Go to Post I'm thinking they subscribe to the thought that "the best offense is a good defense". They are from New England, after all. - Travis Hoffman [more]
Unread 07-02-2006, 13:55
Engineer at Medrobotics
AKA: Dr. Joe
FRC #0088 (TJ2)
Re: Denso motor Lead Gear specs?
Originally Posted by billbo911
I am wondering if anyone has already determined the specifications for the Lead Gear in the Left or Right Denso Window motors. Specifically, I am looking for: pitch, angle and possibly the number of teeth.
"Why" you might ask?
If my insanity hasn't taken over, I am hoping to have the lead gear drive an encoder pot through a small hole or slot in the side of the frame of the gear assembly.
I can't answer your question directly, but I think that even your modification to allow a gear to mate with this worm or wormgear would illegal. I don't have chapter and verse in my hand, but I am pretty sure this would be an illegal modification to a motor. Motors are pretty tricky. Only things that are explicitly allowed are legal. I don't think this type of modification is specifically allowed.
As to your question. The worm and worm gear are designed to mate together and are not likely to be a easily matched by an "off the shelf" type standard pitch gear. The reason is complex but basically, they have to trade off a lot of things in a worm/wormgear design (tooth thicknesses, helix angle, center distance, etc.) Since the parts are no longer cut from standard hobs, there is no reason to stick to a standard pitch (even in the plane of the cutter -- the so called normal plane), standard pitches are almost always a last priority.
Joe J.
Team #88, TJ2
Denso Window Motor gear profile? Joshua Lynn Inventor 2 23-01-2006 23:57
pic: GEAR BOX with two speed ericwittlich Extra Discussion 6 19-07-2005 22:01
Mabuchi motor gear specs? Salik Syed Motors 1 11-01-2005 20:25
Specs on the gear of the fisher price motor archiver 2000 0 23-06-2002 23:23
Fisher price motor gear specs archiver 2000 4 23-06-2002 23:23
