Go to Post This just goes to prove there was life before FIRST (but it wasn't as much fun!) - Ken Loyd [more]
Unread 07-02-2006, 20:54
team1852's Avatar
team1852 team1852 is offline
FRC #1852 (Team Amore)
team1852 has a spectacular aura aboutteam1852 has a spectacular aura aboutteam1852 has a spectacular aura about
Help With Layout
Our team was wondering if we had to use both fuse panels on the electrical wiring or can we just use one if thats enough. Thanks for your time and help.
-Team 1852
Unread 07-02-2006, 22:17
CraigHickman
Posts: n/a
Re: Help With Layout
It depends on what amp breakers you're going to use. You need a different panel to use a 40amp breaker, and then one for 30 and below.
Unread 07-02-2006, 22:38
MudThumper's Avatar
MudThumper MudThumper is offline
Mikey
AKA: Mike
FRC #0435 (Robodogs)
MudThumper is an unknown quantity at this point
Send a message via AIM to MudThumper
or u can use a breaker panel like last years that had everything intergraded in to one panel
hum.....
Unread 08-02-2006, 12:22
Schneidie's Avatar
Schneidie Schneidie is offline
AKA: Marc Schneider
FRC #0177 (The Bobcats)
Schneidie will become famous soon enoughSchneidie will become famous soon enough
-Team 1852
I'm not sure on the rules for a 40 A and 30 and below combuination board, nut you do need to use the seperate ones if yo uplan on using the kit board.
Schneidie
Unread 08-02-2006, 12:37
If you have last year's board, you are allowed to use it as long as you account for in in cost.
Unread 08-02-2006, 14:23
nirty's Avatar
nirty nirty is offline
FRC #1574
nirty is an unknown quantity at this point
i think it OK to use one for the 40 amp and second for the 30 and below
so you use only to of the kit board
Unread 08-02-2006, 18:31
Emily Pease's Avatar
Emily Pease Emily Pease is offline
Nobody puts Baby in the corner.
FRC #0125 (NU-TRONS)
Emily Pease is a name known to allEmily Pease is a name known to allEmily Pease is a name known to allEmily Pease is a name known to allEmily Pease is a name known to allEmily Pease is a name known to all
Send a message via AIM to Emily Pease
Team 1852:
The gold panel given in the kit is for 40 Amp fuses (needed for CIMs, for example) and the other panel in the kit is for 20 or 30 amp fuses. If you have the breaker panel shown here, you don't need to use either of the panels given in the kit, because you can fit the 40A fuses and the 30/20 fuses, too!
Unread 08-02-2006, 19:26
team1852's Avatar
Thanks
Team 1852
Basic Robot Layout gsorozco Technical Discussion 8 12-02-2006 19:15
flat sheet layout of helix? Bob Holmstrom Inventor 12 09-02-2006 07:21
[OCCRA]: Looking for the field layout Alex Golec OCCRA 3 28-09-2004 21:35
Championship layout Marc P. Championship Event 23 04-04-2003 21:49
