Go to Post My teams robots have been good, bad and ugly BUT they were all beautiful because they were there. - JohnBoucher [more]
  #106   Spotlight this post!
Unread 04-02-2006, 19:53
BuddyB309's Avatar
BuddyB309 BuddyB309 is offline
I freaking love animating!!
AKA: Peter Casey
FRC #1625 (Winnovation)
Team Role: Animator
BuddyB309 has a reputation beyond reputeBuddyB309 has a reputation beyond reputeBuddyB309 has a reputation beyond reputeBuddyB309 has a reputation beyond reputeBuddyB309 has a reputation beyond reputeBuddyB309 has a reputation beyond reputeBuddyB309 has a reputation beyond reputeBuddyB309 has a reputation beyond reputeBuddyB309 has a reputation beyond reputeBuddyB309 has a reputation beyond reputeBuddyB309 has a reputation beyond repute
Send a message via AIM to BuddyB309
Re: 3D Animation Q/A
Originally Posted by xrabohrok
How do I stop selecting a selection class? It just won't stop!
Click the selection class tab on the main toolbar up at the top. select it to all.
A.K.A Llama
check out my latest animations Appliance Night Out, Infant Intolerable, Fishing Like a Loony Tune, VVV Roadside Assistance
Life? I have a life. It is sitting at my computer and Animating. AND DRAWING!!! WEEEEEEE!!!!
  #107   Spotlight this post!
Unread 05-02-2006, 02:03
darkstar's Avatar
darkstar darkstar is offline
Animator
FRC #0585 (Warrior Robotics)
darkstar is an unknown quantity at this point
Send a message via Yahoo to darkstar
I love 3d studio max 8 so much
  #108   Spotlight this post!
Unread 06-02-2006, 19:56
animator1's Avatar
animator1 animator1 is offline
Animator
FRC #1312 (Syntax Error)
Team Role: Animator
animator1 is an unknown quantity at this point
I was wondering if anyone knew how i could change a question mark, into an exclamation mark in 3ds max? is it using a modifier? is it even possible? if not i will just stick to my original plan.
  #109   Spotlight this post!
Unread 06-02-2006, 21:06
Tyr's Avatar
Tyr Tyr is offline
AKA: Colin Windmuller
FRC #1086 (Pirates of the Black Pearl)
Team Role: Animator
Tyr is an unknown quantity at this point
take a box, apply a bend modifier to make the '?' and then straighten it out so it forms a '!'
that's the only way I know...
Just because I can't spell it
doesn't mean it didn't happen.
  #110   Spotlight this post!
Unread 06-02-2006, 21:13
animator1's Avatar
Animator
Team Role: Animator
The box thing didn't work.But what i was thinking of doing was using it with text.
  #111   Spotlight this post!
Unread 06-02-2006, 21:40
Capt.ArD Capt.ArD is offline
Animator
FRC #0116 (Epsilon Delta)
Team Role: Animator
Capt.ArD will become famous soon enoughCapt.ArD will become famous soon enough
make a question mark. then use the morpher modifier on it, set the preset thingy as a exclaimation point. as long as the two models have the same number of vertices you will be able to morph one into the other.
  #112   Spotlight this post!
Unread 06-02-2006, 22:23
animator1's Avatar
Animator
Team Role: Animator
the preset thing? where is that?
  #113   Spotlight this post!
Unread 07-02-2006, 02:18
Damelvin's Avatar
Damelvin Damelvin is offline
Damelvin
AKA: J.D.
FRC #1147 (Herdinators)
Team Role: Animator
Damelvin is an unknown quantity at this point
Send a message via AIM to Damelvin Send a message via Yahoo to Damelvin
Pretty much finishing texturing and this is probably the most tedious part and some books I still need to take pics but this is pretty much my bookshelf. I will be adding some dvds to teh bottom self no to leave it barren.
Hear about the cannibal that passed his brother in the forest.
  #114   Spotlight this post!
Unread 07-02-2006, 03:50
MiNT MiNT is offline
AKA: oj
None #1489 (Blood Sweat and Gears)
MiNT is an unknown quantity at this point
Post Re: 3D Animation Q/A
This is actually a pretty easy thing to do with the morpher.
1) Use the text tool to make a ! and a ? - these are only for reference
2) trace one spline over the straight part of the exclamation point, and another spline over the curvy part of the question mark
3) make a box, cylinder, w/e, however thick you want your character to be. Then, make a clone of it - COPY, do NOT instance
4) convert it to editable poly. Select the top face and click 'extrude along spline' options box(under 'edit polygons')
5) pick your spline as the question mark curve, and set the segments to a high enough number that it looks smooth. Add any taper, rotation, etc that you'd like.
6) do the same for the other plane, except with the straight segment. Add taper, or whatever to stylize it abit, and make sure that the segments is equal to the number you used for the question mark. You can modify the models however you want, as long as their topology is the same.
7) select the question mark, and from the modifier list, select morpher. Go to channel parameters, click 'pick object from scene', and it'll add the exclamation pt as a target. Now you have a morph target that you can keyframe (play with the slider and watch it move back and forward between the two...) in the morph channel list.
note -morpher will only work on objects that have the same topology over the vertex indices, even if they have the same vertex count (afaik../) - because, vertex 312 moves to wherever vertex 312 might be in the target. Also its a linear move, so you may need an intermediate morph to smooth out the transition betweent the two.
For the period, just make it however and either constrain it to the question mark or edit poly modifier attach it on.
Hope this helps
  #115   Spotlight this post!
Unread 07-02-2006, 10:17
animator1's Avatar
Animator
Team Role: Animator
what do you mean by the spline?
But wow, seems like the type of thing for an advanced user. But i will try it and see what i get.
P.S-only a beginner.
  #116   Spotlight this post!
Unread 07-02-2006, 14:09
AKA: oj
Create->shapes->line
click points, right click to finish your spline. The vertex editing works mostly how you'd expect with the transform tools. Also you can select vertices, and convert them to different tangency types - bezier, bezier corner, smooth, corner - by right clicking in the viewport and selecting the type from the quad menu. I would go with bezier for this, since you can rotate and scale the tangency, and it has more control than 'smooth'.
Also you can animate the spline vertices, so you could just animate your spline vertices and set the spline to renderable. If you need more detail (ex,tapers,etc) on your text, then you can take a long, highly segmented box, do whatever you want to it, then use the pathdeform modifier on it with the animated spline.
  #117   Spotlight this post!
Unread 07-02-2006, 15:24
Animator
Team Role: Animator
nice, mint, that was exactly what i was thinking. i have been running short on time and nerves, so i never got to really explain what i meant very well.
nice bookshelf, damelvin. are the edges of the bookshelf champhered? champhering edges a TINY bit adds a bit of realism to things. scince no edge is perfectly square, champhering adds the effect of tiny dings/curves to your objects.
BTW, Orson Scott Card's Novels are awesome, saw some on your shelf. nice.
  #118   Spotlight this post!
Unread 07-02-2006, 18:53
(InsrtNameHere)'s Avatar
(InsrtNameHere) (InsrtNameHere) is offline
AKA: Jason
FRC #0011 (MORT)
Team Role: Student
(InsrtNameHere) is an unknown quantity at this point
Here, This guy needs some help with 3d Studios. If someone could help him, that would be nice.
  #119   Spotlight this post!
Unread 07-02-2006, 22:57
Damelvin's Avatar
Damelvin
AKA: J.D.
Team Role: Animator
I was wondering how you would make a light bulb look realistic and also cast light? Would a lume modifier or material work? .
Crumpled paper:
  #120   Spotlight this post!
Unread 08-02-2006, 04:03
AKA: oj
Did a quick test for a bulb, doesn't itself cast light, but the effect seems *ok*
The model itself is a mutilated box, bottom face missing, with a shell modifier on it to give it thickness.
Bulb glass material is:
Standard, blinn shading
Diffuse: Pure white
Opacity: Falloff perpindicular/parallel starting at ~.05 with a sharp curve up to 1 the right - meaning, the sides are not transparent.
Reflection: Raytrace, with a mapping the same as opacity
self illumination (when on) - Glow(lume) shader with very high yellow intensity
Specular set to 0
The thing inside is:
Standard, self illumination with Glow(lume) shader with very high intensity. Black in the diffuse channel.
Specular set to 0
i then put an omni light with inverse falloff, set the outer bound to fit the scene nicely, and turned the intensity up a bit. Then I excluded the bulb stuff from recieving light from the omni. (Off pic has a sun on) To turn it off, i just turn off the omni and switched off the self illumination channels.
Used Mental ray to render (pardon the low AA), auto levels + specular bloomed a bit in photoshop. raytrace depth was 6 for everything.
Animation Question Velaes 3D Animation and Competition 15 02-02-2005 00:11
FANATIC - Offseason Animation Competition opnickc 3D Animation and Competition 15 10-06-2004 20:54
A solution for Animation Judging for 2005 TKatsAniMentor 3D Animation and Competition 26 04-04-2004 15:29
A joke they called Regional Animation Competitions Lev 3D Animation and Competition 50 18-03-2003 21:18
How to develop your animation idea and keep your sanity too! Robby O 3D Animation and Competition 0 25-01-2002 01:25
