Go to Post I don't think that FIRST is going to get better with a top down solution alone, it is going to take a grass roots effort to strengthen teams. That starts by teams getting off their "islands", self imposed or otherwise. - Fe_Will [more]
Unread 07-02-2006, 23:37
RoboMadi's Avatar
RoboMadi RoboMadi is offline
3 Fs..... Fun Friends FIRST!!
AKA: Imad
FRC #0612
RoboMadi has a brilliant futureRoboMadi has a brilliant futureRoboMadi has a brilliant futureRoboMadi has a brilliant futureRoboMadi has a brilliant futureRoboMadi has a brilliant futureRoboMadi has a brilliant futureRoboMadi has a brilliant futureRoboMadi has a brilliant futureRoboMadi has a brilliant futureRoboMadi has a brilliant future
pic: Team 612 Drive System
Unread 07-02-2006, 23:38
MudThumper's Avatar
MudThumper MudThumper is offline
Mikey
AKA: Mike
FRC #0435 (Robodogs)
MudThumper is an unknown quantity at this point
Send a message via AIM to MudThumper
Re: pic: Team 612 Drive System
so wait what is going on with the two batteries? other than that its looks like a pretty beefy drive system
hum.....
Unread 07-02-2006, 23:58
RoboMadi's Avatar
AKA: Imad
FRC #0612
For the drivers to practice, we needed to make it stable; so we mounted two batteries to keep it balanced.
Its a simple and easy drive system. This year we decided not to waste a lot of time on working on complicated design. We rather decided to spend more time on the Body part, because it was sort of complicated. Pictures of the body will be up soon.
Unread 08-02-2006, 01:54
Darkswordsmith Darkswordsmith is offline
Allen's Shiznit
FRC #1678 (En-Gen)
Team Role: Electrical
Darkswordsmith is on a distinguished road
Send a message via AIM to Darkswordsmith
nice drive. I shoould've used that vertical, two-sided electronic board design...our wires were kinda crowded with limited space on the chassis
Unread 08-02-2006, 07:43
REVving up for a new season
FRC #2848 (All-sparks)
just a question. Have you had problems with your chain slipping? The back wheels look like they only have about 70 degrees of chain contact with the sprocket. If you haven't i would try testing your bot under load (pushing against a wall or another heavy object and see if they skip. From experience i always aim for a full 180 degrees but never less then 90.
Greg Needel│www.robogreg.com
Co-founder REV Robotics LLC www.REVrobotics.com
2014 FRC World Champions with 254, 469, & 74
Unread 08-02-2006, 09:17
ForgottenSalad's Avatar
ForgottenSalad ForgottenSalad is offline
In search of a home...
AKA: Michael Wessler
ForgottenSalad will become famous soon enoughForgottenSalad will become famous soon enough
Send a message via AIM to ForgottenSalad
I hope you've got the vertical board and all wires tied down solid... Any bit of movement and it will turn into a mess after just a few matches. Case in point? Last year's robot. (after about 10 matches across two comps)
But you also seem to have wired it cleaner, so you might not risk the same problem.
Unread 08-02-2006, 15:16
in between teams
AKA: Luke Van Oort
Looks like they've go a lot of cables coming out/in of the RC, and it seems that that ATC panel is full of breakers, if not wires. Interesting.
Team 1219: 2009 - Mentor
Unread 08-02-2006, 16:38
RoboMadi's Avatar
AKA: Imad
FRC #0612
Actually it works pretty good. We tested it on the ramp, and it goes up pretty easily. We came up with ths triangle chain design. The back wheel sprocekt is firmly in contact with the chain just form the bottom. So it don't allow the chain to slide. The top part is in contact too, but its just there.
Also our electrical board is mounted temp. It will eventually be mounted rigth behind our shooter. The shooter is goin to go right on top on our wheels. i'll post the pics soon.
Free Kittens/Tetra Grabber Mr. Lim Rumor Mill 30 08-04-2005 11:36
If you could change one thing.... Koko Ed General Forum 48 31-03-2005 19:23
pic: Team 836 2005 Drive Plate Bcahn836 Robot Showcase 11 09-02-2005 10:13
pic: Possible Team 114 Drive Component James114 Extra Discussion 14 15-01-2005 12:27
The 2003 Index of team's post about their robot... Ken Leung Robot Showcase 4 28-02-2003 00:18
