Go to Post School cannot teach everything you need to know so they teach you how to learn. - kstl99 [more]
Unread 07-02-2006, 22:14
Mike's Avatar
Mike Mike is offline
has common ground with Matt Krass
AKA: Mike Sorrenti
FRC #0237 (Sie-H2O-Bots (See-Hoe-Bots) [T.R.I.B.E.])
Mike has a reputation beyond reputeMike has a reputation beyond reputeMike has a reputation beyond reputeMike has a reputation beyond reputeMike has a reputation beyond reputeMike has a reputation beyond reputeMike has a reputation beyond reputeMike has a reputation beyond reputeMike has a reputation beyond reputeMike has a reputation beyond reputeMike has a reputation beyond repute
Possible danger using default camera code
I saw this a while ago and didn't think too much of it, but I was just talking to Nehalita and turns out it happened to her. So a warning to all programmers:
The default pan/tilt pwm outputs as defined in tracking.h are pwm01 and pwm02. Now the electronics team is usually composed of a well organized bunch, people that like to go in order. The mechanical team usually starts with building a drive train and then ships it off to the electronics team to get it driving around. The programming team then finally gets the robot. What do most people do when they get the robot? Download the raw, unmodified code.
This seems like a smart idea, but it turns out that the electrical team (in their neat and orderly fashion) decided to put the drive motors on pwm01 and pwm02 (left and right). So what do we get? An out of control robot that thinks its a servo!
So, for those of you that skipped all that:
Make sure that the camera pan/tilt values are not the same as your drive motor values.
-Mike
http://www.mikesorrenti.com/
Unread 07-02-2006, 22:18
Goldeye Goldeye is offline
AKA: Josh Hecht
FRC #0694 (Stuypulse)
Goldeye has a spectacular aura aboutGoldeye has a spectacular aura aboutGoldeye has a spectacular aura about
Send a message via AIM to Goldeye
Re: Possible danger using default camera code
Happened to us today. We keep our hands on the disable switch
Team 694
2005 Championship - Galileo Semifinalist
2005 New York - Regional Chairmans Award
2005 New York - Semifinalist (Thanks 1257,1340)
Unread 07-02-2006, 22:29
X-Istence X-Istence is offline
Melt the RC controller!
AKA: Bert JW Regeer
X-Istence will become famous soon enoughX-Istence will become famous soon enough
Send a message via AIM to X-Istence Send a message via MSN to X-Istence
Programming team is the one that get's to decide what PWM's are used for what. That means we get the robot from the electronics crew with PWM cables neatly tagged ready for us to plug them in. Makes life easy!
My Blog!
Unread 07-02-2006, 23:28
Idaman323 Idaman323 is offline
In Theory, Our Robot Would Own.
FRC #1706
Team Role: Driver
Idaman323 is an unknown quantity at this point
Well, with such a small team... I am the progrmmer/electrical/driving/whatever else I can do, I get to watch out for that kind of stuff. I noticed that the first time I looked at it and made sure it didn't happen when we got our bot driving.
TEAM 1706
2007 Judges Award, St. Louis (For our amazing ability to have bad luck)
2005 Rookie Inspiration Award, St. Louis
Out of the Box Camera Code russell Programming 9 21-10-2009 05:28
default camera code edit Windward Programming 8 25-01-2006 18:33
problems using gyro/adc code with camera default code tanstaafl Programming 7 22-01-2006 23:09
Getting the Camera and Default Code to Work nukem Programming 5 18-01-2006 11:48
Team THRUST - Kevin's Code and Camera Code Combine Chris_Elston Programming 3 31-01-2005 22:28
