Go to Post A wet noodle of a chassis won't matter how much drop you have. - Andrew Schreiber [more]
Unread 07-02-2006, 17:48
Unholy Unholy is offline
electrical / makeshift programmer
AKA: Daniel
FRC #1402
Unholy is an unknown quantity at this point
Send a message via AIM to Unholy
Re: Potentiometer help
Originally Posted by kaszeta
Wherever you're trying to use the value (user_routines.c is the most obvious place). What are you trying to do with the pot?
We're trying to have set values to fire at a given angle. We're using the pot to give us reference. Also, we are planning to use it during autonomous mode. Personally, I am a bit confused since last year I had a robot.c/.h divison. By the way, thanks for the help ^_^
coding a potentiometer incognito_NICK Programming 5 14-02-2005 15:56
Potentiometer Trouble ?? VideoMan053 Programming 18 28-01-2005 14:10
Potentiometer Joshua May Technical Discussion 8 22-05-2004 19:51
Potentiometer with BS2 sanddrag Programming 7 13-05-2004 19:21
Potentiometer Problem Greg General Forum 1 15-02-2003 18:10
