Go to Post Celebrate your failures as well as your successes. - Taylor [more]
Unread 07-02-2006, 21:46
Re: EMERGENCY HELP NEEDED ON MAIN BOARD AND CAMERA
Free-turning servos can indicate no power getting from the backup battery to the pwm port pins, but they are also a symptom of the RC being disabled. That'll happen automatically if there's no communication with the OI. Make sure you have either a red tether cable between the OI and the RC or a pair of functioning radio modems connected. If you're using a competition port dongle, make sure it's not disabling the robot (the yellow light on the OI should be off).
Camera Servo Problems pi_guy578 Programming 2 28-01-2006 13:17
