Go to Post I can't wait until Kick Off! Simultaneously across the country there will be one loud cry of "Doh!", followed by the sound of smacking foreheads with the palm of a hand, then "Why didn't I figure that out? I saw the hint". Indeed, hind sight is 20/20. - billbo911 [more]
Unread 07-02-2006, 16:51
Unholy Unholy is offline
electrical / makeshift programmer
AKA: Daniel
FRC #1402
Unholy is an unknown quantity at this point
Send a message via AIM to Unholy
Potentiometer help
Greetings everybody,
I'm Dan from 1402, and I have sort of an issue in my hands among with my programming group. To begin with, we're not very C-savvy, so just bear with us. We want to include a potentiometer in our program, but we're not exactly sure how to go about it. Last year, I was thrown into programming during the season, so I never really quite got the potentiometer part. We are not exactly sure where to add the basic potentiometer data (definition, etc). Also, we plan to have set values, so we are wondering where could we define such values. We appreciate any help we can get.
Thanks in advance,
-Dan, Yuriy, and Chris
Unread 07-02-2006, 17:00
kaszeta's Avatar
kaszeta kaszeta is offline
FRC #0095 (Grasshoppers)
kaszeta is a glorious beacon of lightkaszeta is a glorious beacon of lightkaszeta is a glorious beacon of lightkaszeta is a glorious beacon of lightkaszeta is a glorious beacon of light
Re: Potentiometer help
Thanks in advance,
Pots are easy. Check out the FIRST Guidelines, Tips, and Good Practices document. But basically, the pot gives a 0-5 V signal, which is read by the RC using Get_Analog_Value() (unless you're using Kevin Watson's ADC.c/h), yielding a 10 bit value (0-1023).
Unread 07-02-2006, 17:34
AKA: Daniel
FRC #1402
So, would it be ok to put that command under UserRoutines.c, or where would you suggest to put that command?
Unread 07-02-2006, 17:40
kaszeta's Avatar
Wherever you're trying to use the value (user_routines.c is the most obvious place). What are you trying to do with the pot?
Unread 07-02-2006, 17:48
AKA: Daniel
FRC #1402
We're trying to have set values to fire at a given angle. We're using the pot to give us reference. Also, we are planning to use it during autonomous mode. Personally, I am a bit confused since last year I had a robot.c/.h divison. By the way, thanks for the help ^_^
coding a potentiometer incognito_NICK Programming 5 14-02-2005 15:56
Potentiometer Trouble ?? VideoMan053 Programming 18 28-01-2005 14:10
Potentiometer Joshua May Technical Discussion 8 22-05-2004 19:51
Potentiometer with BS2 sanddrag Programming 7 13-05-2004 19:21
Potentiometer Problem Greg General Forum 1 15-02-2003 18:10
