pic: Team 612 Drive System
Re: pic: Team 612 Drive System
so wait what is going on with the two batteries? other than that its looks like a pretty beefy drive system
For the drivers to practice, we needed to make it stable; so we mounted two batteries to keep it balanced.
Its a simple and easy drive system. This year we decided not to waste a lot of time on working on complicated design. We rather decided to spend more time on the Body part, because it was sort of complicated. Pictures of the body will be up soon. ![]() |
nice drive. I shoould've used that vertical, two-sided electronic board design...our wires were kinda crowded with limited space on the chassis
just a question. Have you had problems with your chain slipping? The back wheels look like they only have about 70 degrees of chain contact with the sprocket. If you haven't i would try testing your bot under load (pushing against a wall or another heavy object and see if they skip. From experience i always aim for a full 180 degrees but never less then 90. |
I hope you've got the vertical board and all wires tied down solid... Any bit of movement and it will turn into a mess after just a few matches. Case in point? Last year's robot. (after about 10 matches across two comps)
![]() But you also seem to have wired it cleaner, so you might not risk the same problem. |
#7
Looks like they've go a lot of cables coming out/in of the RC, and it seems that that ATC panel is full of breakers, if not wires. Interesting.
#8
Also our electrical board is mounted temp. It will eventually be mounted rigth behind our shooter. The shooter is goin to go right on top on our wheels. i'll post the pics soon. |
| Free Kittens/Tetra Grabber | Mr. Lim | Rumor Mill | 30 | 08-04-2005 11:36 |
| If you could change one thing.... | Koko Ed | General Forum | 48 | 31-03-2005 19:23 |
| pic: Team 836 2005 Drive Plate | Bcahn836 | Robot Showcase | 11 | 09-02-2005 10:13 |
| pic: Possible Team 114 Drive Component | James114 | Extra Discussion | 14 | 15-01-2005 12:27 |
| The 2003 Index of team's post about their robot... | Ken Leung | Robot Showcase | 4 | 28-02-2003 00:18 |
