Go to Post As mentors we need to be good role models for students. Because like it or not, we will be role models. - mathking [more]
Unread 08-02-2006, 13:13
Mike's Avatar
Mike Mike is offline
has common ground with Matt Krass
AKA: Mike Sorrenti
FRC #0237 (Sie-H2O-Bots (See-Hoe-Bots) [T.R.I.B.E.])
Mike has a reputation beyond reputeMike has a reputation beyond reputeMike has a reputation beyond reputeMike has a reputation beyond reputeMike has a reputation beyond reputeMike has a reputation beyond reputeMike has a reputation beyond reputeMike has a reputation beyond reputeMike has a reputation beyond reputeMike has a reputation beyond reputeMike has a reputation beyond repute
Defining file name?
I've noticed this in a couple IFI files, and figured it was just some necessary thing for the IFI code, but now it's in Kevin's code and I'm curious.
Why, at the start of most .h files, do we have something similar to
#ifndef _TRACKING_H
#define _TRACKING_H
I searched all the project files and nothing else uses _TRACKING_H, so why have it?
http://www.mikesorrenti.com/
Unread 08-02-2006, 13:21
AKA: Lars Kamen's Roadie
FRC #0051 (Wings of Fire)
Re: Defining file name?
This is so that the code is included only once. For example, let's say you have three files: file1.h, file2.h, and file3.c.
file1.h is the following:
// file1.h
int var1, var2;
char var3, var4;
file2.h is the following:
// file2.h
#include "file1.h"
int var5;
finally, file3.c is the following:
// file3.c
#include "file1.h"
#include "file2.h"
// code here
If you did the above, then var1, var2, var3, and var4 would be defined twice, which is a bad thing. Using the #infdef/#define/#endif would keep this from happening.
Unread 08-02-2006, 17:28
Bongle's Avatar
Bongle Bongle is offline
FRC #2702 (REBotics)
Since the question was already answered, here's more info.
You can do other fun things with preprocessor stuff like that.
Example: What if you wanted your code to do something while you were debugging, and something else in your 'production' or complete competition code?
#define DEBUG
int shoot()
#ifdef DEBUG
  printf("shooting!")
#endif
  shootTheBall()
Basically, the compiler comes through and evaluates the if statement. If it is true, then it will include what is between #if and #endif. Otherwise, it is as if that code is not even there. It's an improvement over using actual code to block out bits, because it doesn't take any of your memory on the robot, and doesn't take any run-time computation to determine whether or not to run printf("shooting!").
So when you're debugging, you just #define DEBUG. When you want your final code to be faster/smaller, just remove the #define DEBUG line, and all your debug-related things will be removed.
.hex file too large for 2004 controller? AL_E Programming 6 21-01-2006 22:54
Reading binary data from a file and writing it in VB complete Programming 1 02-01-2006 21:21
C HELP PLEASE sglegend11 Programming 4 14-11-2005 21:35
Dashv2.ocx dependency file now available archiver 2000 0 23-06-2002 22:00
