Go to Post FIRST- its a pandemic in all our schools. - Akash Rastogi [more]
Unread 07-02-2006, 17:25
Engineer at Medrobotics
AKA: Dr. Joe
FRC #0088 (TJ2)
Re: Small motor used as sensor
Let's not get too worked up about this "Motors can't be Tachs" rule. I am not ready to go storm the gates and get these people to see reason.
In actual fact, motors make a pretty lousy tachometers compared to how easy an alternative is on a FIRST robot. Basically all you need to do is get a Banner Sensor or an encoder or maybe even a reed switch mounted to the thing that was going to drive the motor/tachometer and then use the RC calculate speed by either counting pulses per given time or by timing each pulse (which is a piece of cake, given Kevin Watson's many fine examples).
I would argue that there is almost always a better solution to the tachometer problem than using a motor as a generator.
It is an unexpected rule interpretation, but it is one I think reasonable people can live with.
Joe J.
Team #88, TJ2
Bannner IR sensor Measures Ball Exit Velocity Dale(294engr] Technical Discussion 4 15-02-2006 23:57
Making a Sensor Board SpaceOsc Technical Discussion 11 15-05-2004 12:46
Banner Sensor Programming Problem 2Crisis Programming 4 24-02-2004 13:40
Quick Optical Sensor Question zorro Technical Discussion 10 21-01-2003 06:39
