Go to Post Trapping JVN (or any other IFI employee) is negative infinity [I]and[/I] a caption contest. Trapping 1114 is a measly 50 points, unless you trap Karthik, which multiplies your entire score by -1. - EricH [more]
Unread 08-02-2006, 18:39
jaustin jaustin is offline
AKA: Jeff Austin
FRC #2930 (The Taterbotz)
jaustin is an unknown quantity at this point
Re: Team Number 000
Message received, but the robot I'm working with is styrofoam and driven by 4 little EDU motors. It's just a software test bed. So I'm hearing that the 000 team number should not disable anything and I have a bug somewhere in my autonomous code that I need to ferret out. Thanks folks!
Here is an update for what it's worth. Using the Team 000 option DID have something to do with my autonomous code working. I hooked up my recently made switch to the competion port of the OI (pins 8 and 5), switched it to autonomous and the motors sprang to life! I'm not sure why, but using the 000 did disable all my pwm outputs. Lesson learned!
Improving the Efficacy of a Team Jaine Perotti Team Organization 5 24-05-2005 19:27
Do you celebrate your team number day? OZ_341 General Forum 63 22-02-2005 04:46
How Many FIRST shirts do you own? Joe Ross General Forum 81 31-08-2004 10:36
The 2003 Index of team's post about their robot... Ken Leung Robot Showcase 4 28-02-2003 00:18
More 'Best' Robots (a well thought list) archiver 2000 2 23-06-2002 23:11
