Re: Help With Layout
i think it OK to use one for the 40 amp and second for the 30 and below
so you use only to of the kit board |
Team 1852:
The gold panel given in the kit is for 40 Amp fuses (needed for CIMs, for example) and the other panel in the kit is for 20 or 30 amp fuses. If you have the breaker panel shown here, you don't need to use either of the panels given in the kit, because you can fit the 40A fuses and the 30/20 fuses, too! |
Thanks
Team 1852 |
| Basic Robot Layout | gsorozco | Technical Discussion | 8 | 12-02-2006 19:15 |
| flat sheet layout of helix? | Bob Holmstrom | Inventor | 12 | 09-02-2006 07:21 |
| [OCCRA]: Looking for the field layout | Alex Golec | OCCRA | 3 | 28-09-2004 21:35 |
| Championship layout | Marc P. | Championship Event | 23 | 04-04-2003 21:49 |
