Go to Post Instead of "Team XXXX graciously accepts" how about just a big "yeaaaahhhhh!" ? - sanddrag [more]
Unread 07-02-2006, 00:08
Donut Donut is offline
The Arizona Mentor
AKA: Andrew
FRC #2662 (RoboKrew)
Re: Motor Limits
The call to the limit switch function can be put where ever you like it (this will be in a function called in user_routines.c or directly in there), just make sure that it is called AFTER the other code you use to set pwm values. It makes no sense to limit your motor so it can't drive further, then to command it to drive beyond it afterwards, since the last command will be the one the motor sees.
