31.18%
no 138 52.47%
kitbot? 43 16.35%
Voters: 263. You may not vote on this poll
  #136   Spotlight this post!
Unread 27-01-2006, 15:26
Eldarion's Avatar
Eldarion Eldarion is offline
Electrical Engineer / Computer Geek
AKA: Eldarion Telcontar
no team (Teamless Orphan)
Eldarion has a reputation beyond reputeEldarion has a reputation beyond reputeEldarion has a reputation beyond reputeEldarion has a reputation beyond reputeEldarion has a reputation beyond reputeEldarion has a reputation beyond reputeEldarion has a reputation beyond reputeEldarion has a reputation beyond reputeEldarion has a reputation beyond reputeEldarion has a reputation beyond reputeEldarion has a reputation beyond repute
Send a message via AIM to Eldarion Send a message via Yahoo to Eldarion
Re: How far are you
Drivetrain...complete
Programming...90% complete
Rest of robot...top secret
CMUCam not working? Tracks sporadically? Try this instead: http://www.falconir.com!
PM me for more information if you are interested (it's open source!).
Want the FIRST Email blasts? See here: http://www.chiefdelphi.com/forums/sh...ad.php?t=50809
"The harder the conflict, the more glorious the triumph. What we obtain too cheaply, we esteem too lightly; it is dearness only that gives everything its value."
-- Thomas Paine
If it's falling apart it's a mechanical problem. If it's spewing smoke it's a electrical problem.
If it's rampaging around destroying things it's a programming problem.
"All technology is run on 'Magic Smoke' contained within the device. As everyone knows, whenever the magic smoke is released, the device ceases to function."
-- Anonymous
I currently speak: English, some German, Verilog, x86 and 8051 Assembler, C, C++, VB, VB.NET, ASP, PHP, HTML, UNIX and SQL
  #137   Spotlight this post!
Unread 27-01-2006, 16:10
BRosser314's Avatar
BRosser314 BRosser314 is offline
Post-A-Holic
AKA: Brandon Rosser
FRC #0469 (Las Guerrillas)
BRosser314 is a splendid one to beholdBRosser314 is a splendid one to beholdBRosser314 is a splendid one to beholdBRosser314 is a splendid one to beholdBRosser314 is a splendid one to beholdBRosser314 is a splendid one to beholdBRosser314 is a splendid one to behold
Send a message via AIM to BRosser314 Send a message via Yahoo to BRosser314
Talking Re: How far are you
Our design an dprototyping is done and majority of the parts are being sent to the fabricator and welder. Since we cant do much machining we are having it done for us. We can shoot make it up the ramp and have picked up balls with our prototypes. Hopefully we will get parts tonight and assemble the majority of the drivetrain and out lower construction so our programmers can have fun while we work on the ball collector hopper and shooter. Also we are working on building are cart (well actually fixing and modifing), and our control panel operators controls. My prediction is end of the fourth week at most 5th week. Then practice everyday for the remainderr of ther build season.
  #138   Spotlight this post!
Unread 27-01-2006, 16:25
Happy Birthday! Ian Curtis Ian Curtis is offline
Best Available Data
FRC #1778 (Chill Out!)
Re: How far are you
To put this in perspective...
At this time in 2004, my team was sitting around in a computer room, tossing around ideas, after physics of the frictiony ball surfaces made our original one impossible. I think this was also the week where the frame was started in construction, and CADing began.
At this time in 2005, we had a prototype claw, later abandoned for a more effiencent one, a CADed arm which was built and changed drastically in the 72 hours leading to the arrival of the FedEx guy*, and we knew what our drivetrain would look like. Our code master was hard a work trying to get the camera to work, and when he gave up, turned to encoders.
Right now, we have 5 prototypes in the shop, 3 of them fuctional, a sixth recently taken apart for testing purposes. We have the drivetrain to a T, V1 of the frame is constructed, and our electronics board is together. Our much larger than previous years coding team is hard a work, and after a rough start with the camera, is making progress in leaps and bounds. We know exactly what our shooter will look like, and have only one or two refined choices for other systems.
That doesn't mean much though, we're still behind schedule.
*Yes, there's a reason why I said 72 hours instead of 3 days.
  #139   Spotlight this post!
Unread 27-01-2006, 16:36
|20807 61|2|_'s Avatar
|20807 61|2|_ |20807 61|2|_ is offline
Builder of a Sweet Drive Train
AKA: Katie
FRC #0116 (Epsilon Delta)
Team Role: Student
|20807 61|2|_ is on a distinguished road
Send a message via AIM to |20807 61|2|_ Send a message via Yahoo to |20807 61|2|_
Re: How far are you
My subgroup (ball gathering) is really far behind. We're having major inagration issues with the ball shooting team. Other then that our team is doing pretty well.
~*Kate*~
  #140   Spotlight this post!
Unread 27-01-2006, 17:34
Ben Piecuch Ben Piecuch is offline
Bengineer
Ben Piecuch has a reputation beyond reputeBen Piecuch has a reputation beyond reputeBen Piecuch has a reputation beyond reputeBen Piecuch has a reputation beyond reputeBen Piecuch has a reputation beyond reputeBen Piecuch has a reputation beyond reputeBen Piecuch has a reputation beyond reputeBen Piecuch has a reputation beyond reputeBen Piecuch has a reputation beyond reputeBen Piecuch has a reputation beyond reputeBen Piecuch has a reputation beyond repute
Re: How far are you
In order of completion...
Drivetrain:
Gearboxes finishing tomorrow.
Frame finished tomorrow. (8020, bolts together!)
Wheels, pillow blocks, etc... finished tomorrow.
Hopefully a fully working drivetrain by end of the weekend.
Ball Pickup:
Prototyped and designed, going to manufacturing this weekend.
The full collection system should be done middle next week.
All parts in-house, or can be bought locally.
Ball Storage:
Prototyped and mostly designed.
Shooter:
The shooter itself was prototyped, and failed.
Going with another design while we'll further prototype, later.
The rest of the shooter mechanism is in design.
Much more to prototype before its final configuration.
Programming/Auto/Controls:
Err... This is ALWAYS our downfall.
Mostly, we know what we want to get feedback on, but how we're going to get that feedback is still in the air. In the meantime, we're dealing with resolution issues, and how design some of the mechanical system to work within that resolution. Most sensors in-house, or shall I say, in the KOP. Uhg...
BEN
  #141   Spotlight this post!
Unread 27-01-2006, 17:35
LightWaves1636's Avatar
LightWaves1636 LightWaves1636 is offline
is all over it.
AKA: Sarah Le
LightWaves1636 is a splendid one to beholdLightWaves1636 is a splendid one to beholdLightWaves1636 is a splendid one to beholdLightWaves1636 is a splendid one to beholdLightWaves1636 is a splendid one to beholdLightWaves1636 is a splendid one to beholdLightWaves1636 is a splendid one to behold
Send a message via AIM to LightWaves1636 Send a message via Yahoo to LightWaves1636
Unhappy Re: How far are you
Originally Posted by Rickertsen2
So we are now about half way through the build season. How far is your team?
We are running really behind this year. We have a lower frame, alot of parts on order and a bunchload of CAD drawings. We are waiting for a bunch of parts which are being made out of house because we have very limited machine tools.
Hopefully next week we will have a completed drivetrain and launcher.
robot, he he, what robot? today became stress day because we don't even have a working launcher yet.
  #142   Spotlight this post!
Unread 27-01-2006, 18:33
Spiffizzle's Avatar
Spiffizzle Spiffizzle is offline
Makes up for height in personality!
AKA: Zara Simpson
FRC #1111 (Power Hawks Robotics Team)
Spiffizzle has much to be proud ofSpiffizzle has much to be proud ofSpiffizzle has much to be proud ofSpiffizzle has much to be proud ofSpiffizzle has much to be proud ofSpiffizzle has much to be proud ofSpiffizzle has much to be proud ofSpiffizzle has much to be proud of
Send a message via AIM to Spiffizzle Send a message via Yahoo to Spiffizzle
Re: how far have you gotten on your robot?
Team 1676
20mm item extrusion chassis!
Zara Simpson
Team 1676 - The Pascack Pi-oneers - 2008
University of Maryland
- BS Materials Science & Engineering 2013
- MEd Middle School Mathematics and Science 2016
  #143   Spotlight this post!
Unread 27-01-2006, 18:57
Joie Joie is offline
Scout, Electronics
AKA: Joy
#1120 (MXR)
Team Role: Scout
Joie is an unknown quantity at this point
Send a message via AIM to Joie Send a message via Yahoo to Joie
Re: How far are you
Welllll... We have a prototype shooter, a frame kindasorta(notreally) built, a design on the way (that will hopefully be finished by this weekend), plenty of idle hands... and a freshman with a broken finger.
Anyone want to trade freshmen?
Edit. A freshman with broken fingers. Plural, people. Gosh.
Believe you me, it makes me shiver... just to hear you call my name.
  #144   Spotlight this post!
Unread 27-01-2006, 19:45
DjAlamose's Avatar
DjAlamose DjAlamose is offline
AKA: Teh Albie
FRC #0279 (Tech Fusion)
DjAlamose is a splendid one to beholdDjAlamose is a splendid one to beholdDjAlamose is a splendid one to beholdDjAlamose is a splendid one to beholdDjAlamose is a splendid one to beholdDjAlamose is a splendid one to beholdDjAlamose is a splendid one to beholdDjAlamose is a splendid one to behold
Send a message via AIM to DjAlamose
Re: How far are you
Well, 279 is about where it always is. We get the drivetrain portion of the robot done quicker than the rest and then add the game objective portion to it.
The drivetrain is coming along, I haven’t taken a look at it in a while but by the sounds of it, we should have a moving machine by tomorrow .
The Game Objective portion of the bot is halfway through the design process. The ball shooter is all designed finally! We are making parts for it tomorrow so expect another teaser. Also the ball collecting portion of the bot is coming along. We should have a final design after tomorrow’s meeting. We had some issues with how fast we wanted things to run, and then we decided that if we moved a ball 48 inches in 1sec that it would be too fast and unnecessary. But we seem to be ahead of where we usually are. Progress is progress .
Electronics/Programming
Have no idea how far they are. They decided to use last year’s code for the cam and it works better I guess. But they don’t have a list of sensors of controls yet so I don’t think there is much they can do .
CAD
Umm I didn’t know we had cad….
Scouting/Spirit
Saving that for the two weeks between build and regionals.
I think that’s it. I truly feel that we are ahead of schedule for once! Besides, who needs driver practice anyways?
WHAT TIME IS IT????? 279!!
2006 GLR Safety Award (2nd year in a row)
2005 National Xerox Creativity Award
2005 National Curie Quarter Finalist w/ 1126 and 180
2005 Buckeye Regional Champs w/ 67 and 274
2005 Buckeye Regional GM Industrial Design Award
2005 Buckeye Regional Safety Award
2005 GLR Quarter Finalist
2005 GLR Xerox Creativity Award
2005 GLR Safety Award
2004 Nationals Curie Division Finalist
2004 GLR Champs
2004 Buckeye Delphi Driving Tomorrow Award
2004 Buckeye Quarter Finalist w/ 1001 and 869
2003 GM Industrial Design Award GLR
2001 National Champs
  #145   Spotlight this post!
Unread 27-01-2006, 21:08
is all over it.
AKA: Sarah Le
Re: How far are you
he he, uh Reds Robotics doesn't allow freashmen. you have to go through a year and half of eduction in electronics and robotics. Beginning Electronics(resitor, led's, and etc.), Advance Electronics (Demulitiplexer/mulitplexer, binary code, and etc.), and finally robotics(like the bobot but cheaper, make the chassis yourself and give the robot different behaviors according the currant lab give like make it follow the wall, or drive away from the edge, and solve maxes, stuff like that.
  #146   Spotlight this post!
Unread 30-01-2006, 18:39
gondorf's Avatar
gondorf gondorf is offline
inventor/solidworks engineering spe
AKA: stephen truscott
FRC #1733 (The Polar Bots)
gondorf is a splendid one to beholdgondorf is a splendid one to beholdgondorf is a splendid one to beholdgondorf is a splendid one to beholdgondorf is a splendid one to beholdgondorf is a splendid one to beholdgondorf is a splendid one to beholdgondorf is a splendid one to behold
WE GOT OUR ROBOT TO MOVE!!! YAY!!!
unfortunately its first action was to proceed to run me over and try to flatten me.
3 weeks later and only the kitbot works???
i think we are in trouble.
  #147   Spotlight this post!
Unread 31-01-2006, 20:36
Andrew Blair's Avatar
FRC #0306 (CRT)
306 Update 1-31-06: At the halfway point, we have a driving base and a completed ball pickup+assorted essentials. We have a shooter, turret, and hopper in the works for this coming week. Programmings going to need some time this year...
-Sir Francis Bacon
-Albert Einstein
  #148   Spotlight this post!
Unread 06-02-2006, 22:21
Steve S.'s Avatar
Steve S. Steve S. is offline
2008 FIRST Volunteer =D
FRC #1591 (Greece Gladiators)
Team Role: Webmaster
Steve S. is a jewel in the roughSteve S. is a jewel in the roughSteve S. is a jewel in the roughSteve S. is a jewel in the rough
Send a message via AIM to Steve S. Send a message via MSN to Steve S. Send a message via Yahoo to Steve S.
Anyone Done Yet?
So, is any team out there done with their robot yet?
Or is there any team that hasnt built anything yet?
  #149   Spotlight this post!
Unread 06-02-2006, 22:24
Koko Ed's Avatar
Koko Ed Koko Ed is offline
Serial Volunteer
AKA: Ed Patterson
FRC #0191 (X-Cats)
Re: Anyone Done Yet?
If you haven't built anything yet you might as well pack it up and start planning for next year.
  #150   Spotlight this post!
Unread 06-02-2006, 22:41
ForgottenSalad's Avatar
ForgottenSalad ForgottenSalad is offline
In search of a home...
AKA: Michael Wessler
ForgottenSalad will become famous soon enoughForgottenSalad will become famous soon enough
Send a message via AIM to ForgottenSalad
By the definition of the word I don't beleive our robot will be 'done' until reigonals are over.
VCU NASA Regional Collmandoman Regional Competitions 83 10-03-2005 13:20
2005 FRC Team Update 14 Jeffrafa General Forum 43 01-03-2005 15:52
Manual placement of tetras Petey Rules/Strategy 7 22-02-2005 18:04
A Question on Sportsmanship Steve M General Forum 31 25-05-2004 23:52
Calling all Lawyers... ...Define "all parts" Joe Johnson General Forum 10 13-03-2002 15:12
