Go to Post My goal as a mentor is to make myself irrelevant. Is that possible? Probably not. But this is one place I am willing to aim stupidly high. - Ian Curtis [more]
Unread 08-02-2006, 14:04
jaustin jaustin is offline
AKA: Jeff Austin
FRC #2930 (The Taterbotz)
jaustin is an unknown quantity at this point
Team Number 000
Has anyone used the Team number as 000 to "force" the RC into running autonomous mode every time? I've tried it and while the autonomous code appears to be running correctly (pwm values are getting set), none of the PWM signals are getting out to the motors. When I switch back to radio mode, it all works correctly. I was wondering if the 000 disables the PWM out puts some how? I'm in the process of putting a switch together for the OI competition port, but thought this might be faster. Thanks folks!
Unread 08-02-2006, 14:08
kaszeta's Avatar
kaszeta kaszeta is offline
FRC #0095 (Grasshoppers)
kaszeta is a glorious beacon of lightkaszeta is a glorious beacon of lightkaszeta is a glorious beacon of lightkaszeta is a glorious beacon of lightkaszeta is a glorious beacon of light
Re: Team Number 000
Just make a combo disable/auto swith for the competition port. You'll have more control that way.
Unread 08-02-2006, 14:25
Electrical Engineer
Rookie Year: 1995
Re: Team Number 000
Jeff,
We have always used the competition port switch. It's nice to be able to remotely shut down the robot if it starts to run amok.
Mike
Mike Betts
As easy as 355/113...
Unread 08-02-2006, 18:00
devicenull devicenull is offline
Robot? We need a robot?
Rookie Year: 1234
devicenull is just really nicedevicenull is just really nicedevicenull is just really nicedevicenull is just really nicedevicenull is just really nice
Re: Team Number 000
I've done it, and it works. But don't. Do the words "mad robot" mean anything to you? (Trust me, it will happen.)
Not having a remote disable switch when running auto is a bad idea... The comp switch should not be hard at all.. two wires and a switch.
Unread 08-02-2006, 18:09
Tureyhall Tureyhall is offline
AKA: Thomas Hall
FRC #0668 (Apes Of Wrath)
Tureyhall will become famous soon enoughTureyhall will become famous soon enough
Re: Team Number 000
3 if you want autonomous as well as disable.
/*Nerd Camouflage*/
2005 SVR - 668+1072+840 - Semifinalists.
2006 SVR - 668+1280+1693 - Finalists.
2007 SVR - 668+604+624 - Quarter-finalists, Xerox Creativity Award, two highest scores (290-2, 128-0) at SVR.
2007 Nat's - TBA.
Unread 08-02-2006, 18:39
AKA: Jeff Austin
Re: Team Number 000
Message received, but the robot I'm working with is styrofoam and driven by 4 little EDU motors. It's just a software test bed. So I'm hearing that the 000 team number should not disable anything and I have a bug somewhere in my autonomous code that I need to ferret out. Thanks folks!
Here is an update for what it's worth. Using the Team 000 option DID have something to do with my autonomous code working. I hooked up my recently made switch to the competion port of the OI (pins 8 and 5), switched it to autonomous and the motors sprang to life! I'm not sure why, but using the 000 did disable all my pwm outputs. Lesson learned!
Improving the Efficacy of a Team Jaine Perotti Team Organization 5 24-05-2005 19:27
Do you celebrate your team number day? OZ_341 General Forum 63 22-02-2005 04:46
How Many FIRST shirts do you own? Joe Ross General Forum 81 31-08-2004 10:36
The 2003 Index of team's post about their robot... Ken Leung Robot Showcase 4 28-02-2003 00:18
More 'Best' Robots (a well thought list) archiver 2000 2 23-06-2002 23:11
