Go to Post Nobody wins a Regional on Thursday. - Bill Moore [more]
Unread 07-02-2006, 20:06
RedOctober RedOctober is offline
FRC #0291
RedOctober will become famous soon enoughRedOctober will become famous soon enough
Programming Help - Autonomous
Hey guys, I need help with programming and the autonomous mode. What is the "_SIMULATOR" used for? I noticed that its an #indef but where is it actually defined at to make this condition TRUE? Because I noticed that it needs to be TRUE in order to make the autonomous mode execute without setting everything to TRUE manually. Thanks for any help.
Unread 07-02-2006, 21:20
Jared Russell's Avatar
Taking a year (mostly) off
Re: Programming Help - Autonomous
_SIMULATOR is for simulating the RC in MPLab - not what you want.
To run autonomous, you need to enable the autonomous_mode byte.
Check the Programming forum.
Unread 10-02-2006, 13:08
charrisTTI charrisTTI is offline
Ramblin' Wreck
AKA: Charles Harris
FRC #0623
charrisTTI has a spectacular aura aboutcharrisTTI has a spectacular aura about
Send a message via AIM to charrisTTI
Build a switch box for operator interface (see IFI robotics for pin out) use the enable/disable input and the autonomous input.
White Paper Discuss: C Programming and Autonomous Modes for Newbies cbolin Extra Discussion 3 09-01-2008 19:32
Autonomous Programming Guide cbolin Programming 2 16-12-2004 15:13
Autonomous Programming Competition Signup List SilverStar Programming 36 13-05-2004 15:09
How do you do the autonomous programming? Ryan Collings Programming 11 07-02-2003 19:38
