Go to Post I think I just found a way to replace our entire robot drive team! (no big deal, they are graduating anyway!) :D - dlavery [more]
Unread 08-02-2006, 09:31
scottmso scottmso is offline
FRC #1561 (RoboDucks)
scottmso is an unknown quantity at this point
Send a message via AIM to scottmso
Where is tank drive in 2005 code?
I am still trying to understand the 2005 default code (my programming team is currently using the 2005 robot because they are currently working on the new one.) What I want to do right now is try to modify the tank drive so it is less sensitive. I can find where the 1-joystick drive is but I cannot find where the 2-joystick (tank drive) is. Is there a particular place that it is in in the code? thanks
Unread 08-02-2006, 09:38
ForgottenSalad's Avatar
ForgottenSalad ForgottenSalad is offline
In search of a home...
AKA: Michael Wessler
ForgottenSalad will become famous soon enoughForgottenSalad will become famous soon enough
Send a message via AIM to ForgottenSalad
Re: Where is tank drive in 2005 code?
EDIT: Just noticed your edit - They're located in user_routines.c in the default routine.
They should look something like this.
pwm01 = p1_y;
pwm02 = p2_y;
pwm03 = p3_y;
pwm04 = p4_y;
etc....
Unread 08-02-2006, 09:51
pwm01 = p1_y;
pwm02 = p2_y;
pwm03 = p3_y;
pwm04 = p4_y;
etc....
Now I understand, thanks.
Unread 08-02-2006, 10:09
Unholy Unholy is offline
electrical / makeshift programmer
AKA: Daniel
FRC #1402
Unholy is an unknown quantity at this point
Send a message via AIM to Unholy
also, if you want to limit response to the joystick, you can multiply the joystick value by a decimal value less than 1. For example, one of the robot components in our robot requires small movements, but we found it complicated to just move it slightly, so we multiplied the joystick input by .20, so even when the joystick is fully deflected it will move slowly.
-Unholy
Unread 08-02-2006, 14:16
Matt Krass's Avatar
AKA: Dark Ages
FRC #0263 (Sachem Aftershock)
Be careful, it's very easy to accidentally make it multiply by 0, the PIC has no dedicated floating point processor and does weird things to decimals. It would make your motors constantly run full reverse. Which is also bad
I recommend multiplying up then dividing down. For example instead of
pwm01 = p1_y * 0.2; //Error Prone! BAD!
Use this
pwm01 = (unsigned int)(p1_y * 2) / 10;
Try them both on your calculator, you'll get the same result, but the PIC is more likely to work with the second method...practically guaranteed to work better than the first.
Good luck!
Matt Krass
Unread 08-02-2006, 20:56
We found that out yesterday. If we went forward on the joystick, no matter how little, it'd run full forward... If we went backwards, we'd get gradually faster as you pulled back, but then at 3/4ths of the way it'd reverse and go full forward...
Unread 08-02-2006, 21:16
Stephen Kowski's Avatar
BSEE, MSEE, JD
AKA: employed
never heard of 3/4 of the way there, but when you max out the speed controllers sometimes it goes to 255 there is a problem with, i think, the speed controller that it can differentiate well between 255 and 0 so it goes forward or doesn't act properly....wierd thing, but that is the first place id look and just set the max PWM value possible to 254.
Unread 08-02-2006, 22:03
DanDon's Avatar
DanDon DanDon is offline
ohhh MY god
AKA: Dan Hoizner
FRC #0375 (The Robotic Plague)
DanDon has a reputation beyond reputeDanDon has a reputation beyond reputeDanDon has a reputation beyond reputeDanDon has a reputation beyond reputeDanDon has a reputation beyond reputeDanDon has a reputation beyond reputeDanDon has a reputation beyond reputeDanDon has a reputation beyond reputeDanDon has a reputation beyond reputeDanDon has a reputation beyond reputeDanDon has a reputation beyond repute
Send a message via ICQ to DanDon Send a message via AIM to DanDon Send a message via MSN to DanDon
In order to stop the full forward when moving the joystick forward just a bit, you can try putting a deadband into the drive code.
You can try something like this:
 if(p1_y>117 && p1_y<137) //+-10 unit deadband around 127 neutral
	   pwm01=127;
else
	   pwm01=p1_y;
then just experiment with the deadband size to see which range feels best for you driver(s).
Hope this helps,
looking for 1 joystick Pbasic drive code Greg Needel Programming 8 02-09-2005 20:35
pic: Team 836 2005 Drive Plate Bcahn836 Robot Showcase 11 09-02-2005 10:13
2005 default code won't compile Robby Programming 22 04-02-2005 18:21
Sourceforge for Code Repository and other stuff SilverStar Programming 9 15-01-2005 21:16
Recovering code from the RC Orborde Programming 15 04-12-2004 20:02
