Go to Post This tee-shirt collecting gets kind of addicting, doesn't it? - Chief Hedgehog [more]
Unread 08-02-2006, 16:38
RoboMadi's Avatar
RoboMadi RoboMadi is offline
3 Fs..... Fun Friends FIRST!!
AKA: Imad
FRC #0612
RoboMadi has a brilliant futureRoboMadi has a brilliant futureRoboMadi has a brilliant futureRoboMadi has a brilliant futureRoboMadi has a brilliant futureRoboMadi has a brilliant futureRoboMadi has a brilliant futureRoboMadi has a brilliant futureRoboMadi has a brilliant futureRoboMadi has a brilliant futureRoboMadi has a brilliant future
Re: pic: Team 612 Drive System
Originally Posted by Greg Needel
just a question. Have you had problems with your chain slipping? The back wheels look like they only have about 70 degrees of chain contact with the sprocket. If you haven't i would try testing your bot under load (pushing against a wall or another heavy object and see if they skip. From experience i always aim for a full 180 degrees but never less then 90.
Actually it works pretty good. We tested it on the ramp, and it goes up pretty easily. We came up with ths triangle chain design. The back wheel sprocekt is firmly in contact with the chain just form the bottom. So it don't allow the chain to slide. The top part is in contact too, but its just there.
Also our electrical board is mounted temp. It will eventually be mounted rigth behind our shooter. The shooter is goin to go right on top on our wheels. i'll post the pics soon.
Free Kittens/Tetra Grabber Mr. Lim Rumor Mill 30 08-04-2005 11:36
If you could change one thing.... Koko Ed General Forum 48 31-03-2005 19:23
pic: Team 836 2005 Drive Plate Bcahn836 Robot Showcase 11 09-02-2005 10:13
pic: Possible Team 114 Drive Component James114 Extra Discussion 14 15-01-2005 12:27
The 2003 Index of team's post about their robot... Ken Leung Robot Showcase 4 28-02-2003 00:18
