Go to Post Patents are an issue of law which, alas, has little to do with engineering or common sense. - Mike Betts [more]
Unread 08-02-2006, 17:02
railerobotics's Avatar
railerobotics railerobotics is offline
FRC #0935
railerobotics will become famous soon enough
Camera locked on
I have searched forever in the code but I cannot find a variable that says if the camera is or isn't locked on to the target. In atonomous I have trying to make our cannon fire once that the camera is locked on the the target.
Unread 08-02-2006, 17:09
kaszeta's Avatar
kaszeta kaszeta is offline
FRC #0095 (Grasshoppers)
kaszeta is a glorious beacon of lightkaszeta is a glorious beacon of lightkaszeta is a glorious beacon of lightkaszeta is a glorious beacon of lightkaszeta is a glorious beacon of light
Re: Camera locked on
Look in terminal.c in Kevin's camera code. Basically, you can check the value of T_Packet_Data.my, T_Packet_Data.pixels, or T_Packet_Data.confidence.
Unread 08-02-2006, 17:15
FRC #0935
Thanks
Unread 08-02-2006, 17:20
Greg Ross's Avatar
Grammar Curmudgeon
AKA: gwross
FRC #0330 (Beach 'Bots)
Be careful about using T_Packet_Data.my. Kevin's code uses it extensively for distinguishing when the target is or is not in its view. Unfortunately, T_Packet_Data.my does not get cleared when the camera loses the target. I found that this would cause the camera to get stuck pointing off into space sometimes, so I changed all those references to use T_Packet_Data.confidence instead.
Unread 08-02-2006, 19:47
Keith Watson Keith Watson is offline
FRC #0957 (WATSON)
Keith Watson is just really niceKeith Watson is just really niceKeith Watson is just really niceKeith Watson is just really nice
The tracking code also uses PAN_ALLOWABLE_ERROR_DEFAULT and TILT_ALLOWABLE_ERROR_DEFAULT to determine whether the camera is locked or not. Search_Target() already has most (but not all) of the logic. It was simple to modify our code to report the tracking state (searching/tracking/locked) and the target centroid location.
Keith Watson - Professional Software Engineer
No relation to "Kevin" Watson, who created the camera tracking code.
Unread 08-02-2006, 19:50
FRC #0957 (WATSON)
Thanks for pointing this out!
pic: camera locked on light 143ft away!!! kborer22 Extra Discussion 18 08-07-2006 14:49
CMU Camera kills robot controller if not found. Chris_Elston Programming 21 27-03-2006 14:30
How To Use the Google Camera generalbrando Kit & Additional Hardware 2 07-02-2006 16:00
Camera pointing error? Craig Putnam Programming 14 21-01-2006 02:52
Scripting Setup and the Camera + Serial Port Drivers CJO Programming 22 11-01-2006 17:42
