Go to Post When the world gives you lemons make lemonade serve it at your press conference to expand the program. - Koko Ed [more]
Unread 07-02-2006, 15:11
JJMax7 JJMax7 is offline
None #0918 (Circuit Chargers)
Team Role: Driver
JJMax7 is an unknown quantity at this point
Send a message via AIM to JJMax7
Dead zone for RC control
I'm using the arcade drive controls through Easy C, but the current controller the drivers want to use doesn't center itself very well, so I need to know if there is anyway to put a dead zone into the code. Thanks for the help.
Unread 08-02-2006, 15:44
Chris_Elston's Avatar
Chris_Elston Chris_Elston is offline
Controls Engineer
AKA: chakorules
FRC #1501 (Team THRUST)
Chris_Elston has a reputation beyond reputeChris_Elston has a reputation beyond reputeChris_Elston has a reputation beyond reputeChris_Elston has a reputation beyond reputeChris_Elston has a reputation beyond reputeChris_Elston has a reputation beyond reputeChris_Elston has a reputation beyond reputeChris_Elston has a reputation beyond reputeChris_Elston has a reputation beyond reputeChris_Elston has a reputation beyond reputeChris_Elston has a reputation beyond repute
Re: Dead zone for RC control
I think you have two choices:
1. See this Post and use the drive ( ); function. "built in deadband".
2. Make your own "arcade" control by mixing the port1_x and port1_y with a SETPWM. Then using IF statements so that the mixed values from the joystick have to be greater than your deadband, else SetPWM 127.
Team T.H.R.U.S.T. 1501
Download all of our past robot's source code here:Repository
Favorite CD quote:
"That can't be their 'bot. not nearly enough (if any) rivets to be a 1501 machine." ~RogerR: Team #1369
Unread 15-02-2006, 17:37
Team Role: Driver
I figured out a really easy way to do it. Turns out I just didn't think it through. I made a simple If-Else statement. If the joystick values are between then set pwms as 127 else tank drive. Worked well enough.
Unread 15-02-2006, 18:16
ida_noeman's Avatar
ida_noeman ida_noeman is offline
AKA: phobbs
FRC #1719 (Umbrella Corp.)
ida_noeman is on a distinguished road
A very readable way to do it is to make an inline function like this:
#define STOP 127
#define DEAD_ZONE 15 // or any other number, fool around with this to make it work as you want it to
#define IN_DEAD_ZONE(x) (x <= DEAD_ZONE + STOP && x>= STOP - DEAD_ZONE)
This would work with something like this:
if (IN_DEAD_ZONE(p1_y))
p1_y = STOP;
"Weeks of coding can save you hours of planning"
"If the code was hard to write, I'm dam well going to make it hard to read!"
Concept of PID explained ConKbot of Doom Technical Discussion 11 27-01-2008 00:11
Member of multiple (FRC, FLL, VEX) teams in profile/user control panel? Elgin Clock CD Forum Support 3 03-12-2005 20:41
YMTC - Flopper? in the ZONE? Jack Jones You Make The Call 6 04-04-2005 12:59
**FIRST EMAIL**/2005 FRC Game Design Communication to FRC Teams Goobergunch FIRST E-Mail Blast Archive 1 06-01-2005 09:29
