Re: Small motor used as sensor
The way I read it, a KOP motor can be used as a tach and DC tach can be be purchased and used as a tach. And that's all.
Thanks for that, had me worried for a bit there
Here is my take.
If there is a NON-KOP motor on the robot, the wires must be connected to an input (IFI or custom). |
I believe that the answer to the Tachometer question implied that R44 forbids all motors other that KOP motors and those specifically allowed by R44 (which reference the R43 exceptions). Joe J. |
If it is a motor, not allowed. If it is listed and branded as a DC tachometer, then it is allowed. It may sound like an odd statement, since some, if not all, DC tachs will have a motor/generator internally, but I think they want to not allow any non-KOP 'motor' from being on the robot in its purest form. -Nate |
make a nice little label that says: Kens Kustom Analog Tachometer Model 2006F Serial # 123456789 (not a motor) and put it on a DC motor and Wallah! you have a tachometer. This rule is really splitting hairs and getting lost in semantics. If a device with coils and magnets is not wired to a power source, then it is not functioning as a motor. This reminds me of a black-powder kit I got for christmas one year. When assembled it was a black-powder pistol. But you must have a pistol permit to own a pistol. According to the manual that came with the kit, if you assemble it, but never fire it, then its not a pistol and you dont need a permit but the first time you put black powder and a bullet, and fire the thing, then it instantly transforms into a pistol, and a permit is now required! Last edited by KenWittlief : 07-02-2006 at 17:00. |
#7
My problem as an inpector would be how to tell a 'real' (!?) tachometer from a functionally identical device that was sold as a motor. Like Joe, I suspect this would be difficult. Of course I agree with Ken and Joe that the rule is not technically sound; I also think it may be difficult to police. |
#8
Let's not get too worked up about this "Motors can't be Tachs" rule. I am not ready to go storm the gates and get these people to see reason.
In actual fact, motors make a pretty lousy tachometers compared to how easy an alternative is on a FIRST robot. Basically all you need to do is get a Banner Sensor or an encoder or maybe even a reed switch mounted to the thing that was going to drive the motor/tachometer and then use the RC calculate speed by either counting pulses per given time or by timing each pulse (which is a piece of cake, given Kevin Watson's many fine examples). I would argue that there is almost always a better solution to the tachometer problem than using a motor as a generator. It is an unexpected rule interpretation, but it is one I think reasonable people can live with. Joe J. |
| Bannner IR sensor Measures Ball Exit Velocity | Dale(294engr] | Technical Discussion | 4 | 15-02-2006 23:57 |
| Making a Sensor Board | SpaceOsc | Technical Discussion | 11 | 15-05-2004 12:46 |
| heres the code. y this not working | omega | Programming | 16 | 31-03-2004 15:18 |
| Banner Sensor Programming Problem | 2Crisis | Programming | 4 | 24-02-2004 13:40 |
| Quick Optical Sensor Question | zorro | Technical Discussion | 10 | 21-01-2003 06:39 |
