Go to Post bedtime? there's no bedtime while chief delphi is up and running! - Alex Cormier [more]
Unread 07-02-2006, 16:31
Generator of Entropy
FRC #2973 (The Mad Rockers)
Reading Servo Data?
Has anyone put a meter across the signal wires on a HiTech Servo, turned the shaft manually, and seen an output that could be used for feedback in lieu of a pot?
<Gee, why would anyone want to do that?>
Unread 07-02-2006, 16:39
Matt Krass's Avatar
AKA: Dark Ages
FRC #0263 (Sachem Aftershock)
Re: Reading Servo Data?
If I understand servos correctly, the feedback potentiometer is connected to a control board inside the circuit, the 3 wires are simply power and signal to command the servo, while you may receive some back EMF from turning it, when idle you won't get any information from it, and it could be bad for the servo.
If any (or all) of that is incorrect, somebody please correct me, but I'm pretty sure about this one.
Matt Krass
Unread 07-02-2006, 16:40
I honestly cannot imagine any hobby-type servo being able to do what you're asking of it.
Unread 07-02-2006, 16:47
Yeah, that's kinda what I gathered from searching threads but thought I'd ask anyway. We'll probably go ahead and have a couple students do the experiment tonight - if we get any results worth mentioning I'll post here.
Unread 07-02-2006, 16:50
You might be able to take a servo apart, and use its internal pot as a feedback sensor
if you could pull it off you would have a nice mechanical package, with a splined shaft and all those neat little arms and levers that screw to the shaft.
Interesting idea! I think you would have to take the electronics out, and connect the 3 pot wires to the 3 pwm pins.
If you could get the servo motor and gears out of the thing then it would be easier to turn.
Reading binary data from a file and writing it in VB complete Programming 1 02-01-2006 21:21
Servo behavior question / advanced servo/PIC programming question DanL Electrical 12 18-10-2005 18:33
TTL port to a serial port on a demo board ImmortalAres Programming 16 09-07-2005 23:44
Limiting PWM in pbasic archiver 2001 4 24-06-2002 00:38
