Go to Post You can learn a lot from making mistakes - even more from fixing them. - DarrinMunter [more]
Unread 08-02-2006, 00:13
crossedheart's Avatar
crossedheart crossedheart is offline
Resident Female
AKA: Katherine
FRC #0753 (High Desert Droids)
crossedheart is an unknown quantity at this point
Send a message via AIM to crossedheart Send a message via MSN to crossedheart Send a message via Yahoo to crossedheart
Which Serial Port?
I'm sorry to be asking a dumb question, I hate doing that on forums. I've been trying to look around for the answer and I'm really tired. I'm trying to integrate the serial ports, eeprom, and camera code into the default code. With that said, I start reading my little readme's and I get to this:
5) Init_Serial_Port_One() and/or Init_Serial_Port_Two()
must be called from the User_Initialization() function
located in the user_routines.c source file.
So how do I tell which port I'm using? Which is which? The readme's are giving me a headache. I don't know what exactly I need to do with the serial port code just for the sole purpose of making the camera code work.
If someone wouldn't mind giving me an AIM or something I'd love to just sit down with someone experienced and get some better understanding. I know my C++ pretty well, I guess it's just the application for robotics that I need some work on.
Thank you all!
Unread 08-02-2006, 01:18
Goldeye Goldeye is offline
AKA: Josh Hecht
FRC #0694 (Stuypulse)
Goldeye has a spectacular aura aboutGoldeye has a spectacular aura aboutGoldeye has a spectacular aura about
Send a message via AIM to Goldeye
Re: Which Serial Port?
Call both, if I recall.
Team 694
2005 Championship - Galileo Semifinalist
2005 New York - Regional Chairmans Award
2005 New York - Semifinalist (Thanks 1257,1340)
Unread 08-02-2006, 01:23
Matt Krass's Avatar
AKA: Dark Ages
FRC #0263 (Sachem Aftershock)
Serial Port One I believe is the RS-232 Program Port, while Two is the TTL serial port on the side (four pin header) used mostly for the camera. For communication with a computer the first is the simplest. Of course I could have them reversed but now you know what to look for, so hopefully this helped.
Matt Krass
Unread 08-02-2006, 01:38
billbo911's Avatar
AKA: That's "Mr. Bill"
FRC #2073 (EagleForce)
Thank you all!
I am not a programmer on the level of Kevin W., but I have read through his code I believe I have a decent grasp on what he is doing.
To make things easier when trying to integrate these pieces together, try just unzipping Kevin's "Bells and Whistles" version and build off of that. It contains his Serial port driver to access the ports and is commented quite well. Make sure to read the .h files as well. It also contains the eeprom support, but I don't think it is the full blown eeprom stuff in his separate file set.
The question about which port is which is clearly documented in his files, I believe the .h files explain it the best.
Once you get the basic part working, just un-comment the sections you need. Make note, once you start un-commenting, watch out for the PWM01 and PWM02 mapping. Kevin uses them for the camera servos, the default code wants to use them for joysticks. I suggest you use them for the camera, but modifying the code is easy.
Good Luck
We'll see you at Davis/Sacramento Regional
Unread 08-02-2006, 11:35
Serial port 1 is the Program port on the RC
Serial port 2 is the TTL port on the RC
CMUcam2 Serial Port Diagnostics Kevin Watson Programming 13 18-02-2006 15:05
Scripting Setup and the Camera + Serial Port Drivers CJO Programming 22 11-01-2006 17:42
TTL port to a serial port on a demo board ImmortalAres Programming 16 09-07-2005 23:44
Updated: Serial Port Driver Code Kevin Watson Programming 4 05-02-2005 18:39
New Serial Port Driver Kevin Watson Programming 16 09-01-2005 01:56
