Go to Post The only tool that will work to get our robot done in time will be a prayer rug. - Rick TYler [more]
Unread 07-02-2006, 10:50
dagger dagger is offline
FRC #1208
dagger is on a distinguished road
Cutting Lexan
Help! Our team just got the lexan but we are having trouble cutting it. Any suggestions? We don't have any water-jets, or laser cutters, we're just looking for simple solutions. Any suggestions are welcome!
Unread 07-02-2006, 10:52
Collin Fultz's Avatar
Collin Fultz Collin Fultz is offline
no team (IndianaFIRST)
Collin Fultz has a reputation beyond reputeCollin Fultz has a reputation beyond reputeCollin Fultz has a reputation beyond reputeCollin Fultz has a reputation beyond reputeCollin Fultz has a reputation beyond reputeCollin Fultz has a reputation beyond reputeCollin Fultz has a reputation beyond reputeCollin Fultz has a reputation beyond reputeCollin Fultz has a reputation beyond reputeCollin Fultz has a reputation beyond reputeCollin Fultz has a reputation beyond repute
Re: Cutting Lexan
Lexan (polycarbonate) is fairly easy to machine. You can use a bandsaw, table saw, hack saw, pair of tin snips (depending on it's thickness).
Plexi-glass is a different story.
Good luck!
Collin Fultz
Unread 07-02-2006, 10:54
REVving up for a new season
FRC #2848 (All-sparks)
Re: Cutting Lexan
check out this thread.
http://www.chiefdelphi.com/forums/sh...ad.php?t=41571
Greg Needel│www.robogreg.com
Co-founder REV Robotics LLC www.REVrobotics.com
2014 FRC World Champions with 254, 469, & 74
Unread 07-02-2006, 11:09
team222badbrad's Avatar
Happy Birthday! team222badbrad team222badbrad is offline
3D Printing Specialist
AKA: Bradley Rigdon
FRC #0222 (The Tigertrons)
Re: Cutting Lexan
If you have big sheets, you can use a table saw.
Tigertrons are on Facebook!
http://www.printo3d.com
16th FIRST season for me.
Unread 07-02-2006, 11:20
Electrical Engineer
Rookie Year: 1995
Re: Cutting Lexan
The aforementioned thread has a lot of info. We can perhaps help you better if you give some specific details on your situation.
What is the thickness and size of sheet that you have? Also, what operations (drilling, cutting, bending, et cetera) do you need to do?
Mike
Mike Betts
As easy as 355/113...
Unread 07-02-2006, 12:01
JohnBoucher JohnBoucher is offline
Blue Shirt
FRC #0237
JohnBoucher has a reputation beyond reputeJohnBoucher has a reputation beyond reputeJohnBoucher has a reputation beyond reputeJohnBoucher has a reputation beyond reputeJohnBoucher has a reputation beyond reputeJohnBoucher has a reputation beyond reputeJohnBoucher has a reputation beyond reputeJohnBoucher has a reputation beyond reputeJohnBoucher has a reputation beyond reputeJohnBoucher has a reputation beyond reputeJohnBoucher has a reputation beyond repute
Re: Cutting Lexan
Carbide blade if you have access to one
Unread 07-02-2006, 12:14
Elgin Clock's Avatar
FRC #0237 (Black Magic)
Re: Cutting Lexan
Leave the protective backing paper (usually with the name plastered all over it) on the material until you are finished cutting.
This reduces the risk of chips and cracks as you cut it.
Think of that paper layer as safety glass in your car. If the panel breaks, it will not turn into little airborne missles heading toward your eyes.
Unread 11-02-2006, 19:58
Eric Scheuing's Avatar
Eric Scheuing Eric Scheuing is offline
FRC #0999 (MechaRAMS)
Eric Scheuing has much to be proud ofEric Scheuing has much to be proud ofEric Scheuing has much to be proud ofEric Scheuing has much to be proud ofEric Scheuing has much to be proud ofEric Scheuing has much to be proud ofEric Scheuing has much to be proud ofEric Scheuing has much to be proud ofEric Scheuing has much to be proud of
Re: Cutting Lexan
CNC if you can. If not, everyone else has given some valuable info.
2005-2007: Bobcat Robotics 177
2015-20XX: MechaRAMS 999
Unread 11-02-2006, 20:06
Nitroxextreme's Avatar
Nitroxextreme Nitroxextreme is offline
Relation to Mrs. Steve
AKA: Jon
FRC #1626 (Falcon Robotics ; 190 (Gompei and The Herd))
Nitroxextreme is a splendid one to beholdNitroxextreme is a splendid one to beholdNitroxextreme is a splendid one to beholdNitroxextreme is a splendid one to beholdNitroxextreme is a splendid one to beholdNitroxextreme is a splendid one to behold
Send a message via AIM to Nitroxextreme
Re: Cutting Lexan
We just use jig-saw and then smooth the edges after.
"He needed a chuck norris lesson in FIRST"...."I will give him a round house kick to the face...with gracious professionalism"
Unread 13-02-2006, 21:50
JakeM's Avatar
JakeM JakeM is offline
FRC #0781 (Kinetic Knights)
JakeM is an unknown quantity at this point
Re: Cutting Lexan
If its thinner than 1/8 ", possibly 3/16", leave the backing on and skor it real good with a sharp knife. Then just bend the cut open until it snaps. Just make sure the skor is even and deep all the way allong and this only works for straight cuts and will not go around corners. It leaves the best edge of any method, and makes a cool booming noise when working with big sheets.
Unread 13-02-2006, 22:03
Simon Strauss's Avatar
Simon Strauss Simon Strauss is offline
None #1155 (Sciborgs)
Simon Strauss has a brilliant futureSimon Strauss has a brilliant futureSimon Strauss has a brilliant futureSimon Strauss has a brilliant futureSimon Strauss has a brilliant futureSimon Strauss has a brilliant futureSimon Strauss has a brilliant futureSimon Strauss has a brilliant futureSimon Strauss has a brilliant futureSimon Strauss has a brilliant futureSimon Strauss has a brilliant future
Send a message via AIM to Simon Strauss
Re: Cutting Lexan
a good ol fassion jig saw works just fine. i personaly cut out all of my team's lexan pieces last year using a 50 year old one in our shop, proof that teams who are too strapt for cash to buy a CNC can still do things properly.
NYC Chairmen's Award Winners 2007 Thank you team 2265, you were our project and we couldnt have done it without you all
New Jersey Regional Finalists thanks to teams 359 and 486 Aloha
"Beware of the Ska Robot Army!" -The Aquabats
Unread 13-02-2006, 22:10
KTorak's Avatar
KTorak KTorak is offline
Fire Rescue 47
AKA: Kyle Dersch
FRC #1023 (Bedford Express)
Team Role: Driver
KTorak has a reputation beyond reputeKTorak has a reputation beyond reputeKTorak has a reputation beyond reputeKTorak has a reputation beyond reputeKTorak has a reputation beyond reputeKTorak has a reputation beyond reputeKTorak has a reputation beyond reputeKTorak has a reputation beyond reputeKTorak has a reputation beyond reputeKTorak has a reputation beyond reputeKTorak has a reputation beyond repute
Send a message via AIM to KTorak
Re: Cutting Lexan
Table saw is what we us, but you have to be careful and keep it moving or it will start to melt it and then eat it...and that gets ugly (experience talking here). You can also round corners with a sander. We do all of our lexan cutting in the wood shop becuase of this.
Kyle D- Myspace - Facebook
2008 Bedford Express Driver & Build & Design (Team) Co-Leader
2007 Bedford Express Driver & Build & Design (Team) Leader
2006 Bedford Express Driver, Build Team Member, & Board of Directors
2005 Bedford Express Rookie, Build Team Member & Robot Operator
2008 - GLR Quarter Finalist
2007 - GLR Finalist & Boilermaker Finalist & MARC Off Season Event Winner
2006 - GLR Johnson & Johnson Sportsmanship Award & Archimedes 7th Seed Quarter Finalist
2005 - GLR Finalist & Judges Award.
2004 - GLR Semi Finalist.
2003 - GLR/DTR Quarter Finalist & GLR/NAT'L Rookie All Star.
Unread 13-02-2006, 22:14
David Guzman's Avatar
David Guzman David Guzman is online now
AKA: Dave
FRC #1251 (The Techtigers)
David Guzman has a brilliant futureDavid Guzman has a brilliant futureDavid Guzman has a brilliant futureDavid Guzman has a brilliant futureDavid Guzman has a brilliant futureDavid Guzman has a brilliant futureDavid Guzman has a brilliant futureDavid Guzman has a brilliant futureDavid Guzman has a brilliant futureDavid Guzman has a brilliant futureDavid Guzman has a brilliant future
Re: Cutting Lexan
Has anyone cut lexan on a plasma cutter before? Would it work if I put a very high seep? Would the whole sheet melt? I need an engineer or some one who knows to tell me what will likely happen to .125 lexan.
Thanks
Team 1251 The Techtigers
2010 FL Regional Winner (BIG thanks to 86 and 1612)
2009 FL Regional Finalist (BIG thanks to 79 and 744)
2008 FL Regional Winner, FL GM Industrial Design, SC GM Industrial Design
2007 FL Regional Winner, FL GM Industrial Design, Palmetto Regional Finalist, Palmetto Motorola Quality.
2006 Palmetto Regional Winner, Daimler Chrysler Team Spirit Award
2005 FL Regional Judges Award, FL Regional 3rd seeded and finalist, Palmetto Regional Xerox Creativity Award, Palmetto Regional 1st seeded and finalist
2004 UCF Regional Rookie All-star Award
Unread 13-02-2006, 22:41
Jeff Pahl's Avatar
Jeff Pahl Jeff Pahl is offline
likes to look at shiny things...
FRC #5148 (New Berlin Blitz)
Jeff Pahl has a reputation beyond reputeJeff Pahl has a reputation beyond reputeJeff Pahl has a reputation beyond reputeJeff Pahl has a reputation beyond reputeJeff Pahl has a reputation beyond reputeJeff Pahl has a reputation beyond reputeJeff Pahl has a reputation beyond reputeJeff Pahl has a reputation beyond reputeJeff Pahl has a reputation beyond reputeJeff Pahl has a reputation beyond reputeJeff Pahl has a reputation beyond repute
Re: Cutting Lexan
Thanks
Nope, the part being cut needs to be conductive for a plasma cutter.
Sorry
Unread 15-02-2006, 15:20
Charger_07 Charger_07 is offline
AKA: Escue
FRC #0932 (Circuit Chargers)
Charger_07 has a spectacular aura aboutCharger_07 has a spectacular aura about
Re: Cutting Lexan
we have used a jig saw and a band saw to cut out lexan
Chuck Norris likes to knit sweaters in his free time. And by "knit", I mean "kick", and by "sweaters", I mean "babies."
Nick: "I'm not Nick"
YMTC: Can teams start cutting metal for 2005? Natchez You Make The Call 67 07-02-2006 21:55
Cutting Pieces? robohippo FIRST Tech Challenge 10 24-12-2005 06:30
Sources for Delrin and Lexan stock sanddrag Technical Discussion 3 04-12-2005 00:25
Project Box, Lexan Tube... Used for what? Ryan Dognaux Kit & Additional Hardware 19 12-01-2005 13:06
Water Cutting in Detroit Jack Jones General Forum 0 09-03-2004 03:02
