Go to Post "If two kids from every school who would otherwise have been uninterested in technology watched this special tonight and was inspired to learn more, then the world just changed because of it." - Barry Bonzack [more]
Unread 08-02-2006, 16:35
TEAM1949 TEAM1949 is offline
FRC #1949
TEAM1949 is an unknown quantity at this point
Camera angle - interesting question
This question had been asked but hadn't been answered.
How I can retrieve the camera tilt angle without using the parameter of the blob size?
I am gonn'a find the distance from the goal with the sin of the angle.
Can anyone please answer this question specifically ?
Thanks.
Unread 08-02-2006, 16:52
FRC #1949
Re: Camera angle - interesting question
from the terminal.c:
		// pan angle = ((current pan PWM) - (pan center PWM)) * degrees/pan PWM step
				printf(" Pan Angle (degrees) = %d\r\n", (((int)PAN_SERVO - 124) * 65)/124);
				// tilt angle = ((current tilt PWM) - (tilt center PWM)) * degrees/tilt PWM step
				printf("Tilt Angle (degrees) = %d\r\n", (((int)TILT_SERVO - 144) * 25)/50);
Can anyone explain?
Unread 08-02-2006, 17:06
FRC #1949
I didnt understand only this part :
Unread 08-02-2006, 22:20
DanDon's Avatar
DanDon DanDon is offline
ohhh MY god
AKA: Dan Hoizner
FRC #0375 (The Robotic Plague)
DanDon has a reputation beyond reputeDanDon has a reputation beyond reputeDanDon has a reputation beyond reputeDanDon has a reputation beyond reputeDanDon has a reputation beyond reputeDanDon has a reputation beyond reputeDanDon has a reputation beyond reputeDanDon has a reputation beyond reputeDanDon has a reputation beyond reputeDanDon has a reputation beyond reputeDanDon has a reputation beyond repute
Send a message via ICQ to DanDon Send a message via AIM to DanDon Send a message via MSN to DanDon
Can anyone explain?
Hi, ma kore?
basically degrees/PWM step is the number of degrees per rotation of the servo from its midpoint to either the max or min value of the servo. If you need more help, then PM me with your ICQ number and I'll be happy to help.
What information can we access from the camera? Total Meltdown Programming 37 01-02-2006 11:24
For anyone who doesn't get the camera code..... Jake M Programming 8 16-01-2006 18:56
Camera Calibration organgtool Programming 0 11-01-2006 23:56
Camera Question fred Control System 3 13-02-2005 14:25
Using Base 36 "Compression" For Easier Scouting and Other Interesting Tidbits Adrian Wong Rules/Strategy 9 21-09-2001 20:28
