Go to Post I've done enough preaching to the choir. Let's carry on changing the culture. - StevenB [more]
Unread 07-02-2006, 12:16
Bob22341 Bob22341 is offline
FRC #1870
Bob22341 will become famous soon enough
No lights on camera
The camera had the lights on it, and we had just trouble shot it so it would follow the target. The lights on the camera went out and we haven't been able to power anything on the camera. We tried charging and checking batteries, reseting the electronics, reloading code and rebuilding the electronics on the camera. None of these worked and the camera is still dead.
If anyone knows what is wrong it would be much appreciated. Thanks.
Unread 07-02-2006, 13:37
Jared Russell's Avatar
Taking a year (mostly) off
Re: No lights on camera
Backup battery charged and plugged in?
Unread 07-02-2006, 14:15
Camera power switch turned on? (flip the switch if not)
Camera circuit board still isolated from the metal frame of the pan/tilt assembly? (fix it if not)
A working cable correctly connected from a PWM port to the camera power input? (plug it in if not)
A charged backup battery plugged in to the RC? (charge and connect if not)
Backup battery voltage present on the PWM port pins? (find and remove the speck of metal shorting between power and ground if not)
Unread 08-02-2006, 12:34
FRC #1870
Checked all of those, still not working.
May have shorted the board.
Suggest other teams put a piece of rubber or equivalent material between the camera board and the mounting bracket.
Unread 08-02-2006, 13:27
The air gap specified in the gimbal assembly instructions is best.
The solder points on the back of the camera will poke through insulating material.
CMU Camera kills robot controller if not found. Chris_Elston Programming 21 27-03-2006 14:30
How To Use the Google Camera generalbrando Kit & Additional Hardware 2 07-02-2006 16:00
Camera Is Spazzing Out! BrittanyV Programming 15 04-02-2006 13:39
Scripting Setup and the Camera + Serial Port Drivers CJO Programming 22 11-01-2006 17:42
Unresponsive camera neilsonster Programming 9 17-02-2005 08:51
