Go to Post I NEVER doubt the insanity of pig farmers. - Amanda Morrison [more]
Unread 07-02-2006, 16:02
Max Brin Max Brin is offline
FRC #1943 (Neat Team)
Max Brin has a spectacular aura aboutMax Brin has a spectacular aura aboutMax Brin has a spectacular aura about
Very wierd compiling problem!
Hey,
I've tried to make a very simple statment:
float test = 3.14;
            printf("%f", test);
it wont print anything.. what seems to be the problem?
Thanks.
Unread 07-02-2006, 16:21
Eldarion's Avatar
Eldarion Eldarion is offline
Electrical Engineer / Computer Geek
AKA: Eldarion Telcontar
no team (Teamless Orphan)
Eldarion has a reputation beyond reputeEldarion has a reputation beyond reputeEldarion has a reputation beyond reputeEldarion has a reputation beyond reputeEldarion has a reputation beyond reputeEldarion has a reputation beyond reputeEldarion has a reputation beyond reputeEldarion has a reputation beyond reputeEldarion has a reputation beyond reputeEldarion has a reputation beyond reputeEldarion has a reputation beyond repute
Send a message via AIM to Eldarion Send a message via Yahoo to Eldarion
Re: Very wierd compiling problem!
Originally Posted by Max Brin
Hey,
float test = 3.14;
            printf("%f", test);
Thanks.
I don't think the RC supports printf with a float modifier. Try %d with an integer value and see what happens.
CMUCam not working? Tracks sporadically? Try this instead: http://www.falconir.com!
PM me for more information if you are interested (it's open source!).
Want the FIRST Email blasts? See here: http://www.chiefdelphi.com/forums/sh...ad.php?t=50809
"The harder the conflict, the more glorious the triumph. What we obtain too cheaply, we esteem too lightly; it is dearness only that gives everything its value."
-- Thomas Paine
If it's falling apart it's a mechanical problem. If it's spewing smoke it's a electrical problem.
If it's rampaging around destroying things it's a programming problem.
"All technology is run on 'Magic Smoke' contained within the device. As everyone knows, whenever the magic smoke is released, the device ceases to function."
-- Anonymous
I currently speak: English, some German, Verilog, x86 and 8051 Assembler, C, C++, VB, VB.NET, ASP, PHP, HTML, UNIX and SQL
So far as I can tell, with the C18 compiler we use,
1) strings to be printf'd need a terminating \r
and
2) %f is not supported.
Unread 08-02-2006, 07:06
Ryan M. Ryan M. is offline
Programming User
FRC #1317 (Digital Fusion)
It appears to be possible (at least for us) to have a printf without a terminating \r, as long as you get a \r in before the buffer is flushed. (presumably at the end of the loop)
Unread 08-02-2006, 12:41
pclements's Avatar
pclements pclements is offline
AKA: Patrick
FRC #1254 (Entropy)
pclements is an unknown quantity at this point
Send a message via Yahoo to pclements
Hey,
float test = 3.14;
            printf("%f", test);
Thanks.
try using an intereger instead of a float, or even a char which will do the same thing a float does. a printable float is not compatable with the Ccompilers.
Does the walker choose the path, or the path the walker?" -- Garth Nix
Unread 08-02-2006, 13:03
aaeamdar's Avatar
aaeamdar aaeamdar is offline
Post-A-Holic
AKA: Paul Dennis
FRC #1719 (The Umbrella Corp)
aaeamdar has a brilliant futureaaeamdar has a brilliant futureaaeamdar has a brilliant futureaaeamdar has a brilliant futureaaeamdar has a brilliant futureaaeamdar has a brilliant futureaaeamdar has a brilliant futureaaeamdar has a brilliant futureaaeamdar has a brilliant futureaaeamdar has a brilliant futureaaeamdar has a brilliant future
2 things:
To be technical, your error (as you've explained it) is run-time, not compile-time error. A run-time error is something odd that happens during the execution of the code that you didn't expect. It may be a crash or just may not print what you thought it would.
The other "thing" is this: when do you need to print out floats? I dunno, maybe you do need them. Important values like motors are unsigned chars, however. Most of what you're working with is bits and chars. If you really need this to work, it's worth your time; otherwise, there are probably 400 better things to do.
Best of luck with it...
Paul dennis
Unread 08-02-2006, 15:43
steven114 steven114 is offline
Programming Wizard and Team Captain
AKA: Steven Schlansker
FRC #0114 (Eaglestrike)
steven114 is a jewel in the roughsteven114 is a jewel in the roughsteven114 is a jewel in the rough
Send a message via AIM to steven114
If you absolutely must print out a float,do this: print the integer part, then take the remaining decimal part, multiply by some power of ten (say, 1000) and print out this number after a decimal point.
Shift to the left, shift to the right!
Pop up, push down, byte, byte, byte!
Need a realistic Statics Problem sanddrag Technical Discussion 10 05-12-2005 15:07
Programming Problem: Extremely Frustrating chantilly_team Programming 19 12-02-2005 23:00
Problem compiling edubot Ben B Programming 3 14-01-2004 00:51
The problem with scouting... archiver 2001 10 23-06-2002 23:49
Major problem with chipphua motors aka Scott White Motors 18 19-03-2002 19:44
