Go to Post "We used to shut the robot up in a box and send it away from home. Now we just suffocate it." - GaryVoshol [more]
Unread 19-01-2006, 18:29
AKA: Brad
#0190 ( Gompei and the Herd)
New version of WPILib
There is a new version of WPILib that will automatically operate the compressor if connected in the background. You need to call:
InitPressureSwitch(unsigned char pressureSwitchPort, unsigned char relayPort)
Call the function only once from your Initialize function and WPILib will start checking the status of the pressure switch every 500ms and operate the compressor when needed. The compressor should be connected to a spike connected to the specified relay port.
You can pick up the new version from the WPILib web site.
Enjoy...
Brad Miller
Robotics Resource Center
Unread 22-01-2006, 20:55
AKA: Brad
Re: New version of WPILib
There is a new version of WPILib on the web site that has some changes that were just added today to help us with some motor control. So here you go:
  1. Modified Motor function to be aware of the deadband in the Victor 884 speed controllers. The Victor 884 has a built-in deadband that runs from 117-137 of PWM values sent to it. The Motor function will now take values from 0-127 and 0-(-127) and scale them to fit into the actual working range of the Victor which is 23-116 and 138-232. This means that values sent to the motors will tend to be more continuous without the discontinuity in the range. The Motor function is used by Drive and Motors so if you use these functions, the change will be seen in those functions as well.
  2. There is another function added,
    unsignd char GetPacketNumber(void)
    that returns the OI packet number. Each time a new packet is received from the master processor this number is incremented. It is only a 8 bit value so it wraps around every 256 packets, but it provides an indication of when there is new data received.
Let me know if you find any problems, particularly with the Motor change. I think this will help - it did for some motors controlled by PID loops for us. There were too many conflicting controls and was getting very confusing.
Brad Miller
Unread 23-01-2006, 15:08
dcbrown dcbrown is offline
AKA: Bud
dcbrown has much to be proud ofdcbrown has much to be proud ofdcbrown has much to be proud ofdcbrown has much to be proud ofdcbrown has much to be proud ofdcbrown has much to be proud ofdcbrown has much to be proud ofdcbrown has much to be proud ofdcbrown has much to be proud ofdcbrown has much to be proud of
Tried to download the zip file, got the following error:
"You don't have permission to access /~bamiller/WPILib/WPILib060122.zip on this server"
Unread 23-01-2006, 15:55
AKA: Brad
Sorry about that... it's fixed now.
Brad Miller
Unread 23-01-2006, 16:23
AKA: Bud
Got it. Thanks!
DCBrown
Unread 29-01-2006, 19:33
AKA: Bud
Originally Posted by BradAMiller
...Modified Motor function to be aware of the deadband in the Victor 884 speed controllers. The Victor 884 has a built-in deadband that runs from 117-137 of PWM values sent to it. The Motor function will now take values from 0-127 and 0-(-127) and scale them to fit into the actual working range of the Victor which is 23-116 and 138-232. . .
Does this change also effect SetPMW()?
Regards,
DCBrown
Unread 30-01-2006, 08:43
AKA: Brad
Regards,
DCBrown
No - the SetPWM function still sends whatever value you give to the PWMs. That way you can use the Motor(port, value) function to get the scaled version, and SetPWM(port, value) to get the unmodified output version.
Brad Miller
Unread 04-02-2006, 13:16
AKA: Brad
There is another new version of WPILib that has the following changes:
1. The capture camera packet functions now have a one second timeout. If the timeout happens, then zeros are returned for all data.
2. A bug in the servo control code was fixed where it was sending bad values when the middle digit was zero in a three digit servo value.
3. There are functions to read the backup and main battery voltages.
You can get it from my website and following the links to the software. As always please post any problems that you might encounter.
Brad Miller
Unread 04-02-2006, 17:45
Joe Hershberger Joe Hershberger is offline
National Instruments
AKA: jhersh
FRC #2468 (Appreciate)
Joe Hershberger is a name known to allJoe Hershberger is a name known to allJoe Hershberger is a name known to allJoe Hershberger is a name known to allJoe Hershberger is a name known to allJoe Hershberger is a name known to all
Brad,
I'm attempting to compile a student's program that was written and exported from EasyC. I don't have EasyC and as such I'm using MPLab and your library to build the project. Everything goes well until the link step. It then notifies me that the "Coff file format is out of date" for the objects in the lib file. It wants to rebuild the library, but I obviously don't have the source. Naturally, Microchip changed their coff format with the new version of their compiler. I'm using version 3.01 of the compiler, which comes with version 4.01 of the linker. Can you post the source to the library so it can be rebuilt? If not, what version are you using to build the library so I can downgrade?
Thanks,
-Joe
Unread 04-02-2006, 18:03
AKA: Brad
Originally Posted by Joe Hershberger
Brad,
Thanks,
-Joe
WPILib is built with the version 7.20 of MPLab and 2.40 of the compiler. The newer tools generate a different output file format, and do some (possibly) incompatible optimizations with interrupt handlers. The IFI code which is included with WPILib is also on the older tools and also prevents the use of the new compiler.
To be sure, I'd suggest switching to those versions of the tools. You can get them from the CD that was included in the kit of parts.
Brad Miller
Unread 04-02-2006, 18:11
AKA: jhersh
Brad,
Thanks for the quick response!
-Joe
Unread 05-02-2006, 12:31
TubaMorg TubaMorg is offline
Programmermechanicalelect ricalcoach
AKA: Dan
FRC #1480 (Robatos Locos)
TubaMorg has a reputation beyond reputeTubaMorg has a reputation beyond reputeTubaMorg has a reputation beyond reputeTubaMorg has a reputation beyond reputeTubaMorg has a reputation beyond reputeTubaMorg has a reputation beyond reputeTubaMorg has a reputation beyond reputeTubaMorg has a reputation beyond reputeTubaMorg has a reputation beyond reputeTubaMorg has a reputation beyond reputeTubaMorg has a reputation beyond repute
I've updated our EasyC with the new libraries. To test I added
InitPressureSwitch(1,2);
to our code and built it. It returned no errors but a warning that the above function call had no prototype. I'm not sure how to rectify this with EasyC, any thoughts?
Unread 05-02-2006, 21:55
AKA: Brad
You should also replace the UserAPI.h file to get the new functions to be available in your version of EasyC. Then if you reference the function there won't be any warnings.
There are additional functions in Builtins.h that you might also want to use. They are documented (mostly) in the PDF file.
Brad Miller
Unread 07-02-2006, 08:36
Kruuzr Kruuzr is offline
Mentor - electrical, software
AKA: Steve Cote
FRC #1922 (Ozram)
Kruuzr has a spectacular aura aboutKruuzr has a spectacular aura about
Hi Brad...
I started coding up our full application using WPILib but I ran across a big difference between the documentation and what I assume are new functions. In the userAPI.h file, there are two camera functions:
void InitCamera(unsigned char cameraInitIndex);
void CaptureTrackingData(
unsigned char *centerX,
unsigned char *centerY,
unsigned char *x1,
unsigned char *y1,
unsigned char *x2,
unsigned char *y2,
unsigned char *regionSize,
unsigned char *confidence,
unsigned char *pan,
unsigned char *tilt);
The first is obviously a changed version of InitializeCamera() and the second must be new. Could you give a quick rundown of how they work, especially the 'cameraInitIndex' parameter of InitCamera() ? And how do we set camera parameters as there is no place to set up a CameraInitializationData struct.
Thanks
Unread 07-02-2006, 10:11
AKA: Dan
Oh yeah! Compiles and runs fine now, thanks!
Welcome to the WPILib forum BradAMiller Programming 22 25-03-2008 22:44
WPILib - Library for robot programming BradAMiller Programming 7 21-06-2006 03:12
openFIRST Project Announces Pending Deadline for End of Support for Old Versions Timothy D. Ginn FIRST-related Organizations 0 11-07-2005 22:40
Flash Version of Playing Field Conor Ryan General Forum 49 30-01-2005 20:08
Does anyone know if we can use the version of Backburner from the 3DSMax trial ver? lnxpenguin4ever 3D Animation and Competition 2 26-01-2005 19:58
