Go to Post "It's not a flashlight! it's an arduino with a really strong status LED!" - Leav [more]
Unread 07-02-2006, 18:09
Happy Birthday! BrittanyV BrittanyV is offline
FRC #1025 (Impi Robotics)
BrittanyV is on a distinguished road
Which Terminals?
Hey!
I know that last year, we had to have specific terminals on the batteries, fuse block, and on/off switch (circuit breaker). They were the copper ones with the screws on them. Does anyone know if we still have to use these this year? (we haven't found anything in the manual, but we want to be sure. It was really hectic trying to find them at the competitions.) If you could post, it would be much appreciated.
I have a higher and grander standard of principle than George Washington. He could not lie; I can, but I won't. -Mark Twain
Unread 07-02-2006, 18:16
Re: Which Terminals?
Brittany,
The rules (per the robot manual) have been relaxed a little this year. You may use SLU 35 terminals ( a smaller version of last year's terminal) or you may use a suitable crimp terminal if you wish. As always, insulate all electrical connections on the robot, particularly the battery and main power distro and main circuit breaker.
<R54> The EX18-12 Battery, the Main 120 Amp Circuit Breaker, and the Circuit Breaker distribution panels
must be connected as shown in the 2006 ( or optionally) as in the 2005 diagrams shown below. The EX18-12
Battery must use the Anderson Connector. The connector must be attached with either the copper SLU-35
lugs provided in the Terminal Supply Bag or appropriate crimp-on lug connectors. The Battery terminals and
the connecting lugs must be insulated with shrink tubing and/or electrical tape
Unread 07-02-2006, 20:19
chrisinmd's Avatar
chrisinmd chrisinmd is offline
AKA: Chris Pickett
FRC #0888 (Robotiators)
chrisinmd is a jewel in the roughchrisinmd is a jewel in the roughchrisinmd is a jewel in the rough
Send a message via AIM to chrisinmd
Originally Posted by Al Skierkiewicz
Brittany,
Thanks for reassuring me, Al.
Last year they made us change all of our #6 crimp connectors to the copper lugs. Reading the rule book, I thought it said we could use crimps again this year, but I wasn't sure. Just to clarify, though, can we use crimps on the batteries as well?
Thanks,
-Chris
Unread 08-02-2006, 07:52
Thanks,
-Chris
Yes, you may.
As a side note here...Since all robot current is passing through these connections (battery, main breaker, gound and breaker panel feeds) you need to be very sure of the connection. We crimp and then solder before insulating with heat shrink.
Unread 08-02-2006, 09:07
ForgottenSalad's Avatar
ForgottenSalad ForgottenSalad is offline
In search of a home...
AKA: Michael Wessler
ForgottenSalad will become famous soon enoughForgottenSalad will become famous soon enough
Send a message via AIM to ForgottenSalad
We've run into a problem here.... Since we're using last year's distro panel, the SLU-35 lugs have too small of a hole to fit onto the bolt on the distro panel. Which would be the legal way to do this... Drill out the SLU-35's hole so it fits the bolt, or use last year's SLU-45 lugs?
EDIT: Was it SLU-75 last year? I can't remember off the top of my head.
Unread 08-02-2006, 09:43
SLU 70 (indicating it is twice as big and the 35)
Unread 08-02-2006, 12:46
AKA: Dr. Brooks
no team (WRRF)
The rules say to use the SLU-35s or appropriate crimp on connectors. The rules don't say that SLU-70s are legal. This is a nit, but they hung a lot of teams on the rules requiring SLU-70s last year. Legal terminals were a hot commodity in the pits last year. Posting a QandA on this one would be appropriate...
Eugene
Unread 08-02-2006, 13:12
Tristan Lall's Avatar
FRC #0188 (Woburn Robotics)
The Q&A says that SLU-70s are legal, but not preferred.
Unread 08-02-2006, 13:29
AKA: Dr. Brooks
no team (WRRF)
As Al has repeated many times, if you use the SLU-70s (for the 1/4 inch
attachments) or the SLU-35s (for the number 10 attachments): clean them, screw them, SOLDER THEM, and shrink them! We went so far as to tin plate ours last year, to make the soldering go easier. It takes a BIG soldering iron.
Eugene
Unread 08-02-2006, 13:30
sciguy125 sciguy125 is offline
Electrical Engineer
AKA: Phil Baltar
FRC #1351
sciguy125 has a reputation beyond reputesciguy125 has a reputation beyond reputesciguy125 has a reputation beyond reputesciguy125 has a reputation beyond reputesciguy125 has a reputation beyond reputesciguy125 has a reputation beyond reputesciguy125 has a reputation beyond reputesciguy125 has a reputation beyond reputesciguy125 has a reputation beyond reputesciguy125 has a reputation beyond reputesciguy125 has a reputation beyond repute
Send a message via AIM to sciguy125 Send a message via MSN to sciguy125 Send a message via Yahoo to sciguy125
We ended up drilling ours. It's a little tricky though. I found that the best technique is to sandwich it between two pieces of metal. Take two pieces of 1/4" plate and drill a hole into each of them that matches the current hole on the lug. Sandwich the lug between the two plates and run the bit back through to make sure they're all lined up. Clamp it down and drill through the entire assembly with the appropriate bit.
-----BEGIN GEEK CODE BLOCK-----
Version: 3.12
GE/S/P a-- e y-- r-- s:++ d+ h! X+++
t++ C+ P+ L++ E W++ w M-- V? PS+ PE+
5- R-- tv+ b+ DI+++ D- G
------END GEEK CODE BLOCK------
Unread 08-02-2006, 20:53
We drilled a couple of the 35's in the second week or so, but now that I know the 70's are legal I'll be using those... I don't mind drilling them out, but I don't like how it thins out two of the walls, so I'll just use untouched 70's.
**FIRST EMAIL**/Rule R48 and SLU-70 Copper Terminals Information Rich Wong FIRST E-Mail Blast Archive 2 29-03-2005 17:20
Restricted to the Anderson Connectors in the Kit? sanddrag Electrical 15 20-01-2005 11:36
Spikes Denman Control System 17 16-11-2004 07:51
a word of advice when wiring or rewiring motors with solderless terminals pryoplasm Electrical 12 06-04-2004 11:04
Current Sensor Output Controls1317 Electrical 5 01-02-2004 23:45
