Go to Post What's so bad about Matt? I mean, if the guy can explain PID so that even I can understand it, he can't be all that bad... - Billfred [more]
Unread 06-02-2006, 22:57
JoelP JoelP is offline
whats the P for? Pazhayampallil
FRC #1155 (Bronx Science Sciborgs)
JoelP is a jewel in the roughJoelP is a jewel in the roughJoelP is a jewel in the rough
Send a message via AIM to JoelP
Small motor used as sensor
In order to measure the RPM of the wheel used as the shooter, would it be legal to connect a small dc motor, not in the KOP, to the shaft of the wheel so that when the wheel is turned by a KOP motor, the small motor generates a current which is connected to the RC analog inputs.
I'm pretty sure using a small motor as a sensor is legal by the rules regarding to custom circuitry, but it doesn't hurt to double check.
Unread 06-02-2006, 23:08
Electrical Engineer
Rookie Year: 1995
Re: Small motor used as sensor
Joel,
It is best to check with FIRST Q&A regarding legality. I am guessing that they would not allow this device as it is a motor and would generate a signal more powerful than other sensors available.
Why not use an encoder or other sensor designed for this type of measurement?
Mike
Mike Betts
As easy as 355/113...
Unread 06-02-2006, 23:26
its a great idea.
You would want to load the motor lightly to get a more linear response, and maybe filter it some with caps to squash the commutator spikes.
I dont know if FIRST will allow a motor not in the KOP. If its being used as a tachometer.... maybe?
Unread 06-02-2006, 23:35
sciencenerd's Avatar
sciencenerd sciencenerd is offline
ooh, what does this button do?
AKA: Kyle
FRC #1318 (the IRS (Issaquah Robotics Society))
sciencenerd has much to be proud ofsciencenerd has much to be proud ofsciencenerd has much to be proud ofsciencenerd has much to be proud ofsciencenerd has much to be proud ofsciencenerd has much to be proud ofsciencenerd has much to be proud ofsciencenerd has much to be proud of
The reply to part B of this question in the Q&A would seem to imply that if it is not a kit motor, this is not legal. You could post a clarification question just to be sure, though.
Oh, maybe I shouldn't have pushed that...
Unread 07-02-2006, 07:34
Motors that are not in the kit beyond the allowed two additional small chalupas are not allowed on the robot for any reason. The rotational sensors or even using banner sensors aimed at a reflective area of the shooter wheel give a far more accurate determination of speed than a spinning motor.
Unread 07-02-2006, 09:31
We are using the small KOP Mabuchi motor as a tach for velocity control on our shooter and it works very well. The response is linear and the Mabuchi spec is a near perfect fit for our design speeds. There is additional noise from the commutator, but it's regular and we smooth that somewhat in software and set our tolerances to avoid reacting to it.
We added a diode to limit current to one direction and an adjustable pot to bring the output into the 0-5v range. You can also add caps as Ken suggested, but it's not necessary.
Unread 07-02-2006, 10:23
Engineer at Medrobotics
AKA: Dr. Joe
FRC #0088 (TJ2)
If it is used as a sensor and it is done safely, I assume it would be legal.
The question referenced above specifically says you can buy and use a tachometer and you can use a KOP motor as a tachometer. Note that it does NOT say that non-KOP motors cannot be used as a tachometer.
A tachometer is a device that provides a voltage proportional to rotational speed.
Many tachometers are just fancy motors. A motor is really just a simple tachometer.
As long as you are using the motor as a tachometer, I can't imagine that it is not legal.
Now, if you are using the motor as a motor, then that is another matter. Just as if you bought a tachometer and used it as a motor you'd be afowl of the rules.
Callin' 'em as I see 'em.
Joe J.
Team #88, TJ2
Unread 07-02-2006, 10:29
ntroup's Avatar
ntroup ntroup is offline
WildStang!
None #0111 (Wildstang)
ntroup has much to be proud ofntroup has much to be proud ofntroup has much to be proud ofntroup has much to be proud ofntroup has much to be proud ofntroup has much to be proud ofntroup has much to be proud ofntroup has much to be proud ofntroup has much to be proud ofntroup has much to be proud of
I think this Q&A question is more directly related:
Q&A - DC Tach Generators
Question:
Are DC Tach Generators allowed as sensors?
If so, can DC motors be used as tach generators solely to provide a signal source to an analog input?
Answer:
DC Tach Generators are allowed as sensors.
DC Motors are not allowed per <R44>.
I would take that to say that any DC motor (non-KOP) can not be used at all, even if for use as a tachometer.
-Nate
Unread 07-02-2006, 10:55
AKA: Dr. Joe
FRC #0088 (TJ2)
-Nate
Thanks for the quote. The quote that I was referring to did not have the R44 rule.
I was wrong.
This is a strange ruling to me because, as a practical matter,
I really don't know how to distinquish between a motor used as a sensor to turn rotational velocity into a voltage and a tachometer.
The above "generator/tachometer" is legal, but a simple non-KOP Mabuchi is not. Seems strange...
But... the rule is the rule.
Joe J.
Team #88, TJ2
Unread 07-02-2006, 11:07
Richard Wallace's Avatar
I live for the details.
FRC #3620 (Average Joes)
As Joe says, the rule is the rule.
I am concerned that this Q&A ruling could create difficulty for inspectors, since (like Joe) we will have trouble distinguishing a DC Tachometer from a DC Motor. I just hope any DC Tachometers that I see when inspecting robots have legible manufacturers labels that allow me to identify them as such, since this rule doesn't allow me assume they are tachometers based on how they are connected to the control system.
As mentioned in several earlier posts, uniform application of the rules at all events should be an important consideration.
Richard Wallace
since 2003
Unread 07-02-2006, 14:00
Matt Krass's Avatar
AKA: Dark Ages
FRC #0263 (Sachem Aftershock)
I'm missing something I think, does this mean KOP motors cannot be used as tachometers as well?
Matt Krass
Unread 07-02-2006, 14:57
AKA: Dr. Joe
FRC #0088 (TJ2)
No, on the contrary, I think one message explicitly allows the use of KOP motors as tachometers.
Question:
Are purchased DC tachometers allowed as sensors?
Is it legal to use a KOP motor as a DC tachometer rather than as a motor?
Answer:
a) Yes
b) Yes, if it is a KOP motor
While some reading the other message may (wrongly, I believe) infer that all motors may not be used a a tachometer. I think that it is in reference to using a (implied non-KOP) motor as a tachometer.
Question:
Answer:
That is how I read the rules/Q&A anyway...
Joe J.
Team #88, TJ2
Unread 07-02-2006, 15:01
The way I read it, a KOP motor can be used as a tach and DC tach can be be purchased and used as a tach. And that's all.
Unread 07-02-2006, 15:34
Matt Krass's Avatar
AKA: Dark Ages
Thanks for that, had me worried for a bit there
Matt Krass
Unread 07-02-2006, 16:26
ttedrow's Avatar
ttedrow ttedrow is offline
Herding electrons
AKA: Tim Tedrow
FRC #0281 (EnTech)
ttedrow will become famous soon enoughttedrow will become famous soon enough
Here is my take.
If there is a NON-KOP motor on the robot, the wires must be connected to an input (IFI or custom).
Sr. Design Engineer
Caterpillar Inc.
Greenville, SC
KD4EGM
FRC 281 Greenvillains
Infected with the FIRST virus in 2000
Yes, Chute Door!!!
Bannner IR sensor Measures Ball Exit Velocity Dale(294engr] Technical Discussion 4 15-02-2006 23:57
Making a Sensor Board SpaceOsc Technical Discussion 11 15-05-2004 12:46
Banner Sensor Programming Problem 2Crisis Programming 4 24-02-2004 13:40
Quick Optical Sensor Question zorro Technical Discussion 10 21-01-2003 06:39
