Go to Post Ah, this sounds like a sitcom whose pilot I should write and send to NBC - "Life With Lavery". There's a lot of eating, several practical jokes, and lots of bad hair. - Amanda Morrison [more]
Unread 07-02-2006, 16:32
ntroup's Avatar
ntroup ntroup is offline
WildStang!
None #0111 (Wildstang)
ntroup has much to be proud ofntroup has much to be proud ofntroup has much to be proud ofntroup has much to be proud ofntroup has much to be proud ofntroup has much to be proud ofntroup has much to be proud ofntroup has much to be proud ofntroup has much to be proud ofntroup has much to be proud of
Re: Small motor used as sensor
Originally Posted by ttedrow
If there is a NON-KOP motor on the robot, the wires must be connected to an input (IFI or custom).
I have to disagree. With what I have read on the Q&As, and with the discussion here, I think that Joe is right on when saying that NO non-KOP motor may be used at all.
If it is a motor, not allowed. If it is listed and branded as a DC tachometer, then it is allowed.
It may sound like an odd statement, since some, if not all, DC tachs will have a motor/generator internally, but I think they want to not allow any non-KOP 'motor' from being on the robot in its purest form.
-Nate
Bannner IR sensor Measures Ball Exit Velocity Dale(294engr] Technical Discussion 4 15-02-2006 23:57
Making a Sensor Board SpaceOsc Technical Discussion 11 15-05-2004 12:46
Banner Sensor Programming Problem 2Crisis Programming 4 24-02-2004 13:40
Quick Optical Sensor Question zorro Technical Discussion 10 21-01-2003 06:39
