Go to Post Life isn't a set track: you have to go out and make your own path. - Greg Marra [more]
Unread 08-02-2006, 20:43
Re: Encoders and putdata
Originally Posted by theycallhimtom
So I'm getting the error: Timeout on Packet Number (Infinite Loop or no call to put data)
I got the latest version of Kevin's stripped down camera code and added his eeprom and interrupts(following his instructions for how to add them). I also added my code for encoders which I have tested on a different code base and it works. When I ran the encoders off of the new code base I get the above error ONLY when I move a wheel and the interrupt routines get called. They get called around 20 times before it crashes.
I have tried adding putdata in anywhere from twice instead of once to calling it during every interrupt and I still get the same error. I have no loops at all in my code. I have tried commenting out all the function calls in Process_Data_From_Master_uP so that function only calls getdata then putdata and I still get the same error.
Anyone have any ideas?
Here is the encoder code: (which again has been tested to work)
if(ENCODER2 == INPUTTRUE){
      directionTravelingOne = FORWARD;
  }else{
    clockwise*/
    directionTravelingOne = BACKWARD;
     clickRotationsOne--;
Did you retype your code or cut and paste because you have an comment block terminator but no start in the code you have above.
Please cut and paste your entire interrupt handler and your InterruptHandlerLow function including all #pragmas.
Unread 09-02-2006, 00:54
theycallhimtom theycallhimtom is offline
AKA: Tom Conerly
FRC #1540 (The Flaming Chickens)
theycallhimtom has a spectacular aura abouttheycallhimtom has a spectacular aura abouttheycallhimtom has a spectacular aura about
Send a message via AIM to theycallhimtom Send a message via MSN to theycallhimtom
*	FUNCTION:		Int_1_Handler()
*	PURPOSE:		If enabled, the interrupt 1 handler is called when the
*					interrupt 1/digital input 1 pin changes logic level. The
*					edge that the interrupt 1 pin reacts to is programmable
*					(see comments in the Initialize_Interrupts() function,
*					above).
*	CALLED FROM:	user_routines_fast.c/InterruptHandlerLow()
*	PARAMETERS:		None
*	RETURNS:		Nothing
*	COMMENTS:		The PIC18F8520's RB2/INT2 pin on port b is mapped to
*					interrupt 1 on the EDU-RC and digital input 1 on the
*					FRC-RC [108].
//CATLIN FUCNTION
void Int_1_Handler(void)
	//printf("int1");
                //A came second so its going clockwise
      //     printf("TRUE \r");
        }else{
	     //   printf("FALSE subtract from varible \r");
                /*b came first so its going counter clockwise*/
		//printf("%d",clickRotations );
// this function will be called when an interrupt 1 occurs
*	FUNCTION:		Int_2_Handler()
*	PURPOSE:		If enabled, the interrupt 2 handler is called when the
*					interrupt 2/digital input 2 pin changes logic level. The
*					edge that the interrupt 2 pin reacts to is programmable
*					above).
*	PARAMETERS:		None
*	RETURNS:		Nothing
*	COMMENTS:		The PIC18F8520's RB3/CCP2/INT3 pin on port b is mapped
*					to interrupt 2 on the EDU-RC and digital input 2 on the
*					FRC-RC [108].
//CATLIN FUNC
void Int_2_Handler(void)
	//printf("int2");
	//callPutData();
	if(ENCODER1 == INPUTTRUE){
           //printf("TRUE \r");
    }else{
	    	printf("False add one to counter \r");
           clickRotationsOne++;
           printf("%d", clickRotationsOne);
    }	// this function will be called when an interrupt 2 occurs
	//printf("Encoder 1: " + directionTraveling);
	//printf("Total Distance: " + clickRotations);
*	FUNCTION:		Int_3_Handler()
*	PURPOSE:		If enabled, the interrupt 3 handler is called when the
*					interrupt 3/digital input 3 pin changes logic level.
*	PARAMETERS:		RB4_State is the current logic level of the
*					interrupt 3 pin.
*	RETURNS:		Nothing
*	COMMENTS:		The PIC18F8520's RB4/KBI0 pin on port b is mapped to
*					interrupt 3 on the EDU-RC and digital input 3 on the
*					FRC-RC [108].
//CATLIN FUNC
void Int_3_Handler(unsigned char RB4_State)
	//printf("int3");
	//	printf("\n");
	//	printf("%d", (int) RB4_State);
	if(RB4_State == 1){
	    if(ENCODER4 == INPUTTRUE){
           directionTravelingTwo = FORWARD;
        }else{
           directionTravelingTwo = BACKWARD;
           clickRotationsTwo--;
	// this function will be called when an interrupt 3 occurs
*	FUNCTION:		Int_4_Handler()
*	PURPOSE:		If enabled, the interrupt 4 handler is called when the
*					interrupt 4/digital input 4 pin changes logic level.
*	PARAMETERS:		RB5_State is the current logic level of the
*					interrupt 4 pin.
*	RETURNS:		Nothing
*	COMMENTS:		The PIC18F8520's RB5/KBI1/PGM pin on port b is mapped
*					to interrupt 4 on the EDU-RC and digital input 4 on the
*					FRC-RC [108].
//CATLIN FUNC
void Int_4_Handler(unsigned char RB5_State)
	//	printf("\n");
	//printf("%d", (int) ENCODER3);
	if(RB5_State == 1){
		if(ENCODER3 == INPUTTRUE){
	    }else{
	           clickRotationsTwo++;
		// this function will be called when an interrupt 4 occurs
*	FUNCTION:		Int_5_Handler()
*	PURPOSE:		If enabled, the interrupt 5 handler is called when the
*					interrupt 5/digital input 5 pin changes logic level.
*	PARAMETERS:		RB6_State is the current logic level of the
*					interrupt 5 pin.
*	RETURNS:		Nothing
*	COMMENTS:		The PIC18F8520's RB6/KBI2/PGC pin on port b is mapped
*					to interrupt 5 on the EDU-RC and digital input 5 on the
*					FRC-RC [108].
void Int_5_Handler(unsigned char RB6_State)
	printf("int5");
	//	printf("\n");
	if(RB6_State == 1){
	    if(ENCODER6 == INPUTTRUE){
           directionTravelingThree = FORWARD;
        }else{
           directionTravelingThree = BACKWARD;
           clickRotationsThree--;
	// this function will be called when an interrupt 5 occurs
*	FUNCTION:		Int_6_Handler()
*	PURPOSE:		If enabled, the interrupt 6 handler is called when the
*					interrupt 6/digital input 6 pin changes logic level.
*	PARAMETERS:		RB7_State is the current logic level of the
*					interrupt 6 pin.
*	RETURNS:		Nothing
*	COMMENTS:		The PIC18F8520's RB7/KBI3/PGD pin on port b is mapped
*					to interrupt 6 on the EDU-RC and digital input 6 on the
*					FRC-RC [108].
void Int_6_Handler(unsigned char RB7_State)
		//	printf("\n");
	printf("int6");
	//printf("%d", (int) ENCODER5);
	if(RB7_State == 1){
		if(ENCODER5 == INPUTTRUE){
	    }else{
	           clickRotationsThree++;
		// this function will be called when an interrupt 6 occurs
* FUNCTION NAME: InterruptHandlerLow
* PURPOSE:       Low priority interrupt handler
* If you want to use these external low priority interrupts or any of the
* peripheral interrupts then you must enable them in your initialization
* routine.  Innovation First, Inc. will not provide support for using these
* interrupts, so be careful.  There is great potential for glitchy code if good
* interrupt programming practices are not followed.  Especially read p. 28 of
* the "MPLAB(R) C18 C Compiler User's Guide" for information on context saving.
* CALLED FROM:   this file, InterruptVectorLow routine
* ARGUMENTS:     none
* RETURNS:       void
#pragma code
#pragma interruptlow InterruptHandlerLow save=PROD,section(".tmpdata")
void InterruptHandlerLow ()
	unsigned char Port_B;
	unsigned char Port_B_Delta;
	if (INTCONbits.TMR0IF && INTCONbits.TMR0IE) // timer 0 interrupt?
		INTCONbits.TMR0IF = 0; // clear the timer 0 interrupt flag [89]
		Timer_0_Int_Handler(); // call the timer 0 interrupt handler (in interrupts.c)
	else if (PIR1bits.TMR1IF && PIE1bits.TMR1IE) // timer 1 interrupt?
		PIR1bits.TMR1IF = 0; // clear the timer 1 interrupt flag [92]
		Timer_1_Int_Handler(); // call the timer 1 interrupt handler (in interrupts.c)
	else if (PIR1bits.TMR2IF && PIE1bits.TMR2IE) // timer 2 interrupt?
		PIR1bits.TMR2IF = 0; // clear the timer 2 interrupt flag [92]
		Timer_2_Int_Handler(); // call the timer 2 interrupt handler (in interrupts.c)
	else if (PIR2bits.TMR3IF && PIE2bits.TMR3IE) // timer 3 interrupt?
		PIR2bits.TMR3IF = 0; // clear the timer 3 interrupt flag [93]
		Timer_3_Int_Handler(); // call the timer 3 interrupt handler (in interrupts.c)
	else if (PIR3bits.TMR4IF && PIE3bits.TMR4IE) // timer 4 interrupt?
		PIR3bits.TMR4IF = 0; // clear the timer 4 interrupt flag [94]
		Timer_4_Int_Handler(); // call the timer 4 interrupt handler (in interrupts.c)
	else if (INTCON3bits.INT2IF && INTCON3bits.INT2IE) // external interrupt 1?
		INTCON3bits.INT2IF = 0; // clear the interrupt flag [91]
		Int_1_Handler(); // call the interrupt 1 handler (in interrupts.c)
	else if (INTCON3bits.INT3IF && INTCON3bits.INT3IE) // external interrupt 2?
		INTCON3bits.INT3IF = 0; // clear the interrupt flag [91]
		Int_2_Handler(); // call the interrupt 2 handler (in interrupts.c)
	else if (INTCONbits.RBIF && INTCONbits.RBIE) // external interrupts 3 through 6?
		Port_B = PORTB; // remove the "mismatch condition" by reading port b
		INTCONbits.RBIF = 0; // clear the interrupt flag [89]
		Port_B_Delta = Port_B ^ Old_Port_B; // determine which bits have changed
		Old_Port_B = Port_B; // save a copy of port b for next time around
		if(Port_B_Delta & 0x10) // did external interrupt 3 change state?
			Int_3_Handler(Port_B & 0x10 ? 1 : 0); // call the interrupt 3 handler (in interrupts.c)
		if(Port_B_Delta & 0x20) // did external interrupt 4 change state?
			Int_4_Handler(Port_B & 0x20 ? 1 : 0); // call the interrupt 4 handler (in interrupts.c)
		if(Port_B_Delta & 0x40) // did external interrupt 5 change state?
			Int_5_Handler(Port_B & 0x40 ? 1 : 0); // call the interrupt 5 handler (in interrupts.c)
		if(Port_B_Delta & 0x80) // did external interrupt 6 change state?
			Int_6_Handler(Port_B & 0x80 ? 1 : 0); // call the interrupt 6 handler (in interrupts.c)
	if (PIR1bits.RC1IF && PIE1bits.RC1IE) // rx1 interrupt?
		#ifdef ENABLE_SERIAL_PORT_ONE_RX
		Rx_1_Int_Handler(); // call the rx1 interrupt handler (in serial_ports.c)
		#endif
	else if (PIR3bits.RC2IF && PIE3bits.RC2IE) // rx2 interrupt?
		#ifdef ENABLE_SERIAL_PORT_TWO_RX
		Rx_2_Int_Handler(); // call the rx2 interrupt handler (in serial_ports.c)
		#endif
	else if (PIR1bits.TX1IF && PIE1bits.TX1IE) // tx1 interrupt?
		#ifdef ENABLE_SERIAL_PORT_ONE_TX
		Tx_1_Int_Handler(); // call the tx1 interrupt handler (in serial_ports.c)
		#endif
	else if (PIR3bits.TX2IF && PIE3bits.TX2IE) // tx2 interrupt?
		#ifdef ENABLE_SERIAL_PORT_TWO_TX
		Tx_2_Int_Handler(); // call the tx2 interrupt handler (in serial_ports.c)
		#endif
//  ***  IFI Code Starts Here***
//  unsigned char int_byte;
//  if (INTCON3bits.INT2IF && INTCON3bits.INT2IE)       /* The INT2 pin is RB2/DIG I/O 1. */
//    INTCON3bits.INT2IF = 0;
//  else if (INTCON3bits.INT3IF && INTCON3bits.INT3IE)  /* The INT3 pin is RB3/DIG I/O 2. */
//    INTCON3bits.INT3IF = 0;
//  else if (INTCONbits.RBIF && INTCONbits.RBIE)  /* DIG I/O 3-6 (RB4, RB5, RB6, or RB7) changed. */
//    int_byte = PORTB;          /* You must read or write to PORTB */
//    INTCONbits.RBIF = 0;     /*     and clear the interrupt flag         */
//  }                                        /*     to clear the interrupt condition.  */
//  else
//    CheckUartInts();    /* For Dynamic Debug Tool or buffered printf features. */
Thanks for whatever help you can offer. Excuse my comments of printfs that I used for debugging.
Unread 09-02-2006, 19:24
I noticed that there are a few printfs in the interrupt routines that are not commented out. Calling a big complicated, slow function like printf in a interrupt handler is probably the fastest way to crash the controller.
